Question about ATI RADEON HD 2400 PRO Graphic Card
I recently had a new motherboard installed on my workstation. The screen graphics are not as good as before, fuzzy letters not crisp, Resoultion is set at 1400 x 900.
It shots off suddenly and a blue screen with white letter comes up
Hello try to visit the homepage here:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=381&MenuID=1&LanID=0
And install any missing drivers if needed for the mainboard.
Please select your windows system
Try also to renew the graphic cad driver.
Or renew the graphic card.
Your mainboard has the 1 x AGP 8X/4X graphic card slot.
Try to start in failsafe mode by pressing F8 when boot up.
I think your graphic card is failing.
Good luck
Sep 14, 2013 | EliteGroup ECS 755-A2 Motherboard
Resoultion of screen
Mainly the problem is faced when either your graphic driver is not installed or installed improperly (not the one which is required by the system). You need to look for the required graphic / vdo driver for your system as per your operating system.
Jul 06, 2012 | Computers & Internet
My soundcard is now working, but the graphics card isnt displaying the rite resolution, HELP PLZ
Install the graphics card drivers just as you did the sound cards. Then the resolution should display perfectly if you set it up to the maximum. The lettering should be crisp and clear. Hope this helps =]
Mar 04, 2011 | Computers & Internet
Graphics issues
www.nvidia support.com re-run drivers from vendor's web site
Jul 18, 2009 | OEM Systems RADEON 9700,, AGP Video Card
Unable to get 1280x1024 res after xp install on a P4 machine.
Try going to the control panel then to appearance and themes then disply and change the screen resoultion
Jun 12, 2009 | ASUS P4S533-MX MB, DDR+SDR/ VGA/ Audio/...
Laptop Screen Resolution / Graphics Card
Without researching thru alot of tech sheets I would doubt that the old card would work in the new laptop.
Dec 07, 2008 | Computers & Internet
Monitor lcd acer al2016w 20" letters and image are fuzzy,,why?
I also have an Asrock motherboard (M266A) and have the AL2216W. The image and text is also fuzzy. I did improve it a by by unplugging/replugging all of the connectors on the back of the computer. I believe my mouse had a somewhat loose connection and this was causing interference. I can actually create interference on screen by moving my mouse up and down.
These Acer monitors seem to be very sensitive. I also tried this monitor on a old Desktop with Win98 and another new laptop with XP and it looks good on those computers, but not on my Asrock based system.
Nov 30, 2008 | Acer AL2016W 20" LCD Monitor
No input signal
Check connections, Hertz rate, and settings (if you can read them). Otherwise, it may be time to whip out the cash and get a new monitor and/or computer.
Aug 17, 2008 | Computers & Internet
Dell D800 screen looks like if it fizzing
you need to reinstall the Graphic Drivers. If you have Installed any antiVirus in recent days, try uninstalling it and reinstalling it back again. it seems as if the problem is with the graphic card and need to be replaced
May 01, 2008 | Dell Latitude D800 Notebook
Video problems
change ur screen resoultion n try to make ur screens refrest to 60MHZ! if still ur problems not solving re-install windows
Nov 10, 2007 | EliteGroup P965T-A Motherboard
ATI RADEON HD 2400 PRO Graphic Card Logo
54 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Tony
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
