Question about Philips CDR570 CD Recorder
My 570 CDR will not load a disc - it just keeps saying 'no disc' - whichever type is inserted either blank or pre - recorded. Any thoughts on this
    Guru:
  • 2,178 Answers
The laser is either bad or has a dirty lens. Open the unit and inspect the lens - if it's dirty, clean carefully with a "Q" tip and alcohol. Turn the player on and see if it emits light from the lens and also observe it move up and down.
Posted on Nov 13, 2010
Testimonial: "Thanks for that - it looks like I'll need to have a new Laser Lens fitted"
Why does my philips cdr 570 mini recorder does not take blank cd torecord
Wrong type of disc (needs CDR or CDRW) or the laser lens is dsuty. Try a cleaning disc
Aug 31, 2014 | Audio Players & Recorders
When u put a blank CD in it will say blank disc when you push REC. it will say Data disc and with a different CD it will say -79.59 e-mail me at j.smedley@moreheadstate.edu
I think your problem is that you are using a blank CDROM type disc in a CD Audio recorder. If you "burn" cds on a computer, it does not matter what type of cdr you use, but if it's for a stand alone CD Recorder (that you ise with hifi/dj stuff) you MUST use CDR AUDIO discs (sometinmes it will even say FOR MUSIC)
Sep 07, 2010 | Sony RCD-W500C 5-Disc CD Recorder
I have the Denon CDR-W1500 recorder and the recording side no longer functions. It doesn't have that many hours of use. The tray doesn't recognize a blank cd but both sides will playback discs. Your help...
Your original post said it was blank discs that didn't work.
Now it's ALL discs including pre-recorderd ones. THAT changes things considerably.
Is it audibly rotating the disc once it's loaded?
May 21, 2010 | Denon CDR-M30 CD Recorder
Phillips CDR 570
Let's start with an assumption... you're using ReWriteable discs.
What specific message do you get when you try to unfinalize it?
When finishing a recording, what does it display instead of "update" when you stop?
May 04, 2010 | Philips CDR796 2-Disc CD Recorder
Cd not recording
Be sure to "finalize" the recorded cd before use in another cd player. Another thing is there are always a few bad discs in a spindle of blank discs... And sometimes you will get "check disc" or "bad disc" when a blank disc is inserted. I would be sure to use blank discs for audio use, not computer use, with your Yamaha.
Apr 14, 2010 | Yamaha CDR-D651 2-Disc CD Recorder
My cd recorder wont read blank cds help me please
Do as it asks, insert blank CD-Audio or CD-Music media.
Discs for recording
For recording, make sure to use special audio discs only.
These discs are marked with “Digital Audio” and the logos shown below.
There are two different types of audio discs for the use on this CD recorder:
– CD-Audio Recordable (CDR) discs
These discs can be recorded on once and
play in all standard CD players and CD
recorders, when they are finalized.
– CD-Audio ReWritable (CDRW) discs
These discs can be recorded on, erased and
re-recorded many times and play in CDRW
compatible CD players and CD recorders,
– All Philips CD players and CD recorders
with the sticker shown here are CDRW
compatible.
To ensure proper working of the set we recommend the use of Philips audio CDR and audio CDRW discs only.
Note: Do not use a computer CDR or CDRW as recording will not work!
Go here and download the manual. You'll need it.
http://www.p4c.philips.com/files/c/cdr602_00s/cdr602_00s_dfu_eng.pdf
Mar 04, 2010 | Philips CDR602 CD Recorder
Hello i have a Philips cdr 870. With every blank CD inserted, the display shows NO AUDIO. Pre recorded CDs play OK. Unable to record. I have recently aquired this machine and this is the first time I have...
You are probably inserting blank computer discs, eg 650 or 700mb rather than blank music CD-R or CD RW`s which this machine is designed to work with. The correct discs are labelled "music audio" or 80 minutes. You can only use these types of discs. Why? When these recorders first came out, it was a way of battling piracey in copying discs. I believe there is a "hack" to enable this player to use blank computer discs.
SMA
Jan 13, 2010 | Philips CDR870 CD Recorder
My CD Recorder is not reading my blank discs. What can be the pro
hi not sure if this helps but some disc ,s ive used on my 500s won,t work either so i changed the type of disc and it seems to do the trick i think some disc,s just aren,t good enough ie cheap ones .
Jan 13, 2009 | Philips CDR600 CD Recorder
RECORD DROP OUT
Just bought this CDR 570 and not use yet.
Reading the instruction manual - yes, life experience has taught me some really useful stuff! -
Under 'Discs for recording' on page 7 it says at end of section
IMPORTANT:
To ensure proper working of the set we recommend the use of PHILIPS audio CDR and audio CDRW discs only'
Roughly translated I read this to me - 'don't blame us if the set don't work using other (non-compatible) discs' !!
Oct 02, 2007 | Philips CDR570 CD Recorder
Philips CDR570 CD Recorder Logo
351 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
