Toshiba lcd tv with what looks like a water stain. Nothing is on the screen....it is clean.
5 Suggested Answers
SOURCE: looks like a water stain on screen
IT SHOULD NOT NEED A "REPAIR" PER SAY. HOWEVER, I OWN AN LCD TV, BUT NOT A PROTRON. YOU'RE GONNA FIND THIS PROBLEM WITH ALL LCD TV'S. IT SOUNDS LIKE IT IS SIMPLY DIRTY. THIS IS THE WAY YOU CLEAN YOUR SCREEN. IT IS VERY EASY AND FAST, AND YOU SHOULD HAVE THE SOLUTION IN YOUR KITCHEN AND BATHROOM. TAKE THE CLEANEST, MOST SOFT CLOTH YOU HAVE IN YOUR HOUSE. DAMPEN,NOT SOAK IT, WITH WATER, AND LIGHTLY RUB A SMALL SECTION OF THIS STAIN, AND SEE WHAT HAPPENS. IF THIS DOES NOT WORK, ADD A SMALL AMOUNT OF SIMPLE RUBBING ALCOHOL, AND TRY ANOTHER SMALL SPOT OF THE STAIN. IT SHOULD COME OFF. SOME OF MY "HI-TECH" FRIENDS USE STRAIGHT RUBBING ALCOHOL, AS IT HAS A TENDENCY TO EVAPORATE A LOT FASTER THAN WATER AND LESS LIKELY TO LEAVE ANY "WATER STAINS". HOWEVER, IF YOU CANNOT SEE THROUGH THIS STAIN, THEN YOU'RE BETTER OFF BUYING A NEW TV. SOUNDS LIKE SOME KIND OF LEAK OR MAYBE THE TV IS JUST NEVER SHUT OFF, THEREFORE BURNING IMAGES INTO THE SCREEN. FORTUNATELY, IF IT IS STILL UNDER WARRANTY, YOU MAY GET HELP THERE. MY FIANCE TOUCHED THE LCD SCREEN WITH HIS FINGERS, AND IF YOUR FINGERS ARE DIRTY, THEY WILL LEAVE OIL STAINS. PEOPLE DO SOMETHING TO A PRIZE POSSESSION IN YOUR HOUSE, DONT TELL YOU THEN ACT LIKE THEY DONT KNOW WHAT HAPPENED. ITS HILARIOUS. HOPEFULLY THE ISSUE YOU HAVE CAN BE FIXED BY YOU!
Posted on Jan 08, 2008
MikeMaierTV
  • 206 Answers
SOURCE: plasma screen
There is a slight film on these and once damaged is a real pain to clean, what we do here is spray the rag with rubbing alchahol then clean the screen, several passes may clean it up, but never spray the screen, this allows fluid to leak down past the front and this can kill the set real fast
Posted on Feb 13, 2008
  • 8457 Answers
SOURCE: 47 inch Toshiba LCD REGZA TV - screen has what
The only way might solved this problem,to replaced the Tuner Signal board.If the board is replaced have same problem,then ur tv have some kind of dead pixels burns in.Tries Shopjimmy.com,Ebay.com for the board part.
Posted on Feb 04, 2010
kb8dns
  • 494 Answers
SOURCE: my philips lcd tv looks like it has water stains
Same thing happened to my "new" Sharp lcd, I loosened the back screws just a tad and it stopped. I believe it is caused by heat from the back light and expands the LCD fluid causing it to leak down the front between the cover mask and the glass. Not an easy fix and if you have any warranty check into it....
Posted on Apr 13, 2010
How do I get streaks off the screen?
I use a brand new microfiber cloth. Mist the cloth with a spray bottle a few times with clean water. And brush the screen lightly with only the microfiber by folding the cloth into a square. If the stain is persistent try a LCD screen cleaning product
Aug 03, 2015 | Sanyo DP42848 LCD TV
Tip
How to clean an LCD TV
<span>An LCD screens must be cleaned as it attracts dust like a magnet. Cleaning is risky as the screens are very sensitive and there are chances of you damaging the screen if you don't know the proper method to clean it. To help you in this read the article below to the various tips on cleaning the LCD TV.</span> <b>Tips On Cleaning LCD TV</b> <b>Basic Facts About LCDs</b> <ul> <li>LCD screens or displays should not be cleaned through normal methods, as they are not glass. LCD or liquid crystal display is a soft film and it can be damaged through improper cleaning agents.</li> <li>The popularity of LCD TV's is on a rise as they can be can be run on low battery power and also have<a href="http://lifestyle.iloveindia.com/lounge/how-to-clean-lcd-tv-8061.html#"><span>sharp</span></a> picture clarity.</li></ul> <b>LCD Screens Problems</b> <ul> <li>LCD screens regularly gather dust and smudges and sometimes fingerprints and ink markings.</li> <li>Cleaning the screens with a <a href="http://lifestyle.iloveindia.com/lounge/how-to-clean-lcd-tv-8061.html#"><span>paper</span></a> towel, dishcloth or tap water can do considerable damage, as the screens are very sensitive. It can cause clouding and can cause damage to the pixels.</li> <li>Tap water contains chemicals like chloride and wiping the screens with it can leave a residue on the screen.</li></ul> <b>Cleaning Tips And Guidelines</b> <ul> <li>The LCD TV must be cleaned regularly for you to enjoy the proper clarity of the display.</li> <li>First of all, turn off the LCD TV and examine the condition of the screen.</li> <li>Note the smudges and the areas to be cleaned.</li> <li>To remove dusts use a microfiber cloth and brush off the dust particles.</li> <li>It is best to use proper cleaning solutions that come with LCD cleaning kits. However, you can mix one part of isopropyl alcohol with one part of distilled water and using cotton or microfiber cloth, clean the screen. Another cleaning solution that can be made at home to clean LCD TV's is to mix one part of vinegar in one part of water. Pour this solution on a soft cloth and then wipe the screen.</li> <li>Take care not to spray any sort of cleaning solutions directly onto the screen. Instead take it on a piece of cloth and then wipe.</li> <li>Wipe the screen in a circular motion and be very gentle. Don't press hard.</li> <li>Also do not touch the screen with your fingers or there are chances of leaving oily prints.</li> <li>Rub a soft cotton dry cloth to completely remove excess liquid from the screen as the moisture may damage it.</li> <li>Before switching back the TV on, let the screen dry completely.</li> <li>If some stains or marks are hard to remove, don't apply pressure to remove it. Instead, repeat the cleaning procedure several times to get rid of it. For ink marks and other hard stains, you have to invest in special cleaners.</li> <li>To clean the dirt from the edges or corners use a Q-tip. Dip one end of the Q-tip in the cleaning solution and squeeze out the excess moisture from the cotton tip. Now gently drag this tip along the edges.</li> <li>Do not use cleaning solutions that contain ammonia, ethyl alcohol, acetone, toluene, ethyl acid, or methyl chloride. These chemicals can react with the LCD screen materials and damage it.</li></ul>
on Jan 18, 2011 | Televison & Video
Sanyo TV DP42647 Screen Has Dark Stain
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 27, 2017 | Sanyo Televison & Video
Looks like a water stain on the sceen
Liquid and/or water stains in LCD screens can be removed by opening the panel and cleaning with a delicate non-abrasive cloth {If needed use a diluted alcohol water mix.} The water will be trapped between the plastic sheeting that is within the panel assembly. This procedure is very easy on a laptop though since you have a 42" screen... The LCD panel is composed of: the display itself and several layers of translucent plastic sheets which focus and enhance the image produced by the display. The display is usually very thin so perhaps on such a large screen it is best that you have a professional perform the repair.
If you decide to undertake this task on your own, I recommend a flat level surface and latex gloves to prevent further smudging {also, most if not all LCD's contain mercury.}
Sep 08, 2012 | LG 42LH55 42 in. HDTV LCD TV
47 inch Toshiba LCD REGZA TV - screen has what looks like water stain or "woodgrain-like" shadows/artifacts. They go sort of vertical but are not straight, (look like wood grain shadows). Not real obvious...
Feb 04, 2010 | Toshiba REGZA 47HL167 TV
WESTINGHOUSE FLAT SCREEN TV
Water damage/stains possible on backlight panel behind LCD panel. I've seen this more on laptops. Does it look like brighter white spots? You might have to take it in to have it professionally cleaned.
Apr 23, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Looks like a water stain on screen
Jan 01, 2008 | Protron PLTV-32 Television
Staining on LCD tv screen
The LCD screen is bad this may have been caused by presure exerted to the screen fracturing the cells of the LCD. any way the LCD is bad and needs replacing.
Dec 27, 2007 | Philips 32PT6441/37 32" TV
Shadow down right side of screen on a toshiba 44NHM84 44" DLP television
shadows at the bottom of the screen sound like moisture that was "wicked up" between the screen layers and dryed out leaving a stain. DO NOT get these screens wet, use nothing but a damp soft cloth; just a few drops of water running down the screen can cause a fairly large stain. Some people have suggested that they may be professionally cleaned, but the risk of damage is too great on the user level.
Nov 12, 2006 | Toshiba 44NHM84 44" TV
Televison & Video Logo
115 people viewed this question
Top Televison & Video Experts
Electro Med Services...
