Question about Frigidaire Dryers
My dryer is not drying and/or spinning - Frigidaire Dryers
  • 1,531 Answers
There could be a couple of thingsthat would cause this,,,,,One a bad door Switch.2 bad start switch.3 a bad thermal fuse.open the door and hold the door switch in by hand have someone press or turn the start button while you try and turn the drum by hand.If it starts then you may have bad contacts in the motor and needs to be cleaned out.
Posted on Nov 13, 2010
Hi i have samsung dryer it work fine but it doesn't dry sheets and blanket verry well??
This can be because blankets and sheets tend to absorb more water and do not dry well in a spin dryer. Check that your spin cycle on the washer is putting out enough spin to centripetal dry your blankets and sheets.
Feb 01, 2015 | Samsung Dryers
How to fix dryer that will spin but not dry
STOPS MID CYCLE AS IF AROUND 20-30 MINUTES? IF SO U MAY HAVE BAD MOTOR WINDINGS? OH OH, CAN CHECK HEATING ELEMENT AND THERMOSTAS WITH A MULTIMETER FIRST
May 12, 2014 | Frigidaire AGQ6700F / AGQ6700FE Gas Dryer
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Oct 01, 2010 | Whirlpool Dryers
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Aug 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Dryer that is getting warm, but the drying power is missing. I am trying to dry towels, socks and t-shirts that are on their 4th spin and the items are still not dry
check your wattage on back,then do load check with amp meter,verify that all of elements are working-watts=voltsxamps,a link may be burnt at elements or element has failed,hope this helps
May 08, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer heats and spins but doesn't dry. Perhaps the blower?
Remove the rear connecting vent and try it. If it dries then, repair the vent blockage.
It not, report back as to what does happens.
Model number too.
Apr 15, 2009 | Dryers
Spin cycle lasts indefinately
the spin cylce in washer, did not shut off?soundslike an issue with the timer itself, no servicing htetimer strictly replace, as far as teh time in the dryer, i would check for clogged/kinked dryer vent, biggest issue with any dryer, innadequate vent
Nov 25, 2008 | Kenmore 98702 Stacked Washer/Dryer
Only spin dry available?????
Yes, turn on the machine, push the button for spin to select the speed and then press start.
Apr 26, 2008 | LG WD-12126RD Front Load Washer / Dryer
Dryers Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
