Question about Sharp LS-600
Model : scanner T sharpwin LS600 i need driver for XP and 7 thanks a lot
    New Friend:
Driver ls600 for win 8
Posted on May 22, 2017
Scanner driver for win7
Please click the following link to download Mustek Bearpaw 2400 CU Plus Win 7 driver:\
For more information, please visit the following link:
Hope the above information is helpful.
Aug 23, 2012 | Office Equipment & Supplies
Window 7 driver of visioneer 9320
This model is discontinued from OEM. So, it will not work on Windows 7. For more information, please visit the following links:
Thanks & regards,
Aug 16, 2012 | Visioneer OneTouch 9320 Flatbed Scanner
Scanner doesnt have a driver for windows 7
This may help. Depending on your version of windows 7 you may be able to run Windows XP as a virtual machine and still user your scanner under XP Mode. You will have to install the XP driver for your scanner on the XP virtual machine running on your Windows 7 computer.
Windows 7 has several built-in tools to help with program compatibility and Windows XP programs should be installed directly on Windows 7. Windows XP Mode runs many older Windows XP productivity programs and that are not natively compatible with Windows 7, thus helping realize cost savings and reduce possible operational downtime by extending the life of existing software.
HERE is the direct link to instructions on downloading and using XP Mode on Windows 7
Jul 18, 2011 | Office Equipment & Supplies
My XP PC crashed, and I am now using a Windows 7 64-bit laptop. I tried to install the set up CD, but it said it is compatible up to XP, 32-bit. Is there an updated driver so I could use it with this...
the flat bed scanner will not work properly because the driver you have is for windows xp, you have to download the driver for that scanner which support windows 7, got to the website of cannon and find your device and driver supported with windows 7, plug in you scanner and make full update your system and windows will update the driver of your scanner.
thank you
Apr 26, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
Got flatbedscanner 22 from ACER S 2 W Scann to Web 3300U. Works fine under Windows XP, but can't get it going under Windows 7. Windows 7 has found the hardware, but no driver instaled. Got the original...
got to the web site for the scanner manufacturer select down load for that model and select win 7 os
down load and run
Microsoft no longer supports win 7 so the scanner driver will not be listed in win 7
Dec 03, 2017 | Acer Scan to Web 3300U Flatbed Scanner
I have upgraded to Windows 7. Where can I get drivers for Visioneer One Touch 8920 Scanner?
You can't. This is an older model, "end of life" per Visioneer, and they never released drivers for any system later than XP. If the XP drivers don't work, you'll need to replace the scanner with a newer model.
Jan 17, 2011 | Visioneer OneTouch 8920 Flatbed Scanner
I need drivers for FlatbedScanner win 7
It does work for windows 7.
Go to:
and download file, then just unzip and install setup.exe.
I use win 7 x86 (don't know if it works for x64).
Yes, the scanner is rather old, but it sitll does the job.
May 08, 2010 | Acer ScanPrisa 640U Flatbed Scanner
Microtk Scanmaker 3840 driver for windows 7
The scanner is not supported by Microtek for Win7. Since Windows 7 didn't find a generic driver (TWAIN) in its driver code, one option exists in Windows 7 Pro and Ultimate. Download and install the virtual XP mode (two programs are needed), then use the XP drivers and install the scanner to the "XP computer". You may need to store files on external media to transfer them between the "two" computers.
The XP drivers are here:
I hope this helps.
Feb 26, 2010 | Microtek scanmaker 3840
Canon Canoscan D1259U2F dont have any driver for Windows 7 64-bit
the only successful method I found for using CanoScan D1250U2F in 64 bit Windows 7 (I guess the same would be for 64 bit Vista) is to use Windows XP Mode in Virtual PC (attach the scanner as USB device and that's it - works perfectly)
I had a problem with Windows 7 detecting the device as CanoScan (needed for Windows XP Mode to detect is as USB device and allow attach) - the solution was to unplug the scanner, plug it in and CANCEL Windows 7 hardware detection process before it finishes - this leaves it as "CanoScan" device (auto-detect will leave it as "Unrecognized device" and with that unusable/un-attachable in Windows XP Mode)
latest versions of Windows XP Mode will make your hard drives accessible as network locations (no need for external media)
Jan 01, 2010 | Canon CanoScan D1250U2F Flatbed Scanner
Sharp LS-600 Logo
175 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
