Question about Sharp LC-19SB24U 19 in. HDTV LCD
Someone entered a pass code on my Sharp Tv just before I moved, now it is hooked up to a working comcast cable but still no broadcast and the pass code pops up to go any further
  • Sharp Master
  • 736 Answers
To reset this television turn it off but leave it plugged in. On the side buttons of the television not on the remote control hold down the input and vol - button. Keep them held down and press and release the power button to turn the television on. Keep holding down input and vol - until a K appears on the screen. Then release the buttons and press down channel + and vol +. When the U appears on the screen let them go. The television will say setting complete. Do not turn off the television. Unplug the television for one minute. Plug it back in and you will be prompted to complete the first time setup as if the television had been unboxed for the first time.
Posted on Nov 14, 2010
Not detecting devices
test this steps and fix it. God bless you
    • 1
      Check the back of your Sharp TV for the HDMI input. These will be long, thin rectangular jacks labeled "HDMI." Most Sharp TVs will include another label on those jacks with an input number ("Input 5," "Input 6" or the like). Remember that number. It will have a bearing when you turn on the TV.
    • 2
      Connect one end of an HDMI cable to the input jack on the Sharp TV and the other end to a compatible component such as an HD DVR from your cable/satellite company or a Blu-Ray disc player. The TV won't broadcast in HD if you can't connect these devices with an HDMI cable (though it will still broadcast in standard definition using RCA cables or S-video cables).
    • Sponsored Links
    • 3
      Turn on the TV and the requisite component (Blu-Ray, DVR).
    • 4
      Press the "Input" button on your remote. A list of signal sources will appear on your screen ("Input 1," Input 2," etc.). Use the cursor to maneuver down to the input number corresponding to the HDMI outlet you just hooked up and press the "Input" button again.
    • 5
      Press the "Menu" button and maneuver the cursor to select "Option." Go to "HDMI Setup" and press "Enter." Move the cursor up or down to the desired item and hit "Enter" again. Then move the cursor from side-to-side to select the proper setting. Hit "Enable" to allow the Sharp TV to automatically recognize the HDMI signal and "Digital" to get the proper audio signal from the HDMI cable. Then hit "Enter" again.
    • 6
      Exit the menu and watch TV as normal.
Read more: http://www.ehow.com/how_4840499_turn-hdmi-input-sharp-tv.html#ixzz2a6Xat0JU
Jul 25, 2013 | Seagate 1TB GoFlex Cinema Multimedia Drive...
Tried to use roof antenna on RV. My Sharp hdtv by passes the digital setup. How do I receive the over the air digital signal
Used the tv remote.Push the menu button.Now u are tv menu.Goto SETUP,go down to CH SETUP push enter on the tv remote.Pick AIR not Cable and push enter on the remote again.Now tv go in auto scanning.After it is done searching all cannels,ur tv will get all the free DTV air broadcasting channels.
Apr 17, 2011 | Sharp AQUOS LC-32GP1U 32 in. LCD HDTV
Tried to connect Sharp 19" LCD TV (purchased on 2008) up to new Comcast Digital TV Adapter. Screen sez "Failed to receive broadcast". The DTA works on other TVs. Is it the TV settings that need to be...
I had the same problem when I got one of these a few months back. Once get it all hooked up give comcast a call at: 1-800-266-2278(or 1800comcast) they will have to update some codes and reset it to get it up and running.
Should take less than 5 min's once you get a rep. on the phone.
If you need any further help give me message in the comments
Mar 18, 2010 | Sharp 19 in. LCD HDTV
Whenever I have an outage or disconnect the tv, guide plus needs to be downloaded again. How do I eliminate that problem of guide plus? I now have a cable box from Comcast that connects from cable from...
Sharp TV, Guide Plus Download problem
Solved by using Sharp TV Remote: Set Up, Guide Plus, Enter 00000 (zip code),
No more Guide Plus downloading!
Jan 02, 2010 | Sharp 36K-X2000 TV
How do i hook up my comcast remote to my sharp aquos lc-32gp1u
Hi there, you should be able to use that universal remote code list located here. Simply locate the the manufacturer, follow the instructions, and you're all set! Please let me know if this does not work, I'd be happy to further assist.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Best,
Detreon Roberts
Comcast National Customer Operations
We_Can_help@cable.comcast.com
Oct 28, 2009 | Sharp Televison & Video
Can't change channels expect by inputing numbers
Try to reload the the remote by using the universal remote code for comcast cable.This number should be available in your owners manual or on the Sharp website. You should search the websites frequently asked questions and troubleshooting sections for you model of television to see if someone already has had the problem answered. If all this fails you must contact the customer service for both the remote and television and get help. Hope this helps you with your problem.
Apr 08, 2009 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Comcast Universal Remote code for Sylvania LC370SL8
10030 or 10054
  1. Turn on your device (i.e. TV).
  2. PRESS the button for the device you want to program (TV, VCR, CABLE, AUD, etc.) then RELEASE.
  3. PRESS and HOLD the SETUP button until the red LED for the selected device flashes twice, then RELEASE.
  4. ENTER the 5 digit code for your brand from the list above.
  5. You should receive 2 quick flashes on the LED for the selected device after entering your code.
  6. PRESS the POWER button to test the code. (On VCR,LD,and CD players use PLAY)
Dec 04, 2008 | Sylvania LC320SS8 32 in. LCD Television
Sharp TV (LC52D64U) remote control Comcast cable (DVR) box ?
I had the same problem with my remote. I would enter the code and there would be no response from the remote. I looked up the manual for the other comcast remote and the codes are 5 digits instead of 4. Try codes 10093 or 11602. The reason why there is no response from your remote is because it is waiting for you to enter the last digit of the code. Hope this helps.
Dec 01, 2008 | Sharp Remote Control
Programming the Acquos Remote
There is a code out there to try.  The code would be 47.  Just follow the steps in your manual on how to program this box and you should be able to go from there. Can't garantee that it will work as that code came out with the newer tv but it should work.
Nov 08, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Comcast remote code for 42in sharp aquos lcd
the 10093 code worked perfectly!!! YOU ROCK! the codes in the comcast manual dont work. i don't have an aqquos, but a regular sharp hdtv... purchased in nov '07
Dec 14, 2007 | Televison & Video
Sharp LC-19SB24U 19 in. HDTV LCD Logo
129 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
