Question about Kenmore Elite 45986 Front Load Washer
I have a Kenmore front load Washer (Model #48102) and I want to clean the filter, but I can't remove the trap door to gain access to the hose and filter. I can't see or feel any screw, what is the trick?
jsrock516
  • 5911 Answers
SOURCE: Kenmore 44072 Front Load Washer Drain Hose Cleaning
Try this link for step-by-step instructions. More than likely you will have to clean the drain pump as well.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If you are having trouble draining the water from the wash tub, and cannot get it to drain with a shop vac, you can drain it directly from the tub. If you don't own a shop vac, you may have to bail. If your drain pump does not have a clean out trap, remove the inlet and outlet hoses to access the inside of the drain pump. Inspect the pump impeller for obstructions and/or damage. If the water will not drain when you try to pull a vacuum on the drain line, you may have to disconnect the drain hose from the bottom of the wash tub. In some front loaders, there is a ball valve in the drain hose from the bottom of the wash tub to the drain pump. This ball can act as a collection pint from lint and debris. You will need to remove the hoses from the bottom of the wash tub to clean this area. I would recommend doing this as a LAST resort. Often, it can be difficult to reconnect this hose to the tub and get it to seal correctly. I hope this helps you. Please post back if you need further assistance.
Posted on May 28, 2008
jsrock516
  • 5911 Answers
SOURCE: Disassemble Washer
Here ya go. Follow the steps provided in this link:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
The mixing valve is also know as a "fill valve" or "water inlet valve", just for clarification. I hope these steps help you with completing your repairs. If you get confused along the way, or require additional assistance, please let me know.
Posted on Dec 22, 2008
  • 4 Answers
SOURCE: Kenmore Front loader Washer Problems
Hi, I got this exact Kenmore washer from Black Friday.  They finally installed last week and the vibrations were way out of control!  I looked around the machine and inspected the installation manual after spending hours leveling the thing and finally figured out that most likely cause is the foam shipping part at the bottom of the machine.  I called Sears to come back out since I have a pedestal screwed on the bottom, trapping the foam.  They came out and didn't think it was the issue.  I asked them to take it out anyway, and sure enough it worked.  For the first time my machine is working just the way it should...I wonder how many washers were installed this way?
Tip: To confirm that this is the problem, if you push down on the drum from the inside of the washer, you should be able to make the foam squeak...there's your problem!
Posted on Feb 08, 2009
  • 106 Answers
SOURCE: 48102 kenmore washer drains but more on floor than
You only have to look under where the hose might have come loose, refit. Check out your filter also.
Posted on Mar 01, 2009
SOURCE: kenmore front load he3 washer: door wont unlock
happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
Posted on Mar 02, 2009
Was washing a load when washer quit. all lights are flashing door is locked and the code of F - on the display.
The machine thinks it is flooded. Either your filter trap is clogges or the drain hose is clogged or your pressure switch is not working. Clean the drain line and filter trap and if still getting the fault then the pressure switch will be need to be checked out.
Sep 11, 2011 | Kenmore HE2 Plus Front Load Washer
Where is the filter on the machine
Unplug the washing machine and turn off the water.
Open the small trap door next to the drain hose connection on the back of the washer to gain access to the filter.
Take care.
Jan 11, 2011 | Hotpoint WMA48 Front Load Washer
Where are the filters located?
Good luck.
Jan 11, 2011 | Whirlpool AWM029 Front Load Washer
Where is the filter
Good luck.
Jan 11, 2011 | Hoover PE235 Front Load Washer
HOW DO I GET TO THE FILTER WHERE IS IT ?
Good luck
Is there a filter on a wma56 washing machine, if so where is it
The filter is located at the rear of the washer, to gain access to it, remove the lower rear panel of washer.
Remove large black hose from bottom of drum, and remove and clean plastic filter inside the hose.
Refit filter and hose, and test .
May 04, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
Kenmore front load won't drain
Try this, on the access panel below the door(panel that goes across the front of the washer) remove the attaching screws at the bottom corners and pull the panel off, you should see a round,white plastic cap with finger hold bar across the middle of it, unscrew the cap by turning it counter clockwise, pull it towards you to open the trap,clean the filter trap out completely and reverse the order you took it apart to put it back togrether, try running the machine as normal. Good luck and Happy Holidays!
Dec 24, 2009 | Kenmore 46462 Front Load Washer
48102 kenmore washer drains but more on floor than thru drain pipe
Mar 01, 2009 | Kenmore 44102 Front Load Washer
I just wanted to know what pedastals will fit with the kenmore washer 48102
BEFORE U BUY PEDESTALS PLZ GIVE THEM MODEL NUMBER AND THEY WILL LET YOU KNOW WHAT WILL FIT THANK YOU
Nov 28, 2008 | Kenmore Elite 45986 Front Load Washer
F02 error on Kenmore front load, followed solution, problem still exist, What next?
cant see what you tried to repair problem (dont see original post) but F02 is a long drain time. or innaddaquate drain. usually from a clogged, drain pump/button trap. ill assume you were told to remove the lower access panel, gain acess to the drain pump assy, clean the "button trap" of foreign derbis. if thats been done and your still having draining issues iehter theres something i nthe drain hose, or perhaps the drain pump impeller has been damaged preventing proper flow of water.
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
63 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
