Question about Maytag Washing Machines
MAYTAG WASHING MACHINE, DRUM WONT SPIN OR OSCILLATE
    President:
  • 1,654 Answers
Either your motor is bad or the coupling to the motor and transmission is bad. If you are hearing a grinding noise then the coupling is probaly bad, if you aren't hearing any noise at all the I would suspect the motor or possibly the timer. try moving the timer/selector switch around to different cycles to see if it will work on another cycle, if it does the I would suspect the timer, if not then I suspect something in the motor-tranmission-coupling.
Posted on Nov 14, 2010
My maytag hav2558aww wont turn on wash cycle
Possible that the grinding noise comes from the drum, irregular movement or broken paddles.
You can try and attempt only if equipped with a fundamental understanding of the working .
I shall give you some tips to this click 1..: Washing Machine
2. Replacing bearings
Jan 24, 2013 | Maytag HAV2558 Top Load Washer
Wont spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 05, 2011 | Maytag Washing Machines
My Maytag bravos wont spin out
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 23, 2010 | Maytag Bravos MTW6600T Top Load Washer
Maytag Neptune washing machine - wont drain & spin
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
heatman101
May 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag washing machine. .. spin cycle throws
Did you remove the drum protecion ? (a kind of 2 or 4 big screws that attach the drum to the body of the machine to protect it during transportation - new machines ships like this from factory)
If you continue to use it without removing those attachements, not only it is dangerous but also you will damage it.
Have a look on the installation manual, the re should be discribed how to remove them.
Hope this helps.
Sep 10, 2009 | Maytag Washing Machines
My maytag washer will not spin
HI, try to physically spin the drum.there should be some slight resistance but not a lot. if the drum spins freely and, with ease, replace the Motor control board. is has failed in this case.
***Now, if the drum dose not spin freely, this will confirm a failed electric motor.
Jul 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Feb 16, 2009 | Maytag PAV2300 Top Load Washer
Washing Machine agitates only
maytag front loader washing machinne the drum agitates but does not spin
Feb 10, 2009 | Maytag MAH6500 Neptune Front Loading...
I have a maytag neptune washer that will not spin or drain.
if the drum wont spin it could be the motor carbon brushes ,all machines have a drain trap some get accsess from the front of the machine some are acsessed from under the machine these get everything from bits of clothes ,coins, another possability is the pump witch drains the machine
Oct 05, 2008 | Maytag Washing Machines
Maytag performa pye/g2200,3200
when you say the drum wont spin even manually. Do you mean the drum is too stiff to turn by hand? If so the bearings may have seized up solid. If the drum is free to turn by hand, the pump may be blocked, or burned out & not allowing the water out. If so the circiut wont allow the machine to spin. If thats the case, unblock or replace the pump
Oct 20, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
55 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
