Question about Sony KDF-E50A10 50 in. LCD HDTV
My Sony Wega Engine KDF-E5A10 tv power will come on momentarily with the green power/standby light flashing for a few seconds, then turns to red, then shuts off by itself. The lamp fan blades do come on and run during this process but of course shut down when it powers down. The lamp light on the front of the tv isn't coming on.
experttv
  • 203 Answers
SOURCE: 42" sony wega KDF-E42A10
4 blinks is a fan error. I would take the back off and look to see if the fans that are visable are spinning when you try to turn it on. If you see one that is not spinning it needs to be replaced. If all the fans you can see are spining then there may be some fans that are hidden, in this case you will need to be able to use a meter to determine what fan to replace. Let me know what you find!
Tim nolan
Posted on Sep 24, 2008
  • 58 Answers
SOURCE: My Sony Wega KDF E50A10 has developed an excess of
Some of these models have this problem from production.
I would recommend to contact SONY and tell them the problem they may be able to fix your TV at no cost, since some of their Light engines have a recall but I'm not sure if your model number is one of those.
If you want to fix the TV yourself you need to replace the light engine and that requires advanced skills for this product
hope that was helpful
thank you
Posted on Apr 25, 2009
Beelz
  • 666 Answers
SOURCE: KDF-46E2000 Sony wega. Bought new
you will want to look through your user guide for a error count reset you have to let the tv know that the new hardware has been installed by doing this or restoring factory default via your user guide
hope this helps
Robb
Posted on Sep 21, 2010
ginko
  • 19396 Answers
SOURCE: i need a replacement lamp
Hi.
Here the part:
KDF-E42A10 KDFE42A10
Posted on Apr 01, 2011
Kensolutions
  • 455 Answers
SOURCE: sony 3 lcd rear projection tv hd w/ wega gate.
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Posted on Jun 12, 2011
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Tv wont power up Standby light keeps flashing.
First step in any Sony LCD projector repair is bulb or lamp replacement. Fixes 95% of problems.
Taking apart and trying to measure things without a known good bulb is a waste of time and effort.
easyab
ConvergenceRepair.com
Feb 26, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
The tv repeatedly turns on then off
First area to check out is the power supply of the set.
Jun 14, 2017 | Sony Grand WEGA KDF-60XS955 60" Rear...
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
I just replaced the lamp on my sony wega 42WE655 tv and the lamp replacement indicator light onthe front no longer indicates that it is bad, but the standby light keeps flashing red. when i try to turn it...
If you just replaced the lamp then there's something wrong in the power circuit or you have a bad lamp. If you can I would take the back cover off and look at the board where the power cord connects and lok around it for swollen capacitors. Let me know if you find anything.
Oct 16, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sound went out, tv turned off, red light flashing...
The Lamp being bad as well as one of the three fans in the unit not turning could also cause the problem.
Hope this helps,
Skyassoc
Jul 23, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Mar 19, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KDF-50WE655 will not power up. Red blight blinks 4 times
4 blinks shows problem either one or all 4 fans are not working AND internal temperature high error.
If you are familiar with TV repair and know basic electronics then unplug TV from AC outlet an take off back cover and check fans are running?
Jan 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony KDF-E50A10 50 in. LCD HDTV Logo
78 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
