Question about Peg Perego John Deere Gator HPX Ride on Toy
Will not run or move. have changed battery, checked all connections
    Sniper:
  • 70 Answers
No, just the shifter. Just to check you can exchange the red and blue wires under the pedal(just for a second or so, do not do this permanently) to see if you get power to the wheels, if so then yes it is Definitely only the shifter, but I am still pretty sure it is just the shifter. you can also call Peg Perego Tech support which is excellent and they can help you too 1800-728-2108 and parts can be priced and found at www.mypegperegoparts.com
Posted on Mar 02, 2011
Changed battery and now start 2005 landrover
Well, lets start with do you know the new battery is any good? If you are certain it is fully charged try the following.
Check for correct polarity.of your new battery
Ensure that your battery connections are tightly done up. If you can move them by hand using considerable force they are no good and need to be tightened
Check the connections on the other ends of the battery leads are tight.
Check the condition of the battery leads. They must not be worn or frayed..
Feb 02, 2015 | Cars & Trucks
Despite wiring speakers correctly they remain out of phase. I know that reversing the connections resolves this problem but it has caused problems when playing 4 speakers simultaneously i.e., I need to...
I have no idea how you determined they are out of phase. Normally if you change all of them the result is the same. Just change the one (swap the speaker leads) that is out of phase.
First assume they marked on the amplifier typically red and black connections. Then check the speakers to see if they are also marked the same way, if so match the colors.
If they are not marked you need to be able to see the cone, that use to be easy. Use a battery and connect it across the speaker leads, I use a flash light 1.5 volt battery. You may have to go to a 9v but try the 1.5 first. When you connect the battery the speaker cone will either move forward or reverse. If the cone moves in reverse when connected swap wires. When the cone moves forward just mark with the plus (red) coinciding with the battery.
Nov 28, 2014 | Audio Players & Recorders
2007 is250 won't start. It is not a battery problem.
Sounds like you have a lose connection somewhere, your getting enough juice to run everything but not a strong enough connection to start the car. Try working your way from battery and follow the cables they will lead you towards fuse box, main ground, and starter.
I recommend you starting with one cable and wiggle at battery check to see if it makes a difference, move down same cable to next connection point wiggle there and look for damage or corrosion, see if it makes a difference and so on.
More then likely the issue between battery connection and fuse box based on your experience. So i would focus there checking cleaning or repairing as ness. Remember also most fuse boxs have connections under which may require you to remove a few small fasteners and looking under the fuse panel but following the wires will lead you to all of them.
Jan 27, 2014 | Cars & Trucks
Changed battery in 2001 vw tdi jetta and now it will not crank
check for good clean and tight connections at battery,di it start fine before battery went dead is battery good have it checked ,then look at other possibles starter is it in park move the shifter around sometimes the neutral safety switch acts up ,check fuse for ign fuse blown
Dec 11, 2013 | Volkswagen Cars & Trucks
Tempeture hand on gauge rises and falls as you accelerate and slow down. Also rises and falls when you turn on the internal blower in the car. The engine does not appear to be overheating.
The problem you describe is likely being caused by the dashboard earth (ground) reference moving as the 12v power system current draw changes.
Ensure battery terminal post connections are in good order, clean and firmly connected,
Ensure the all chassis, alternator, engine and dashboard ground connections are intact and in good order.
Ensure all dashboard loom connections are properly connected,
Check alternator output voltage (battery terminal voltage) is approx 14.5 volts with engine running, while loaded with headlights or blower motor running.
If all above is ok, the dashboard internal voltage regulator supplying the instruments may be faulty (unlikely - do all other checks first).
Oct 13, 2009 | Hyundai Santa Fe Cars & Trucks
At times the battery connection does work and the
well you need to clean the battery connection an reinstall it so it doesnt move,as for it running bad for 10-15 minutes,it because whenever you lose battery power on a chrysler product it resets all adaptives in the computer and it will eventually relearn after running for a while,so if you fix the battery problem that should be the end of it,hope this helps
Sep 24, 2009 | 2003 Jeep Grand Cherokee
1989 Ford F250 pickup- amp meter reads backwards
If you had a dead short when connecting the neg. battery cable, the battery was being installed backwards or you had grounded the alternator + lead somhow.
I suspect whnen you installed the battery, you have burnt all of the diodes out in the alternator and the AMP meter is showing no charge. The AMP meter also could have taken a beating in the reversal.
Check the battery in in correctly first. If not reinstall or get the correct battery. Then check the battery voltage with the engine running. If less then 13.2. Replace the alternator again.
Good Luck
Mar 16, 2009 | 1989 Ford F 250
Problem with fuse or something
loose connections.. possible at the battery or starter or back of alternator. check and clean connections at battery. move wire harness in or around fuse block while engine is running. Does moving wires recreate the problem? check connection at starter motor. check for corosion. remove negative cable from engine and clean good.
Jan 31, 2009 | 2003 Ford Focus
2000 Stratus won't start after battery change
Which wire did you hook up first? If you hooked up red wire first you may have took out the PCM/BCM The theft light may be flashing or on, check owners manual or call dealer to find out specific's. But check connections make sure they are tight and do not move, check battery voltage.
Dec 30, 2008 | 2000 Dodge Stratus
Peg Perego John Deere Gator HPX Ride on Toy Logo
71 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
