My electric heater is on off why is there warm air coming from the furnace is this normal
  • 8,220 Answers
That is not normal. It is normal for the sequencer to shut down in an orderly manor however. The heating needs being met the the power is shut down to the sequencer and it shuts down when the bi-metal inside it cools down. If all of the coils and fan were energized the load would be too much so the heating coils are powered up in stages. That does 2 things. Keeps from tripping the breaker and ensures warm air comes out the vents when the fan comes on. You may have a problem with a sticky sequencer.
Posted on Nov 13, 2010
Electric furnace will not turn off
Your sequencer is stuck. A sequencer uses a small coil to warm up the switch so that it will turn the electrical elements on one at a time instead of all at once. If they all come on at once the amp draw would throw the breaker. It is also desired to have warm air come out of the vents when the fan comes on. So how do they do it? With a sequencer:
A sequencer can have up to 4 stacks depending on the amount of coils are in the heater. Each coil on average has a value of 5000 watts. So what ya want to do is turn on a coil then after 30 seconds another coil then after 30 more seconds the fan and maybe another coil depending on your furnace size.
So in your case what is wrong? The sequencer bimetal disc inside it is jammed in the on position and therefore the heater stays on until you tun the breaker off. Replace the sequencer and party on!
Here is a page on sequencers that also features rewiring of an electric furnace
Oct 28, 2011 | Heating & Cooling
Furnace is blowing cold air.
You must have an electric furnace, gas furnaces only come on when the heater is warm. Electric heaters come on with the use of a sequencer. Your sequencer, tstat, and blower is fine, which means you must have broken heating element. I have a nice pictoral of how to restring one HERE
Feb 21, 2011 | Carrier Heating & Cooling
My friend's Colman Furnace Model number DGAA90BDTA, runs and lights but doesn't get warm enough? It's a gas furnace with an electric igniter. Any help is appreciated.
check air filter is clean and all floor vents are open and not blocked see what room stat is set at this could not be working at the temp you need , furnace might need servicing
Nov 27, 2010 | Coleman Heating & Cooling
My heater is not heating anymore, what's the
Sounds like an ole electric furnace with heating elements not kicking in or burnt wire to the controllers..
Dec 17, 2009 | Heating & Cooling
The Pilot on my electric furnace will not stay lit, blowing cold air instead of warm. The model is L8T-UH.
Is this a code for us to come over cause electric furnaces dont use a pilot light ha! Ha! (they uses electric heat strips for heat .....but if you want to give away money..........)
Dec 09, 2009 | Coleman Mach 15 Air Conditioner
Electric furness blows hot then warm
if this has happened since you got hte furnace it is normal
heres how a heter works
themostte tells heater to turn on
heating element turns on
followed in about a minute by the blower
during the peried before the blower kiks on the elements become supper heated
after the blower kicks on it slowly leves off the element temp and air temp coming out
Jan 23, 2009 | Hunter Fan Company 5/1/1 Programmable...
Short cycling..continually..minimal heat
Is this furnace standing pilot or electronic? if standing pilot turn power off then take t-stat off wall and connect the wires labeled r and c together and see if that keeps furnace working. If electronic check flame sensor you can check flame sensor buy cleaning with steel wool. if that doesn't work then try t-sat.
Jan 21, 2009 | Coleman Propane Forced Air Heater...
Electric furnace blows cold air before and after warm air.
It is normal. Your house has to go down a couple more degrees because the heat pump is not working. You can solve this by rewirng you thermostat. Take off the wire that goes to Y and tape off. Then take the wires that are marked w and e or w1 and put the wires to yellow. Do not run ac with it wired like this. If you need more information please post me back
Nov 29, 2008 | Heating & Cooling
My air condition heater
Auto and on only controls your blower inside the home. More info is needed to determine if you have a gas furnace, electric furnace or a heat pump system.
Nov 08, 2007 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
