Question about Norelco G270 Beard Trimmer
How can I change the battery in my Norelco G270 beard trimmer? (How do I open the thing up for access to the battery?)
4 Suggested Answers
  • 6 Answers
SOURCE: How do I change the Battery in My Norelco T3000 Beard Trimer
twist the head and the body.
Posted on Jul 06, 2009
SOURCE: How to open case on Norelco T-3000 beard trimmer
Remove the bottom screw. Next, the on/off slide switch has to be lifted off carefully with a small flat screw driver. Its kept in place with a small spring steel clamp. After you've removed it lift off the steel clamp and remove the slide mechanism by carefully twisting it out of position. Once that's done it will twist open easily.
Posted on Dec 24, 2010
  • 3 Answers
SOURCE: how to get out dead
Remove the screw from the bottom. The on/off switch snaps off.
Then gently work a thin bladed screwdriver in the bottom next to
the screw hole. Pry gently - the top (with the charge light and
the name written on it) slides downward about 3/16 of an inch
and lifts off. Unsolder the old battery from the board and solder
the new one in. Then snap it back together and put the screw
back in. The switch takes a little patience, but it'll snap back on.
Posted on Feb 02, 2011
How do i open my norelco g380 to change the battery
If you use a small flat blade screwdriver you can gently pry it apart, there is no glue holding it together. I replaced my battery recently. It utilizes a AA NiMh battery with tabs on it. See pictures for more details.
Dec 23, 2012 | Philips G380 Beard Trimmer
Wheres the battery
Oct 17, 2012 | Norelco G270 Beard Trimmer
Change battery wahl 9918c
How to change the Battery in a beard trimmer - YouTube
? 3:38
https://www.youtube.com/watch?v=QlLqB9S5oaI
Oct 20, 2013 - Uploaded by Shake the Future
Do you have a beard trimmer/clippers that don't hold the charge? Time to change the battery and give your beard trimmer a second life. .... Wahl Trimmer All-In-One Lithium Ion Unboxing - TimmyTechTV - Duration: 6:32. by ...
Jul 28, 2012 | Wahl 9916-800 Groomsman Beard Trimmer
How do I replace the battery on my Norelco D-finer D350?
try checking on placement of the batteries where it is screwed outside. you unscrew it and open the cover then change the batteries.. you can also sneak into the manual for sure..
Apr 28, 2011 | Norelco D-Finer D350 Beard Trimmer
How long do I charge my trimmer?
it takes about 8 hours to recharge completely
Sep 24, 2010 | Norelco G270 Beard Trimmer
Jul 25, 2009 | Norelco Health & Beauty
Remove Phillips head screw at bottom of trimmer. Separate body in two being careful to notice how on/off switch is assembled. Unsolder the ni-cad battery from circuit board. Install new ni-cad battery of the same physical size that has solder tabs on it and solder it to the circuit board. I used a ni-hi (nickle metel hydride) instead of ni-cad which had different charging requirements so I limit charge time to no more than 16 hours for a discharged battery. It had been working fine for over a year. Don't forget to apply a few drops of light oil to the cutting blades to extend cutting life. Replacement blades are about $30.00
Jul 06, 2009 | Norelco T770 Beard Trimmer
DOES NOT CHARGE
If you still have it I have one I dropped. The body is still fine, and the batteries charge. A piece broke off inside the cutting blades. Let me know if I can help. Thank You, Jeff
Jan 15, 2009 | Norelco G270 Beard Trimmer
Norelco G270 Beard Trimmer Logo
420 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Andrew Taylor
Andrew Taylor
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
