Question about HP OfficeJet Pro K8600 - - color - ink-jet - A3 Plus - 1200 dpi x 1200 dpi - up to 35 ppm
First prints clearly. Second page on lines are not completely black. If I print one page at a time (beginning each job anew), then the page is fine. I cannot print multiple sheets without light lines appearing eery 5 or 6 lines. Print Quality Dikagnostics Page looks fine. Please advise.
  • HP Master
  • 1,679 Answers
Have you been using the Printheads for long time and not changed them ?
Seems like this could be problem with the Printheads and they need cleaning.
Follow the steps below to resolve the issue
First prints clearly. Second page on lines are not - hpweb_1-2_minus.gifMethod one: Clean printheads in Solution Center
  1. Make sure the printer is loaded with unused white paper.
  2. In HP Solution Center , click Settings , and then click Printer Toolbox .
  3. Select the Services tab, and then click Clean Printheads . Figure 9: Clean Printheadsc01955791.jpg A Clean Printheads window opens. .
  4. Click Clean First prints clearly. Second page on lines are not - c01955792.jpg: Clean Printheads windowc01955792.jpg The printhead cleaning process begins. This process takes a few minutes.
hpweb_1-2_minus.gifMethod two: Clean printheads from the control panel
  1. Press and hold First prints clearly. Second page on lines are not - c01955794.jpgwer button (c01955793.jpg Press the Cancel button ( ) two times.
  2. Press the Resume button (c01955795.jpg ) one time.
  3. Release the Power button (c01955793.jpg ). Cleaning the printheads takes a few minutes, and when it completes, a page prints.
    • If the page shows no streaking , continue to Step four: Examine Test Pattern 3.
    • If the page shows streaks , repeat steps 1 through 4 up to two times before continuing to Step four: Examine Test Pattern 3.
Also, Remove the Printheads and clean the Electrical contacts ( not the nozzle from where the ink is sprayed ) with lint free cloth ( little damped in water )
Method three: Replace one or both printheads If, after repeated printhead cleaning, the Print Quality Diagnostic page shows white lines across the color blocks in Test Pattern 2 (but no white lines in the gray blocks in Test Pattern 3), one or both of the First prints clearly. Second page on lines are not - c01955795.jpgll have to be replaced. The Print Quality Diagnostic page shows which printhead should be replaced.
  1. Open the cover.
  2. Make sure paper is loaded in Tray 1.
  3. If the carriage does not move to the left automatically, press and hold the Resume button (c01955795.jpg ) until the carriage moves to the left. Wait for the carriage to stop movinFirst prints clearly. Second page on lines are not - c01955717.gif
    CAUTION: Do not proceed until the carriage is on the left. If the carriage does not move to the left automatically, turn the printer off and back on and thFirst prints clearly. Second page on lines are not - c01955718.gifg down the Resume button (c01955795.jpg ) again.
  4. Lift the printhead latch. Figure 15: Lifting the printFirst prints clearly. Second page on lines are not - c01955719.gif>c01955717.gif
  5. Lift the handle of a printhead, and use it to pull the printhead out of its slot. Figure 16: Pull the printhead out of its slot
  6. Before installing a new printhead, shake the printhead up and down at least six times while the printhead is still in its packaging. Figure 17: Shake the printheadc01955719.gif
  7. Remove the new printhead from its package, and then remove its orange protective caps.
    CAUTION: Do not shake printheads after the caps are removed. Figure 18: Open the printhead and remove the orange capsc01955720.gif
  8. Insert the printhead into its color-coded slot (the label on the printhead must match the label on the printhead latch). Press down firmly on the printhead to ensure proper contact.
  9. Pull the printhead latch all the way forward, and then press down to ensure that the latch is properly engaged. You might have to apply some pressure to engage the latch.
  10. Close the cover, then wait while the device initializes the printheads and prints the alignment pages.
This should resolve the issue.
Thank you for contacting the FixYa team
* Please rate this solution with Thumbs up and comment to help us improve providing support
Posted on Nov 13, 2010
  • ONE-Touch-Solution
    ONE-Touch-Solution Nov 18, 2010
    I would like to know if the solution provided for your issue " First prints clearly. Second page on lines are not completely black " is resolved ?
    Regards
    FixYa Team
    *Please rate this solution with thumbs up
How to clean head HP 7260
HP Photosmart 7150 and 7260 printers
  1. Make sure plain paper is loaded into the In Tray.
  2. To perform the first level cartridge cleaning is a spit and wipe, press and hold the Power button while pressing the Cancel button twice, then release the Power button. The printer will generate a series of noises as it performs the cleaning.
  3. Print a test page from the computer.
  4. Once the cleaning has completed and the test page has printed, examine the test page. If the print is not clear and/or there are lines in the color bars, continue to Step 5.If the print quality is acceptable, disregard the subsequent steps.
  5. To perform a second level cartridge cleaning, press and hold the Power button while pressing the Cancel button twice. Release the Power button and press the Resume button. The printer will generate a series of noises as it performs the cleaning.
  6. Print a test page from the computer.
  7. Once the cartridge cleaning has completed and the test page has printed, examine the test page. If the print is not clear and/or there are lines in the color bars, continue to Step 8.If the print quality is acceptable disregard the subsequent steps.
  8. To perform a super clean, press and hold the Power button while pressing the Cancel button twice. Press the Resume button twice then release the Power button. The printer will generate a series of noises.
  9. Print a test page from the computer.
  10. Once the super clean has the completed and the test page has printed, examine the test page. If the print is not clear and/or there are lines in the color bars, continue to Step 11. If the print quality is acceptable disregard the subsequent step.
  11. To perform a pen nozzle test, press and hold the Power button while pressing the Cancel button eight times. Press the Resume button four times then release the Power button. The printer will generate a series of noises then print a page displaying a test pattern. If there are gaps in the printouts the cartridge(s) may need to be replaced.
Jan 17, 2015 | HP PhotoSmart 7260 InkJet Printer
My ip4300 keeps printing the same page over and over again. There's nothing in the print Q, but no matter what new job I send to the printer it prints the same old page. Is there a way to reset the printer...
Have you rebooted your computer? The printer's memory is very limited -- certainly not enough to hold an entire page. Your computer feeds the printer a line at a time, so it would seem that your computer's print spooler is 'stuck' on that print job. Try shutting the computer down completely, then restarting and see if that print job clears out.
Mar 24, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
HP Laserjet 4L just started printing black pages. After a few pages they print are normally. It all starts again when I begin another print job after some time passes after the last job. Put a new...
The image drum is not getting the correct signal at the correct time. It is time to retire the 4L and replace it with a newer, faster LaserJet. You'll be glad you did.
Nov 19, 2009 | HP LaserJet 4L Printer
Picture crops strange
HP Photosmart 7550 printers
  1. Ensure that the memory card has been removed from the memory card slot.
  2. Make sure plain white paper is loaded into the In Tray.
  3. On the control panel, press the Menu button. Using the directional arrows, select Clean Cartridges .
  4. Press the OK button.
  5. After confirming that paper is loaded into the paper tray, press the OK button.
  6. Once the level one clean cartridge test page has printed, examine the printed page. If the print is not clear and/or there are lines in the color bars, continue to Step 7. If the print quality is acceptable and there are no flaws with the color bar, select No using the directional arrows, then press OK .
  7. Press OK to print the second level clean cartridge page.
  8. Once the second level clean cartridges test page has printed, examine the printed page. If the print is not clear and/or there are line in the color bars, continue to Step 9. If the print quality is acceptable and there are no flaws with the color bar, select No using the directional arrows, then press OK .
  9. Press OK to print the third level clean cartridge page.
Dec 08, 2008 | HP PhotoSmart 7550 InkJet Printer
Will not Print
Try a hardware check of the printer first. To check the hardware of the printer, do the following:
  1. Switch off the printer.
  2. Load one sheet of paper into the paper feeder.
  3. Press the Power button and the Paper Feed button at the same time and hold them both down for three seconds. Then release the Power button only.
  4. When the printer begins to print, release the Paper Feed button. A page will be printed. The page should contain some text at the top and a series of horizontal color lines (cyan, magenta and yellow) below the text, with a thick black line below the colored lines. All the lines should be solid.
  5. When the test is complete, switch off the printer. NOTE: If you do not switch off the printer, it will continue to print.
Sep 24, 2008 | Lexmark X1270 All-In-One InkJet Printer
Hp deskjet 990 cse won't stop printing, help!
you'll need to re install the printer drivers, clear out the print queue, and begin anew
www.hp.com has those drivers by model number and operating system
http://tinyurl.com/6qcpgy
Aug 19, 2008 | Apple HP DeskJet 990cse InkJet Printer
Trouble with duplex printing
I think your problem is that the 5550 supports manual duplex printing. Print every other page then feed them through again. Never tried it though. Dave Reed
May 23, 2008 | HP LaserJet 5550 Printer
Hello
Can you print using the control panel, printers and faxes, general tab, Print Test Page ? You may have to clear the print queue first.
Oct 12, 2007 | HP PSC 1410 All-In-One InkJet Printer
HP LaserJet 1020 Prints a Black Line when at the right side when using Ms Word 2007
First, you need to try update the latest microsoft office patch file from microsoft or you can open the MS Word, go to "HELP" menu select the update MS Word or related. Try the latest patch file first. You also can try windows update and select custom update, see their list have this problem solution or not. Second, you need to go to HP website download latest driver for LJ1020 and suitable use on Vista. Lastly, if still not solve the problem, you need this problem/issue to microsoft, ask their solutions. Kent
Aug 22, 2007 | HP LaserJet 1020 Printer
HP OfficeJet Pro K8600 - - color - ink-jet - A3 Plus - 1200 dpi x 1200 dpi - up to 35 ppm  Logo
214 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
