Question about GE Security Simon 3 Wireless Home Security System
I am just wondering if its posible to extend the range of the simon alarm panel? I have connected the internal ariel to another cable to extend the range, this worked but not to the level i require. Is there a wirefree expander i can learn into system and increase the range?
  • GE Master
  • 8,457 Answers
No.Not possible this thing only work for a quarter of a mile ok for the best operation.It is preset for the range for it best functions,u manage to extented for a littte further.No,the range will not go further beyond a quarter of a mile,if u plan to go beyond that.
Posted on Nov 13, 2010
Connect KARPRWL11NA
First off, have you connected your pc/laptop to the SSID called WiFi repeater? If not, do that first and then try browsing to http://192.168.10.1
Failing that and assuming you have a DHCP service running in your network, you could try checking the leases to see if your range extender has received a dynamic IP address. If it has, try browsing to that IP instead of the default 192.168.10.1.
Another option would be to use the cabled connection (assuming you're not already doing so) by connection your pc/laptop to the range extender using a UTP cable.
Jul 03, 2014 | Zyxel Prestige P-330W Wireless Router...
SIMON 3 panel acknowledge code?
Check and make sure they did not put a secondary number in Option 5. also I would delete the account# in Option 7.
AlarmProfessor.net
May 05, 2010 | GE Security Simon 3 Wireless Home Security...
I can get the cell back up to work on my simon 3
The vell module is not like a cell phone. It is specifically set up to go to the alarm.com network. You need to have an alarm company involved. Alarm.com can send you e-mail or tect messages if you have a smartphone, but you are going to be about $25-$30 per month to get that service.
Alarmprofessor.net
Mar 05, 2010 | GE Security Simon 3 Wireless Home Security...
Extend the range of my N1 router - how?
I have 2 x Belkin N1 vision dsl (cable) routers. One is connected fine with Virgin 20 meg broadband. Is it possible to use the other N1 vision router as a range extender up stairs to get better signal , without using any cat5 cabling ? I.e router-to-router
Aug 04, 2009 | Belkin N1 Vision Wireless Router
How do I turn system beeps off for sirens
My problem started when the electricity went off so now everytime I open the door the siren goes off. I don't have a manual so how can I get this to turn off.
Jun 18, 2009 | GE Security Simon 3 Wireless Home Security...
Sound
First I would check the cable from the ariel to the tv and all connections in between.
May 15, 2008 | Samsung LW26A33W 26 in. HD-Ready LCD...
Installation of vt holden commodore aerial rope and mast
You access the ariel via the left hand wheel arch.
1. Remove left wheel mud guard. It is held in with a bunch of press studs which can be difficult to remove. I found pulling on the plastic mud guard whilst turning the screw helped.
2. unbolt the electric ariel assembly. There is an earth strap that needs to be unscrewed as well.
You should be able to get the ariel out far enough to work on it.
3. Remove chrome plated nut to top end of mast tube.
4. With great anger and force, remove the dead ariel and drive cable from the mast.
It's difficult to get the mast to work unless it's earthed properly.
5. Get you hand inside the wall and remove the ariel face plate. Swear if you have to.
6. Put the ariel mast assembly back into the wall and hook it all up minus the new ariel.
7. Switch your radio on, then put the new ariel into the mast. Gears facing the rear of the car. Switch the radio off, it should retract. If not you may need to push it in a little further.
8. Remove the ariel mast again and slip the chrome nut to top end of mast tube and tighten securely.
9. Ask the spouse to close up whilst you have a beer.
Apr 03, 2008 | Car Audio & Video
Using DTIM with digital phone service
It turns out that because Comcast uses VoIP, the Simon can't use it to call in reports. I ended up having to switch monitoring companies to one that specifically uses internet monitoring. The solution was to buy/install a wireless g bridge into the phone output on the alarm panel, and then connect it (wirelessly) to my home network. No major problems since then.
Sep 08, 2007 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
78 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
