Question about Vizio VO320E LCD TV
I am using my Xbox 360 on my Vizio VO320E LCD TV. The colors are changed. The color red is no longer visible. I can see the colors blue and green, but green is the most overpowering color. I have adjusted the colors to make them all equal, but there is still more green. How do I make all of the colors show up again?
  • 34 Answers
SOURCE: color on vizio 37" lcd
I would recommend a Main board replacement.
Posted on Mar 05, 2008
  • 395 Answers
SOURCE: Vizio 32 inch now shows mostly only green and red colors
Please try to reset all setting and then to see if the problem is solved. 1. Press the Menu on your Remote Control;
2. choose Set up on the OSD;
3. then choose Reset All settings;
4. Press the Exit on your Remote Control to remove the OSD
Posted on Nov 30, 2008
phongnv
  • 56 Answers
SOURCE: Change in color, computer problem inside TV
For "thechances", The LVDS cable has gone bad. This cable connect between the mainboard and the panel. The replace the cable will fix the problem.
Posted on Feb 19, 2009
pumpkinman
  • 1144 Answers
SOURCE: Damn Vizio Red Areas
VIZIO seems to have problems with x-boxs and other gameing sytems ive seen many post about your same question.call them i would?
Posted on Jun 10, 2009
dtci80
  • 125 Answers
SOURCE: Vizio 32'' VO320E Image Distortion
I hope not but:
this is probably a failure from the screen or the electronic parts that control the videosignals.
i think having a specialist or the tecnical service from vizio taking a look at it will be best and safest.
Hope this is helpful, and greetings,
Olivier.
Posted on Oct 21, 2009
I have a daenyx lcd tv, model DN-15, input 12VDC-4A and am trying to hook it up to an xbox 360 console.
If you are using the Red/Yellow/White cable, that's composite cable, but if you're using the one that's Red/Yellow/White/Blue/Green, that's called component. So basically, you set your TV's input to the corresponding color match. 5 colors: Component, 3 colors: Composite.
Sep 13, 2014 | Video Game Consoles & Games
Color problems vizio lcd hdtv
If your tv has a custom settings area, first turn all color down on set so picture looks black and white. Now in color settings look for red blue and green color bars. Use the bars until the picture looks as true to black and white as possible. Also, try changing color temp.
Dec 21, 2013 | Vizio VW37L 37 in. LCD HDTV
Vizio screen problem. Please help!
The screen is ok Your T-Con board quit. You can get a new one from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 03, 2017 | Vizio VO320E LCD TV
CONNECTING XBOX 360 TO A LCD PANASONIC VIERA TV
You need to Connect via, the Component Video, the xables are Blue, Red, Green, ALL Video, and go color to color, from, Xbox to TV, and you Select EXTERNAL INPUT, on TV. OR You must use the Composite, Video, which is Yellow, for Video, again, cables go color to color. The Audio, as you have discovered, is Red & White. Now, if using HDMI, you do not usually need the Red 7 White audio, as it's all in the one signal, though the HDMI. Again, you select the relevant, INPUT On the TV, And also select the output on the Xbox, and you should be all OK.
Apr 30, 2010 | Microsoft Xbox 360 Console
Which wires doi use to connect up my xbox with my
In order to connect your Laptop with Xbox 360, you will have to use the ethernet cable that came along with the Xbox 360,
For connecting the Xbox 360 to TV you would be having a HD AV cable if you have a Xbox 360 Pro model, you would have to insert one part of this cable with 3 colored wires red,blue and green to your composite video port behind your tv with similar color coding, and on the Xbox 360 HD AV cable you have an option to choose either TV or HD video output based on your TV make, also this cable has two more wires red and white meant for audio connectivity which would go to audio port behind TV with same color code ports
If you have got a normal AV cable with Xbox 360 then it would be a a wire with one single yellow colored wire for video and two wires Red and White for audio
Nov 23, 2009 | Microsoft Xbox 360 Console
Green Tint On Xbox Monopoly Game
have you tested with another game?
maybe you are running a EURO game...the colors go crazy....it´s normal...try a usa version...
Dec 05, 2008 | Microsoft Xbox 360 Console
Vizio 37" LCD color problem!
is the TV still under warranty. if it is I would call Vizio and request a main board be switch and if it is not under warranty I would call a TV Repair shop and have them put in a Main Board.
Mar 04, 2008 | Televison & Video
A GREEN HUE!!!
U have to make sure your xbox 360 is set to the HD pixels as your tv.
Dec 13, 2007 | Microsoft Xbox 360 Console
Video probs
Which cable are you using? Are you using the component cable? Have you accidentally switched the red/green/blue somehow? Or may someone have played a trick on you, rearranging them?
Also check PAL/NTSC settings and capabilities on the 360 and your TV.
Nov 26, 2007 | Microsoft Xbox 360 Console
Vizio VO320E LCD TV Logo
106 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
