Question about Canon Pixma MP500 All-In-One InkJet Printer
Canon pixma 5200 printer
Printer will not recognize the black 8 cartridge. It worked for awhile with this cartridge but all of a sudden it won't recogize it.
I purchased a new cartridge and replaced it. Apparently the cartridge was defective. At least it is working for now.
Posted on Jun 19, 2008
Canon pixma ip2772 cartridge cannot be recognized
Pleas help me.
I have a Canon Pixma ip 2772 Printer, I used Original Canon ink Cartridge and it after refill. now i using original canon black and color cartridge but now have a problem. ink cartridge not recognized i used original cartridge 4.. pls. help me immediate
Jul 20, 2012 | Canon PIXMA Office Equipment & Supplies
I have fault 5200 on mx320 it won t work.
Try these solutions:
  1. Power off printer, wait 5-10 minutes than turn it back on.
  2. Try reseating print cartridges (remove them and then put them back in)
Removing cartridges:
Installing cartridges:
If I helped you, please rate my answer :)
Sep 06, 2011 | Canon PIXMA MX310 All-In-One Printer
Error 5200 occured while printing. And the black catrige does not recognised
Error code 5200 represent print head or cartridge temperature exceed specified value. It may be caused by the following condition: ink empty or usage of refill ink.
Please check which cartridge indicated by this error and replace it with new one. For Canon Pixma iP2770, this problem frequently caused by an empty CL811. Please refer to Canon Pixma iP2770 Service Manual for details.
Source:
Printer Clinic
Printer Manual
Jul 30, 2011 | Canon Pixma iP2700 InkJet Photo Printer
My new pixma canon ip 2770 cannot recognize the black and colored ink
i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
May 08, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Canon mp270 error code 5200
Hello and WelcomeError 5200 is a service error. Follow this solution step by step
  1. With the printer turned on,unplug it
  2. Open the top and bring the ink cartridge holder to the middle
  3. Raise the gray bar and remove the print head assembly with the cartridges in it
  4. Lower the gray bar with the head missing and close the top with the head out
  5. Restore the power,wait till the printer starts
  6. It will tell you to put in the cartridges, Put in the cartridge
  7. Restore the print head, close the top and the printer will resume working
Error will be removed.
If you have already tried all of the above and still you have error then it is probably that your Canon printer is in need of servicing by a service professional.
So go to the Canon Service Center. If you want to get support on Call then
Call Canon Support by phone, at 1-800-OK-CANON (1-800-652-2666)
Please rate my solution as Four Thumbs if it was helpful. Thank you for using FixYa
Mar 10, 2011 | Canon Pixma MP270 All-in-One InkJet...
Canon ip4200 printer will not print
kindly install the correct and genuine catridge according to the catridge no.
Dec 01, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Error 5200
Error 5200 is a printhead temperature error, sounds like you need a new printhead. The part number is printed on the side of the printhead. it's a QY6 number
Aug 13, 2009 | Canon Pixma MP480 All-In-One InkJet...
Printer does not recognize cartridge which was good yesterday
Hi
Tough one here but try removing / replacing cartridge, failing that try new replacement as each cartridges have their own electronic chips. I assume you are using genuine canon carts.
Cheers cbacer
Aug 11, 2009 | Canon PIXMA iP90 Mobile Printer
The black cartridge cannot be recognized
dear ****
try this methode
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.)
should be orange.
5. Press and release the RESUME button again, the indicator
6. Release both buttons
and try to print
thank's
cropp
Mar 15, 2008 | Canon PIXMA iP1600 Printer
Printer wont recognize new or old cartridge
Use a Q-Tip and some clean water to clean the contacts behind the cartridge in the printer and on the cartridge itself. Then use a pencil with a clean eraser to polish the contacts. Be careful not to touch the part where the ink comes out of the cartridge.
Also, are you using Canon ink or third party?
Jan 09, 2008 | Canon PIXMA iP1600 Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
46 people viewed this question
old marine
old marine
