Question about Dell (E210882) Motherboard
No power. changed powersupply and replaced hard drive still no power
    President:
  • 2,653 Answers
Before swapping it out, I would try:
clearing the cmos, reseating the memory, checking the power switch (PS wire from the power button to the motherboard)
If you get no life then the board is bad and will have to be swapped out.
Posted on Nov 13, 2010
Dell gx-280 power button blink's on yellow
This sounds like a powersupply problem. The way to know for sure would be to hook a tester up to it.
If you do not have access to a powersupply tester you can use the trick here-.
Test
You can order new power supplies online, I would recommend newegg. When ordering a new power supply you have to make sure the wattage is equal to or more than existing, and that it has all the necessary connections for your motherboard and drives.
If you find the powersupply is fine, respond here and I can help you out.
Mar 17, 2010 | Dell Optiplex GX280 (99301) Motherboard
Tip
I must say that the diagnosis that you do on the first video that the USB...
Have a external Hard drive? Does not power on or the computer does not find it? Do these steps below for your fix.
Folks I am going to demonstrate to you how to save your data on your failed external usb hard drive.
The Videos below will show you how to retrieve the hard drive out of a My book 1TB drive. This method can be used for all external hard drives as there all basically SATA drives.
1. You need a flat head screw driver.
2. You take the drive in your hand and you pry it open around the sides and back there are no screws on this drive.
3. Once you got it open you basically follow the steps below in the video and what you can do is put this hard drive inside of another case or directly into the computer.
The videos are kinda dark but you can basically see and hear what I am doing here folks.
When you follow my video's here you will have a fix as long as the drive is not crashed. Opening the drive up VOIDS the warranty for the drive so please if you have a warranty and care less about the data sent it back to the manufacture.
I hope you find these video's helpful
gps, home theater systems, home theater, tv repair, computer repair, laptop, repair, computer, laptops, home, computers, desktop, pc, parts,printers,refills,printhead,plunger
on Dec 20, 2009 | Computers & Internet
Blinking green circle & burning odor
Check the powersupply the little black box in the middle of the power cord see if it smells ok if not then it has failed, just buy or find another powersupply with the same voltage and same or more amps than the other one and try it. if the smell is coming from the MY book itself then it's probly the Drive in whick case it needs to be replaced.
Feb 24, 2010 | Western Digital My Book Essential Edition...
Emachine t2882: not powering up just an amber light. replaced power supply, still just an amber light. power supply fan runs, but cpu fan does not. reseated all connections. plugged in drives one by one,...
Hello there:
ok unplug everything from the board first and power up and see what happnes. if nothing still unplug the powersupply to the motherboard and press in the power button and hold it in for 1 min and than plug in the powersupply to the motherboard and see what happnes. Also doublecheck the jumper for the cmos. ok please keep me informed there is a lot more that we can do but lets try this first ok best regards mike
Aug 16, 2009 | Computers & Internet
840GM will not start up all the way
Here is my flow chart.
So basically you cannot get the pc to POST. Meaning you have just a black screen when you power on the pc, right?
First off, did you attempt to update BIOS before this happened. 90% of the time this is caused by a corrupt bios.
If you are the victim of a bad BIOS flash, don't freak there are some options. First off, if the computer (or motherboard) is still under warranty the Computer (or motherboard) can be sent to the Vendor for a BIOS reprogramming.
If you are a DIY PC builder and the warranty is expired you can take out the bios chip and sent it someone who reprograms BIOS chips or you can buy a brand new chip form them. I will show you my people.
http://myworld.ebay.com/***angelb***
or
http://stores.shop.ebay.com/Bios-Depot__W0QQ_armrsZ1
For non-BIOS issues:
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button (this discharges any residual power in the capacitors).
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots. Try one stick at a time to see if you can get the PC to boot. If this works, then the remaining ram sticks are damaged.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker (20-25 dollars at local PC shop), get the supply tested at a PC shop (usually a free service), put the powersupply in a different pc, or try a different powersupply in the problem computer.
If the Powersupply checks out ok, then you will have to do a process of elimination to find out what part or parts are the culprit of the No-Boot.
Start by pulling all the ram sticks if you have not already. This is the easiest components to check and usually a culprit.
If it is not the RAM, you have to continue removing items such as sound cards, un-plugging hard drives and optical drives, other PCI cards. Do this one at a time until you find the culprit. If a POST screen, meaning you can see Anything from the PC brand name to Motherboard brand name appearing on the screen.
Jul 08, 2009 | Gateway 840GM (RB840GM) PC Desktop
Errore codeoxe0000227
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button.
Try to boot the pc.
6. Check the powersupply function. Either by a powersupply voltage checker, put the powersupply in a different pc, or try a different powersupply in the problem computer.
Could be bad ram, motherboard, cpu, powersupply, videocard.
Jul 06, 2009 | ASUS P5P800-MX Motherboard
Flashing orange light on front of my dell 5150 desktop, will not turn on, even after unplugging for one hour. when plugged back in, flashes orange, no fan, no power. JK
Try to boot the pc.
Jul 05, 2009 | Dell Computers & Internet
Dell 4400 won't power up Flea light works
If it is not the RAM, you have to continue removing items such as sound cards, un-plugging hard drives and optical drives, other PCI cards. Do this one at a time until you find the culprit. If a POST screen, meaning you can see Anything from the PC brand name to Motherboard brand name appearing on the screen. The PC may not boot to windows, but it Does post at this point, and with that the problem is resolved. If windows does not load, then you have a new problem. Best dealt with asking a new question.
Brian
Jun 28, 2009 | Dell Dimension 4400 Power Supply ** FREE...
I HAVE A COMPUTER WITH CONFIGURATION OF INTEL EXTREME DP45SG MOTHERBOARD,QUAD CORE 6600 PROCESSOR,NVIDIA GRAPHIC CARD,DDR3 RAM(1333 HZ),500GB HDD(SEAGATE) and still my compuer screen shows NO DISPLAY...
Try to boot the pc.
Ok try all this first...
Feb 27, 2009 | Dell Dimension 4600 PC Desktop
I have asus motherbaord PTGD1-LA
How long have you been experiencing this problem? Are you sure your hard drive has not been formated? Check inside the case to make sure all power plugs are fastened securely to the motherboard and peripherals.
Apr 11, 2008 | Intel Motherboard
Dell (E210882) Motherboard Logo
37 people viewed this question
Alun Cox
