Question about Linksys Wireless-G WRT54G Router
Router " won't start"
On device manager says router "won't start - code 10 "
What is code 10 ?
Laptops are not detecting any signal. All worked fine previously.
Thanks for your help!
  • Ryan Croussore
    Ryan Croussore May 11, 2010
    bbranhut, can you clear up where you are seeing this error code? Are you seeing this in the windows device manager?
    Also have you tried rebooting the router? unplug the power cable for 20 seconds from the back of the device, plug it back in after 1 minute try to connect one of the laptops.
  • 4,472 Answers
Code 10 loadTOCNode(2, 'moreinformation'); If the device has a "FailReasonString" value in its hardware key, that string is displayed as the error message. The driver or enumerator places this registry string value there. If there is no "FailReasonString" in the hardware key, the following generic error message is displayed:
This device is either not present, not working properly, or does not have all the drivers installed. (Code 10)
Try upgrading the device drivers for this device.
Solution button: Update Driver
To resolve this error code, make sure the device is connected to the computer correctly. For example, make sure all cables are plugged in fully and that all adapter cards are properly seated. Follow the suggested solution button and update the device driver. It may be possible to remove the device and redetect it using the Add New Hardware wizard.
I am sorry that we got disconnected in the chat. Please don't hesitate as I will assist you at anytime. I believe their chat session software is not working with the new firefox.
Thanks,
Lee
Posted on Jun 18, 2008
My Hitachi Simpledrive Mini 250 suddenly quit....when I lookein the device manager it said Code 10, would not start????
Sounds like a disk error and it cant read the start of the drive. If it still detects it you might be able to repair it with a partition recovery or partition repair tool available online.
Dec 11, 2014 | Hitachi SimpleDrive Mini 250GB USB 20...
USB dongle installs alright but does not detect GSM signal and does not show on any port
Hello, try using the dongle on another computer, If it works fine then the dongle has a problem initializing on your usb ports. Remove all usb devises, restart your computer and try again. If the problem remains check device manager (Right on Computer and click Properties, and then Device Manager) for any usb devices not properly removed (they will have the yellow warning sign), right click in them and choose uninstall.
Hope this helps, Thanks for using FixYa
Jul 23, 2011 | Computers & Internet
I've spoken to who provides my wireless network and they insist that my Dell laptop is the problem for not being able to connect. I really dont know much about what they were saying but what they had...
If your using a router to get wireless from a DSL connection and your laptop isn't detecting the signal it is most commonly the wireless card in the computer, hence their response. If you can access the router to check what channel it is transmitting on you may be able to change that to resolve the issue. On my cisco router it transmitted on channel 6 by default and my laptops wouldn't detect it, I changed it to transmit on channel 5 and the laptops work fine. I assume they checked if your router was compatible with your computer so I won't go into the type G wireless vs Type B or N wireless. The uninstall/install process they recommended is not hard and shouldn't hurt anything if you do that. On Vista Open Control Panel->System->Device Manager then go down the list of devices to Network Devices and select your wireless adapter and right click, from that drop menu select uninstall and close everything and reboot the computer. When the computer starts up again it will automatically detect the wireless card and reinstall the drivers from the windows system copy. Make sure the wireless device is actually manually turned on before doing any of these steps. Once the device is installed again you should be able to detect the wireless signal from the router they supplied. If not there is one more place to look in the router itself unless you are familiar with router settings I don't recommend you do these though. If you still don't detect the router signal call your supplier back and have them go through the router connections with you and when they say it's your computer you can tell them it works fine with others and you removed and installed the device as they advised and the fault is in their router.
Sep 08, 2010 | Dell (430-3572) Wireless Adapter
Ethernet connection has just stopped working. 80072ee7 error. However, device manager says adapter working properly, orange green lights working/flashing. cable checked to another comptuer without...
Try going into the control panel and then into the device manager. Find the ethernet device and remove it. Then re-boot the computer and the OS should re-detect the card and re-install the drivers. Hopefully this will get the card working again. Let me know if this helps.
Nov 18, 2009 | SMC Realtek 10/100TX PCI Fast Ethernet...
Laptop does not detect wireless from Zyxel 660 router
Dear! You will have to enable wireless conection to access the router and internet. Check your adapter settings and enable wireless conection. Your problem will be solved.
Thanks
Jul 28, 2009 | Zyxel Prestige 660HW Wireless Router...
Dell D610 won't connect to US Robotics router
You will need to acsess the router do this ,start run type cmd in the command prompt andwhen it opens type ipconfig /all just like i typed it .you should see the router address copy the address close cmd .open your browser at the top line type the router address like this 192.168.2.1 then press enter the router config panel should open unless it has a password .in the encryption area add your laptop . if you want to see you computer when you run wireless scan uncheck the ssid box and it will show all connections ,but now everyone can see your router .It is best just to add your laptop to the router and hide the ssid when you are useing WEP
Mar 31, 2009 | Dell Latitude D610 Notebook
Linksys router when cabled, doesn't work wireless to laptop
can it detect the wireless signal?
did you load the drivers for wireless card in laptop?
check the device manager for any ! or ? in it those need attentio
if you can detect the wireless network then you need to set the wepkey if its enabled. if its not and you have a signal then just click on connect in the wireless network manager
Jan 22, 2009 | Linksys Wireless-G WRT54G Router
Intel PRO 2200BG will not detect any network
This IS the solution: Set it to use 802.11b _ONLY_ Do this in Windows: Start->Settings->Control Panel->System->Hardware->Device Manager->Network adapters->Intel(R) PRO/Wireless 2200BG Network Connection->Advanced->Wireless Mode = 802.11b only Driver version: 9.04.36 (04.04.2007) PROset/Wireless Software: not installed OS: Windows XP
Aug 15, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Linksys Wireless-G WRT54G Router Logo
60 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
