Question about Jenn-Air JJW8430D Electric Double Oven
Can hardly read board's numbers/time.
Looks like if the light fixture of board had lost power. Lights are extremely low and can hardly read temperatures or time.
  • Anonymous Jan 01, 2009
  • 3 Answers
Mine is doing the same thing but I can still read it. It's a little computer board that will need to be replaced. I will eventually have to replace it but since I just spent nearly $200.00 replacing a sensor that burned up in the self clean cycle, I'll wait until it's really hard to read!!! By the way, I found a good appliance repair company on Angie's List...and got to read consumers reviews. Good to know.
Posted on Feb 08, 2009
Why won't the clock stay lit? Shows the correct time, but only stays on for a few seconds.
Some clocks work that way. I guess they're just saving power.
Hope this helps.
Feb 24, 2015 | Ovens
Faulty lights and timer bleeper on neon clock display on front of electric oven.
It is very possible the control board is going bad. Before replaceing the control board pull the connectors and reinstall them. There could be a bad connection causing the display not to lioght up completly. If that doesn't work then it looks like control board time.
Nov 17, 2014 | Stoves 720EF Electric Double Oven
How do I fix the lights on the clock?
I don't think that the lights are repairable,it looks to me that they are part of the timer display and if this is the case it would not really be a diy job.
Everything works except the heat. Light on oven temp adjustment not coming on. Circuit boards look good. No burnt or overheated wiring. Transformer looks good, not certain how to test heat coil.
Is it 220v??? If so make sure u have correct voltage. All the oven lights and circuit boards are ram off 120v. The element probably requires 220v to operate.
Also take multimeter and check continuity across element. Should make meter beep or display will read 0.00.
Dec 28, 2012 | Ovens
Oven glowplug lights but gas will not turn on oven, broiler works fine. have replaced gas valve and circut board
Even though the ignitor (glowplug) is heating up, it more than likely still needs to be replaced. They do become weak over time. An oven gas valve requires a certain amount of current moving through the coil in order to open the plunger. The he circuit goes through the ignitor, and the hotter thee ignitor gets, the more current flows through it. As the ignitor weakens, it does not allow sufficient current through the circuit to open the valve. Replace the ignitor and you'll be baking in time for Thanksgiving. Use caution when installing the ignitor, as they are extremely fragile. Also, do not touch the actual element section of the ignitor when installing it.******Remember to remove power from the range before making this repair.
Good luck, and gobble, gobble.
Nov 18, 2010 | Maytag Ovens
No lights on panel can't read temp. or time how to replace lig
Sounds like another control board failure, common on this type oven. It appears that a capacitor (#C3 on board) overheats and goes bad. Replacement of cap is a simple soldering job but the caps can be hard to find, try electronics parts houses and explain you need a high temp replacement. Should cost you about a buck. See post by BrianGem back in may of 2008, who turned me on to the target cap. Its a 35Volt 86mF. DISCONNECT OR TURN OFF POWER PRIOR TO ANY REPAIRS.
Mar 07, 2009 | Jenn-Air WW27430P Stainless Steel Electric...
Lighting pilot of GE gas stove
According to the model number you supplied it looks like your oven use a glow bar ignitor not a pilot light. In that case there is no place to hold a fire. what happens with these when you turn the oven on 120 volts goes to the ignitor causing it to heat up ,the amp draw across the ignitor causes the gas safety valve to open, and then lights the gas. So if you turn your oven on you should see a bright red glow if not probably the the ignitor, to check it you would have to verify you actually have power going to it. If the ignitor glows but the gas valve does not open you will still need to replace the ignitor has to pull about 3.2 amps across ignitor to open safety valve. Your broil burner works the same way. And most of the ovens the floor of the oven comes out to allow easier acess to the ignitor. also if you have to change the ignitor put just a dab of dish detergent on the screws to help from stripping them
Nov 27, 2007 | GE JGRP17 Gas Single Oven
Problems with Jenn-Air Electric Double-Wall Oven
that board supplies power to the light unit and it is very easy to replace if that is what is wrong. it can also be the led display unit also. cost about $150 each i think.
Oct 26, 2007 | Jenn-Air WW30430P Stainless Steel Electric...
Display Panel Light
There is a replacement display assembly, i think its around $150-$200. Its pretty easy to change if you are at all mechanically inclined. Good Luck!
Oct 29, 2006 | Jenn-Air W30400P Stainless Steel Electric...
Jenn-Air JJW8430D Electric Double Oven Logo
132 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
