Question about Sharp LC42SB45U 42 in. LCD TV
Lc-42sb45u has to wait 10 minutes to turn on the power
4 Suggested Answers
UpGrade
  • 113 Answers
SOURCE: Have a Sharp LC-42SB45U green light is on but no
This is the Actual solution, not a try this deal. You need soldering experience, and a multi meter. First pop the back case off the tv and look to the left, you'll see the inverter. It's got 8 or so pink and white connections on it and a few other wires and a ribbon cable. Take all of that off carefully. Now take out the screws that hold the board on. Once you have it in front of you look for the power connector on the far left above that you'll see two fuses. F1 and F2. Check both sides of F1 with an Ohm meter. Most likely it's blown. Replace this fuse with another one and your TV will be back running again. If you're feeling really clever you should touch up the cold solder joints on all of the inverters, and across all of the capacitors, some of mine were cracked.
Posted on Nov 11, 2011
  • 380 Answers
SOURCE: LC-42SB45U will not find channels from setup Auto
Make sure you getting a good signal and that you are properly connected to the tv. If all else fails, look into replacing the main board.
Posted on Dec 13, 2009
  • 28 Answers
SOURCE: I have a Sharp model
Voltages sometime increase/decrease during power outages. This mainly afftects the power supply of a lot of electronics equipment.
1. Check the fuse.
2. Check primary components like; Bridge rectifier, filter cap, switching components etc.
3. Check secondary (cold) side once you isolate the primary side to be ok.
Please consult a professional technician if you are not skilled in electronics repairing.
All the best
Rjn
Posted on Sep 20, 2011
Sharp Flat Screen lc- 42sb45u It seems that whatever it is that controls the power (off/on) in my tv is not working correctly. The tv will not turn on using the remote or power button on the tv....
sounds like it could be a power supply problem - this is a common symptom for a failing capacitor. If you are handy with a soldering iron, you could replace yourself. Look for capacitor which has a bulging top located on the power board.
Oct 21, 2013 | Televison & Video
I will turn my TV on, and it will work for anywhere from 10 minutes to 3 hours, then it will turn off. (The the picture and audio will go away) then within about 10 seconds it will turn back on... Then it...
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 19, 2017 | Sharp Lc-42sb45u Tv Parts 715t3150-2 Power...
To long to come on
I would start with checking the capacitors. Replace any with bulged tops
Oct 26, 2012 | Sharp Lc-42sb45u Tv Parts 715t3150-2 Power...
My Sharp LC-42SB45U takes 15 min to an hour to turn on. Also, sometimes picture blacks out for 10-15 seconds. Any suggestions? Pat Courson
Have same problem. Not the proper fix though I found that taking the back off and heating it up with a heat gun for 30 seconds to 1 minute and tv works fine till you shut it off over night.Maybe someone can offer a solution with that in mind. Pretty strange
Sep 17, 2012 | Sharp LC42SB45U 42 in. LCD TV
I have a Sharp model LC-42sb45u that will not turn on since power outage.
1. Check the fuse.
All the best
Rjn
Sep 20, 2011 | Sharp Televison & Video
My LC-26sh12u takes 10 minutes to
I had a similar problem where it displays "PLEASE WAIT" for several seconds alternating with blocky colors for several seconds and continuing anywhere from 5 to 30 minutes.
I inferred from a couple of sources that the TV is booting up when it says "please wait" by reading data from flash memory. I was able to fix my problem by resetting the data in memory to factory default values using this procedure from the service manual (wait until the TV is working before trying this):
Turn on the POWER.
Set the VOLUME to minimum.
Press both VOL. DOWN button on the set and Channel button (1) on the remote control for more than 2 seconds.
After the finishing of the initializing of shipping, the unit will turn off automatically
Nov 21, 2009 | Sharp Televison & Video
Sharp Aquos wont turn on
this is either a power problem or the screen needs re-gasing
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC42SB45U 42 in. LCD TV Logo
51 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
