Question about LG LWHD1800R Wall/Window Air Conditioner
Doesn't Cool Entire Room/Space - also very noisy
We actually have an LWHD8000R
The space is no more than 25' x 9' and we cannot get it cool to save our lives
We have followed the manual to the letter
you can't feel the cold air unless you are literally right next to the vent and the room is not cool at all ever!
For some reason only at night it makes this awful clicking and buzzing sound & has to be turned off to rest
Anything we can do?
    Novelist:
    Champion:
  • 230 Answers
It sounds like it is cooling a little bit. So I will suggest to you that it may be low on refrigerant. I assume that you have cleaned the filter because you followed the manuals instructions.
The clicking and buzzing sounds may be that the compressor is pulling high amps and failing. Otherwise I have heard similar noises when a capacitor fails. You will probably need a technician to make the repairs.
Posted on Jun 18, 2008
What is the difference between a ducted and non ducted Domestic Air Conditioner?
Ducted A/C has an internal fancoil unit installed in the roof space of the home. From this central location, a series of ducts run from it and into as many rooms in the house as the owner desires. From these ducts, this allows you to cool or heat each room individually – called zoning
Split systems stand out for their relatively low initial purchase price. Another perk is that the installation is not so invasive – it can often be done in a day or less from a licensed technician. Though, being that the unit is fairly small, it is best suited to cooling or heating one room – this is either a positive or negative depending on how you look at it. On one hand, it’s an efficient option if you only need to cool or heat one room, but on the other hand they are less effective in larger spaces. Rarely could a split system air conditioner cool or heat an entire home. Split system air cons are great options for small areas, but lack the power to affect larger spaces – this is reflected in their relatively cheap purchase price, from around $1,000-$2,000.
Aug 05, 2017 | Heating & Cooling
Danby 12,000 BTU Portable Air Conditioner - Doesn't Cool Enough
put a xtra fan on you to blow the cooler air around. this might help. but i think you will find it is to small to cool what your trying to cool. good luck and good day
saw
Jul 09, 2009 | Danby Portable Air Conditioner
Can I purchase a new remote for an unidentified heater?
Heaters : Target
www.target.com/c/heaters-home.../-/N-5xtuk
Target Corporationheaters buying guide > ... (125) reviews for Lasko Tower Heater with Electric Control ..... (23) reviews for Lasko Digital Ceramic Tower Heater with Remote.
Lifesmart Meduim Room Infrared Heater w/Remote - Space ...
www.amazon.com > ... > Space Heaters
Amazon.com, Inc.Amazon.com - Lifesmart Meduim Room Infrared Heater w/Remote - Space Heaters. ... This compact heater also includes a new larger remote control to operate the ... the best heater I have ever owned for my purposes and would definitely buy ...
Heaters - Overstock Shopping - The Best Prices Online
www.overstock.com/Home-Garden/Heaters/.../subcat.html
Overstock.comBuying Electric Heaters: Tower heaters: Tower heaters are ideal for many homes .... Lifesmart Slimline Compact Infrared Heater with Remote Today: $102.99 4.4 (10 .... Dyson AM09 White Hot + Cool Fan (New) Today: $449.00 $499.99 Save: ...
Jan 27, 2016 | Heating & Cooling
I cannot get my temp down to 58 but stays at 68
What is the BTU rating of the unit and what size space are you trying to cool down? Air conditioners move heat from one area to another. Possible reasons for not achieving the temperature you want are 1) the air conditioner you are using is too small to cool the size room you have or 2) the space where you are trying to exhaust the hot air from the air conditioner is too hot to allow your air conditioner to move enough heat out of the room you are trying to cool.
Mar 19, 2015 | Heating & Cooling
Not cooling room
Assuming the unit is 'cooling' but not cooling it 'well,' I would think the unit is too small.
NOTE: 2000 Btu for every 100 sq ft of cooling space if the room is well insulated. If not - then 2000 btu for every 66 sq ft.
For example - a 12000 btu AC unit should cool 600 sq feet of cooling space if well insulated.
or
400 sq feet if not well insulated.
hope this has helped.
Aug 05, 2011 | Danby DPAC12031 Air Conditioner
Clockwise, counterclockwise which is the summer setting?
Ceiling Fan Direction These recommendations depend actually on the height and size of the room; the season; and the activity taking place in the room.
The basic fact of nature is that warm air rises to the top and cold air settles on the bottom. Air settles in layers from warm at the top to cold at the bottom, if left alone at equilibrium.
Ceiling fan recommendations:
In the winter
Set the fan to run counterclockwise (reverse; this looks clockwise as you are looking up). This will redirect the warm air from the ceiling and down the walls and into the living space where the people actually are. In a house, you would run the fan at a low speed so that you don't actually cool the warm air that you are moving downward. If you have a high ceiling, or are trying to heat a hall or a church, you may want to increase the fan speed so that the warm air will reach the living space as long as the fan speed does not create an unwanted downdraft at the people below. In the summer
In a room of normal height (8 - 10 ft), you should operate your fan so that it turns clockwise (this looks counterclockwise as you are looking up), causing a more directed downdraft, especially with the fan running slightly faster. This causes a wind-chill effect because the skin evaporates slight amounts of water from the sweat glands and thereby provides cooling through the skin's surface. However, the air is only moved but not cooled! You may find that you can turn your thermostat down a degree or two and save more money on energy costs. The air blowing down won't actually cool the room though, so you should turn the fan off when there are no people (or animals) in the room. In a high hall or church
It may be best NOT to run the fans at all in summer. This lowers the demand for cooling since the hot layer on top is an excellent insulation between the cool air near the floor (and the people) and the hot roof and outside.
A large, tall manufacturing hall would typically have different goals. There one would have a floor full of heat producing machinery plus the people operating it, working hard and welcoming a bit of a breeze. Then it would make sense to run the fans at fairly high speed to create a certain and directed downdraft. And with the shifts going throughout the days of the week, the fans should be running all the time and maybe in all seasons.
Finally, fans typically use 80-100 watts. When used properly, ceiling fans can really help to optimize the comfort level of the people and save energy and money.
Good Luck and please rate 4 thumbs up for the free answer
Jun 13, 2010 | Hampton Bay 13087 70450 Carousel II...
How much horsepower of aircon do i need for 20sq m space of area?
IIT DEPEND ON HOW MUCH COOL DO YOU LIKE 5,000 B.T.U. WILL COOL A SMALL ROOM BUT AN 8,000 WILL KEEP IT COOL.
Nov 26, 2009 | Samsung Heating & Cooling
Our air conditoner is throwing out cold air but the room is very hot the fan is blowing out cold air too it is not cooling the room down.
sounds like it does not have enough BTUs
so many BTUs can cool somany cu-feet if sealed space
Like leaving the freezer door open too seal that room
Jul 31, 2009 | DeLonghi Pinguino PAC-290 Air Conditioner
Rheem Criterion II air conditioner runs but it does not cool
Check air temp out vent should be approx 20 degrees colder than room temp if it is your unit is too small for the amount of space you are cooling.Rule of thumb 1 ton(12,000btu's) for every 400 sq ft of uninsulated space
May 30, 2009 | Amana Comfort Zone 12M32PBEH Air...
Adding More Kb Space
You would actually need a motorola modding program (i can't list the name for you), it will allow you into the sub sub directories and hidden drives.
we do offer the service if you would like - it is $25 + shipping, and for extra $15 we can "ultimate" your razr - make ringtones louder, put customized DRMs, and some cool stuff - for a complete list email vasco - sales@http://horizonwirelessonline.com
Jan 22, 2008 | Motorola Mobility RAZR V3
Heating & Cooling Logo
258 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
