Question about Dishwashers
I have an older Bosch dishwasher I just hooked up in my condo. WHen a cycle is done there is no water is located at the bottom of the inside of the dishwasher, yet 2 days later water will drip on the floor (with the dishwasher door closed) and I'll open the dishwasher door and therewill be 2" of water at the bottom. The flexible water discharge hole located in the sink base is located at the top of the base cabinet, and the hose runs completly 100% downward from that hole to the garbage disposal. What have I done wrong?
    President:
  • 1,462 Answers
When you empty you sink, some of the water is going down the drain hose of the dishwasher. take the drain hose up as far as possible in a swan neck
Posted on Jun 19, 2008
I have A bosh SKT 2052 Will not fill up to start the cycle
see the following causes:
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher) see diagram
2) faulty float switch, test for open or faulty.
see the diagram attached.
God bless you
Jul 11, 2012 | Bosch 22 in. SKT5102 Free-Standing...
My Bosch dishwasher is taking hours (at least 3 - maybe more) to complete a cycle. There is gummy, yucky stuff building up inside - sorta pinkish brownish. Could the water not be hot enough? A couple of...
if your on demand heater is one of the small ones that mounts under the sink, it will not flow enough water to fill your dishwasher. the dishwasher is waiting for the water level to fill before it starts washing. your bosch will heat its own water. hook it up to a cold line ahead of the water heater so that the fill valve is fed with full pressure. the residue sounds like detergent build up. when you get the water issue resolved, run a few cycles with no dishes and no detergent, on the highest temp setting. add a cup or two of white vinegar or dishwasher cleaner ( order online or get from an appliance repair store) through it. Dont forget your dishwasher has a filter in the bottom under the spray arm that needs to be cleaned periodically. if you dont clean it once a month it will get all kinds of nasty stuff built up in there.
Nov 20, 2010 | Bosch SHX46A07UC Built-in Dishwasher
Dishwasher signals "clean" inside five minutes
I would check tosee if your water meaning hot water temp is hook up correctly. i have seen cold water going to machine and causing the machine to do funny things. 1 the unit drains.2. it fills.3.it washes if the water is cold there is your problem .make sure b4 you start machine the water going in is hot. let me know how you made out maybe we can further check. p.s im a old bosch tech:)
Jan 26, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
Does not clean like it did soap dispences goes through the cycles does not seem to have the pressure
Hello there"
Please go thru this list that i have provided for you and check each item ok
It doesn't get the dishes clean dot_lineone.gif 1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, we recommend Dishwasher Magic®.
Jan 12, 2010 | Bosch SHU3306UC Built-in Dishwasher
DISHWASHER RUNS BUT I HAVE NO WATER INSIDE.
There are two possible options to solve this.
1. Check clogged filters on water ingress pipe. You should have two, one on either end if using factory pipe.
2. Alternatively the water solenoid valve is faulty and needs replacement. Check signal on solenoid valve and try testing the solenoid valve on its own by applying a voltage at its terminals to see whether it opens before you replace it.
Aug 28, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Water does not fill dishwasher
Aug 03, 2009 | Bosch 24 in. SHI43 Built-in Dishwasher
Bosch SHU 5302 Machine doesn,t fill with water.
Jun 16, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch dishwasher does not let water in
Jun 04, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Dishwasher wont fill.
Sep 29, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Not cleaning dishes
sounds like you are not getting enough or any water a check the water level when it fills... let me know
Apr 05, 2008 | Bosch 23 in. SHU33A Built-In Dishwasher
Dishwashers Logo
81 people viewed this question
Top Dishwashers Experts
