Question about Photography
Rangefinder not working and dust in lens - Photography
Blurred numbers on Bushnell range finder.What's the problem?
Bushnell V3 display question - Toronto Golf Nuts - Greater Toronto ...
www.torontogolfnuts.com > Golf Discussion Forum > Golf Gear & Equipment
Apr 8, 2014 - 22 posts - ‎3 authors
Bushnell V3 display question Golf Gear & Equipment. ... When I start it, the numbers are clear but it does not stay like that the whole time. ... Yea I used that and turned all the way counterclockwise (all the way clockwise was very blurry). .... to read and drive and has a real problem using my rangefinder.
Bushnell blurry display Rangefinders Questions & Answers (with ...
www.fixya.com > Forum > Tags > blurry display > Rangefinders display the display appears but does not display yardage Here is the link to the instruction manual if you need it; ... Sight target needs adjustment When i look ...
DIY Fix For A Malfunctioning Rangefinder On The Cheap
fardevice.com/diy-fix-for-a-malfunctioning-rangefinder/ 4 Common Malfunctioning Rangefinder Encountered (and How to Fix Them), or blank ... Bushnell Tour V3 Jolt Standard Edition Golf Laser Rangefinder .... This could be rooted to a blurry focus lens or laser output, so it's really important to ...
Bushnell - I am having difficulty seeing through my scope, all images ...
bushnell.com/global/customer.../i-am-having-difficulty-seeing-through-my-scope,-al I am having difficulty seeing through my scope, all images seem blurry. How can I properly focus ... What battery does my rangefinder take? All my pictures are ...
Bushnell Golf - Bushnell Golf
bushnellgolf.com/ The undisputed #1 Laser Rangefinder in golf ... Bushnell Tour Domination. The #1 Rangefinder in Professional Golf For Over A Decade. Learn More. The #1 ...
Bushnell Tour Z6 Laser Rangefinder - Review - MyGolfSpy.com
https://www.mygolfspy.com/bushnell-tour-z6-laser-rangefinder-review/ 6 posts - ‎4 authors
The Final Contender In The Rangefinder Round Up: The Bushnell Tour Z6 ... Our second entrant is the Callaway RAZR Rangefinder dropped a .... I have near perfect eyesight, but when target is clear, number is blurred and vice ...
Blurry vision Range finders - GPS/Range Finders/Mobile Apps - GolfWRX
www.golfwrx.com > ... > Equipment > GPS/Range Finders/Mobile Apps May 14, 2015 - 5 posts - ‎5 authors
What causes a range finder to have blurry vision through lens? Im looking to purchase a used Bushnell tour v2 in a couple minutes and I've ... Which Laser Rangefinder
2 Aug 2014
Pro 1M Slope = Bad, Bushnell = Good
1 Aug 2013
Problems with Bushnell Pinseeker 1500?
24 Jan 2009
More results from www.golfwrx.com
Jan 07, 2017 | Bushnell Optics
My rangefinder fell in a lake and is now dead and has water droplets on the lens. Can it be repaired or dried out?
Not 100% sure but remove battery, dry as much as possible with paper towels, then leave in a warm place for a few days and hope
Sep 28, 2015 | Bushnell Tour v3 Rangefinders
My yukon sightmark sm650 rangefinder laser is not working.The golf shop sold me a "Parview LS650" after looking around the internet, it looks exactly like the sm650. To my question....the laser...
Take it apart by peeling away rubber cover and then remove two mounting screws. Carefully split cases and see where parts are arranged just in case they shift. Laser and lens frequently get jarred loose ESP in a golf cart environment. Place laser and lens if loose back in mounts and gluon in place with superglue or equivalent. Make sure to get no glue on lenses. Reassemble and it should be good to go again. Total time. Ten minutes maybe.
Jun 09, 2011 | Yukon SightMark SM650 Rangefinder
Bushnell yardage Pro won't read distances. Short
Bushnell has discontinued service on the yp500, yp400,yp800,yp800.yp1000. Basically all the units that look like this one. They will offer you a new unit at wholesale price.
call 800.423.3537 and ask them
mtg
Oct 08, 2009 | Bushnell Yardage Pro 500 Rangefinder
Inconsistent and unreliable readings
A flag is a hard object to get a reading on. It constantly moves and the sound or light waves (depending on the model) will not be reflected consistantly. Clean the sender lens and the receiver lens and install new batteries. Recalibrate the unit using something stationary, like a FLAT wall.
Oct 03, 2009 | Bushnell Pinseeker 1500 Rangefinder
Pieces of dirt/oil residue on INSIDE of viewing lens.
That is not oil.....its thermal burns. Thermal burns happen when the eyepiece cap is not used. Sunlight burns the surface of the LCD display. This is permanent damage. Cleaning will not fix this. The repair center can fix.
Sep 03, 2008 | Bushnell PinSeeker 1500 20-5103...
Pinseeker is blurred
There is an adjustment ring bewteen the eye piece and the body. Make sure the white ines are lined up and it should come back into focus.
Jun 17, 2008 | Bushnell PinSeeker 1500 20-5103...
Converting to Metric
I just got an answer back from Cabela's customer service. "Hello, Thank you for contacting Cabela's Product Information. I am sorry the Cabela's CLR800 Laser Rangefinders Item:7IS-711749 reads only in yards. I hope this information helps. If you have any more questions, please contact us. Have a Great Day" Sorry if this is bad news, hope it helps :)
Oct 24, 2006 | Cabela's CLR800 Rangefinder
Unit "cannot measure" at any distance
Had the same problem... Pushed the mode button and the power button simultaneously for 30 seconds, then it worked again...
Oct 18, 2006 | Nikon ProStaff Laser 440 Rangefinder
Broken lenses
I hate to tell you that I have the same problem but only one, no solution yet!!! Mine doesn't really work fine... When you look inside it is like blue... it actually makes the LED much easier to read but in low lite situations it makes it impossible to use...
Good Luck..
Sep 12, 2006 | Simmons Outdoor Yardage Master 801445...
Photography Logo
78 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
