Question about Honda Garden
How much oil do I put in my Honda GX390 13hp Pressure Washer. Theres no lines on the Dipstick
Capacity is 1.16 U.S. quart - The 1st solution provided actually works, but if you are looking for the procedure listed in the Honda GX390 manual here it is: Unscrew oil fill plug and clean it off. Then insert it back into the hole but don't turn it in, just press it up against the front edge. The oil level should be up to the neck of the stem that's inserted. Oil should be present half way up the stick at the very minimum.
Posted on Sep 25, 2013
  • 57 Answers
You fill the oil up to the dipstick hole,just so it doesn't over flow out.
Posted on Dec 20, 2010
What oil viscosity and how much on my simpson pressure washer msv 3024
Here's a link to your Simpson manual:
http://simpsoncleaning.com/wp-content/uploads/2016/manuals/megashot/MSV3024-I-pwmanual-7107460.pdf
No oil is required for the pump.
10W-30 is normally specified for a Honda GCV160-GCV190 engine. You drain the oil by removing the oil cap/dipstick and then tilting the machine on it's side so that the oil can drain out if the oil fill into a container. (Drain when warm so it flows easily).
The capacity of the engine is ~18.6 oz. Refill amount is ~12.0-13.5 oz. (either engine).
When refilling, add oil and check on dipstick often. To check, press the dipstick into the oil fill, but DO NOT SCREW IT DOWN. Just insert the dipstick in until it contacts the top of the oil fill. The correct reading is between the lower and upper limits marked on the dipstick. (You may have to look carefully to see the marks).
Dec 27, 2015 | Simpson Garden
Oil capacity
oil capacity 1979 Ford Thunderbird 5.8 litre
Jan 03, 2014 | John Deere 020297 Gas Pressure Washer
How much oil does the Anrovi. RkV 4g36 take
rkv pump half of sight glass on back cover any excess can cause over flow if back cover has no sight glass then you will have to use the dipstick do as follow fill pump crankcase while inserting the dipstick til it stops without screwing it in then remove the dipstick and place the end to the pump casing if you see oil your okay cause by the time you fully insert the stick its gonna show where it should be and again half the sight glass:):)best oil to use is 30w non-detergent oil
Jun 18, 2013 | Honda Pressure Washer PSI 3000
I can not find how much oil to use in the Generac Pressure washer 2700.
the only thing i can suggest put your pressure washer on level surface and start fill the oil when gets to the right level the oil start coming out
Apr 19, 2013 | Generac Generator 5989 2,700 PSI 2.3 GPM...
Can i run plus gas in my washer
I'm not sure what you mean.
I think you are asking if your power washer needs oil mixed with the gas.
Does your machine have a oil reservoir below the engine?
If there is a place to put engine oil, then your engine runs on ordinary gasoline.
The pump oil is SAE20 or SAE30 non-detergent motor oil > oil comes up half way inside box.
The engine oil is 10W30 motor oil > oil comes up bit more than half way on dipstick
Oct 21, 2010 | Northstar Pressure Washer 3000 PSI
What type of gas does it take
Is this a big power washer as shown in the photograph?
Is there a separate place to put oil for engine and pump?
If your engine has a place to put oil, then the engine takes ordinary gasoline
If you have a small engine like a weed-eater or chain-saw, and there is not a separate reservoir for oil, then you mix 2-cycle engine oil with the gas in a 40:1 ratio
Pressure washer oil:
Pump fills about half-way up with SAE20 or SAE30 non-detergent motor oil
Engine fills half way up dipstick with 10-W-30 motor oil
Oct 15, 2010 | Mi T M WP-2700-4MHB Pressure Washer
Hi I just bought a Honda pressure washer. The
You just bought it which means it is under warranty. Take it back where you bought it or call Honda. You must have the vent plug installed to use the machine. If it is blowing oil out the vent plug then it is either overfull or it is building up pressure for some reason. Make sure it is not overfull and if not, then call Honda and avail yourself of the warranty. If it is overfull, remove enough oil to get it to the proper level.
Apr 16, 2010 | Honda Maxus Pressure Washer MX5222
How many quarts of motor oil does it hold with filter
the oil light isn't for oil level, its for pressure. if the oil is touching the lines on the dipstick, you have plenty. don't overfill it, that will cause other issues, such as smoking and misfiring. make sure the level is between the lines on the dipstick. if the level is correct and the light is still on, there is an internal oil pressure problem, such as oil pump, clogged oil passages, or worn out engine bearings (cam, crank, rods). you should not drive the car if it is full of oil and the oil light is on. have it towed to a shop or serious engine damage could occur, if it already hasn't
Feb 21, 2010 | 1995 Honda Accord
What oil does a hondapressure washer use and do i put it in the dipstick
standard 40 wieght should work fine and you just pour it in the area where you check the oil with a funnel
Sep 14, 2009 | Honda Garden
The red light on the dashboard does not extinguish. What does it mean? I mean after starting it keeps on burning while normally it goes out.
Sounds like you are low on oil...check your oil level at the dipstick...under no circumstances are you to start that engine until you check the oil level. I will bet you have an oil leak somewhere...trailer the bike to the Honda shop nearest you!
Sep 10, 2009 | 1984 Honda VT 500 C Shadow
Garden Logo
3,043 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
