Question about Breadman TR2828 Pro Bread Maker
I got an error that is 5 an upside down F 00, what does this mean
    Genius:
  • Breadman Master
  • 1,280 Answers
Hi that usually means there is a problem with the temperature of your cook chamber (oven portion of your machine). If you have just finished baking a loaf it will read that before it cools down...or, if the chamber is too cold it will give you that message or similar to it. Try again after it has been at room temperature for awhile....
Posted on Nov 14, 2010
My LG F14A8FDA6 has a upside down 30, what may b the problem?
Hi, This could be an error code. Meaning there is a problem that should be look at by your repair man. Good luck.
Dec 18, 2014 | LG Washing Machines
Breaking password on cisco 857w
When the router first starts booting you need keep hitting the break sequence which should be crtl+F6 and that should bring you to ROMMON mode. you should get a prompt rommon 1>, that means you did it right. Now you need to change the configuration registers to 0x2142 by typing "confreg 0x2142". then type reset to restart the router. It should now ignore the saved config. hit crtl+c to cancel the initial setup, type "enable" to get to the enable prompt. Next type "copy startup-config running-config" to copy the startup configuration to the running configuration. Next type "configure terminal" to enter global configuration mode. Now you can type "enable secret <password>" to change the password to what you want. Last you need to change the config registers back to 0x2102 by entering the command config-register 0x2102.
Feb 17, 2012 | Cisco 857 ADSL Wireless Router...
My canon camera after 4 to 5 picture is saying e32 and shut down then i have to start again
The E32 error means a hardware or system failure generally not repairable by the user. If you purchased your camera new / retail, it has a full one year warranty from Canon. If this is unsuccessful, you should contact one of the Canon repair contacts for free warranty service using the information provided below.
Canon Customer Support Center
Hours: Monday-Friday 10:00 a.m. - 10:00 p.m. ET, excluding holidays
Phone: 1-800-OK-CANON (toll free)
1-800-652-2666
TTD: 1-866-251-3752 (toll free)
Email: carecenter@cits.canon.com
Jun 25, 2011 | Cameras
Kenwood cd player - Since i used an ipod, it comes up error 5, and wont let me play a CD in the car, or any other Ipod. Any ideas on how to reboot the player, or get it working.
According to experts, error 5 on the player means that the player is reading the cd upside down or it cannot read the disc. you may need to run a cd cleaner ten check if it can read the cd again or if not you may need to take the player apart to clean it manually.
Cheers!!
Sep 03, 2010 | Kenwood Audio Players & Recorders
When i install cd it says error 6 on my clarion dxz465mp
Clarion Audio error codes:
Error Codes:
Error 1 Battery inside CD Changer needs to be replaced.
Error 2 CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3 CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4 Connection problem. Reconnect the data cable.
Error 5 CD error message. Could not read correct data due to CD ROM.
Error 6 CD error message. Could not read data from disc because it is upside-down.
Error 8 Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9 Weak RF. Try alternate frequency
Even though it says error 6 is an upside down cd, it just means the disc cant be read. usualy means the laser is dirty, out of adjustment, or not working.
Aug 19, 2009 | Clarion DXZ465MP CD Player
Burn errors cant get drive to write
It looks like from error codes that yoi may have a hardware error, or a disk format problem, if this is only burning problem you have on pc and it worked before, then uninstall and reinstall Nero, info gathered from here,
http://www.isobuster.com/help.php?help=305
sense code 5 ASC 2c= 5 / 2C / 00 COMMAND SEQUENCE ERROR
5ASC2700=5 / 27 / 00 WRITE PROTECTED
Please give good rating if this helps you or points you in right direction, thanks
Apr 12, 2009 | Computers & Internet
An upside down triangle with an explanation point
It means problem on Brake system!You need Tech2 to reed def.cods
Dec 17, 2008 | 1999 Saab 9-5
How do i find what an error code means?
F11 Communication error CCU (control) and MCU (Motor Control)
. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
Sep 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I/O error
Your hard-drive is unreadable or needs repairing the sectors. Meaning you have BAD-SECTORS ON YOUR DRIVE
Jul 25, 2008 | Computers & Internet
Breadman TR2828 Pro Bread Maker Logo
94 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
