Question about PC Chips A15G (V10A) Motherboard
Motherboard A156 V1.0 disconnected the power sw and reset sw and forgot what prongs they belong in
I cleaned my pc, and disconected the wires that are right downside corner. I cant remember how to put them back rightly. Any help? hdd led power led + power led - power switch (sw) reset switch (sw)
H57H-AM2 v2 Motherboard in a Gateway DX4840 wire connections for Front Panel are shown here in Photo. I took them before I disconnected mine so it works.3_3_2012_12_10_44_pm.jpg3_3_2012_12_10_56_pm.jpg
Jun 15, 2010 | EliteGroup ECS L4VXA2 (CDL4VXA2)...
I have a t3985 emachine that won't power up. I've opened the case and vacuumed it, took the power supply out vacuumed it. Plug in shows green led on motherboard. i'm wondering if it is the pwr sw. i...
If you carefully take a screw driver and short the two power switch pins together it should start. Did it work before you cleaned it? On the connector itself it should say power sw.
Apr 07, 2010 | Dell (E210882) Motherboard
Hi.unfortunately I disconnected all wires from motherboard and on the end I have problem because I don't really know in which pin I should connect the power sw wire and reset sw wire
hi, heres a tip, you will need a diagram of your motherboard. if you have one, then you can start looking for the wires where it should be put. if none then you can search in the web for a diagram, you should know the exact model of your motherboard when searching for precise schematics.
Feb 23, 2010 | Computers & Internet
Where does the pwr sw plug go to on the motherboard
There is no way to tell you exactly where it goes without knowing the make and model of the motherboard. However all motherboard label the connection point on the board itself. What you are looking for is usually located in the lower right hand corner of the board and in most cases it will be labeled "F_PANEL" for front panel. There will be one or two rows of metal prongs if there are other items located on the front such as LED's or a reset switch simply follow the wires because all the front panel displays and switches are located in the same place.. These prongs will be grouped in 2s 3s and 4s.
The tricky part is reading the small print located near the prongs. They will be abbreviated such as +PW-(power switch), +RES- (reset switch), +PWR LED- (power led indicator), +HD- (hard drive activity indicator).
The + and - don't really apply to the power switch so you don't have to worry about that.
Hope this helps. Please let me know if you need any other info or are just unclear about anything.
Oct 15, 2009 | Gateway DX4200-09 PC Desktop
Reenstallin motherboard
GO TO THE ASUS WEB SITE THE INSTALL MANUALS ARE ALL THERE.
Aug 17, 2009 | ASUS K8S-MX Motherboard
Reset sw, power sw, and hdd led where do i put them on the motherboard
hello, your front panel connectors like reset sw, power sw, hdd led, you can search easily. a use of screw driver touch all front panel connectors, if any response of connectors connect it.
Aug 10, 2009 | MSI 745 Ultra (MS-6561-010) Motherboard
Can't Fix FRONT PANEL HEADER on my Motherboard
Here is a link to your motherboard manual:
D845PEBT2 Manual
Go to Page 33 for the Front Panel connections...with pictures. :-)
Thanks for using Fixya.
Jun 12, 2009 | Intel Desktop Board D845PEBT2 Motherboard
D946GZIS
look on mobo for pw thats power try it both ways to it boots up
Oct 09, 2008 | Intel D946GZIS Motherboard
PC Chips A15G (V10A) Motherboard Logo
268 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Steven Burn
Steven Burn
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
