Question about Relisys TL 540 (Blue, Graphite) 15" LCD Monitor
Dir sirs I have a Relisys TL450RE 15" lcd monitor and it goes on for 2 seconds and then black out , I opened the cover and found that the PCB that connected to the backlight has a capacitor bured out (C19) , I am going to replace it but i am not sure if that is the only faulty part or there is some other parts to replace ? Thank in advanced , Nevat Ben Haim
  • 11,361 Answers
Is it blue cap by the lamp connector? There should be more than one close by another lamp connector. It will be labeled with something like 22J 3K.
Post the picture if you can.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Nov 18, 2010
  • 732 Answers
Nevatb, Please send the brand name(s) of the filter capacitors that are installed on the switch mode power supply/inverter ballast board. May need to replace those that "look" ok also. 12fixlouie
ps: Hope you took lots of digital pictures so you can do reassembly of unit.
Posted on Nov 13, 2010
I got horizontal lines occasionally across my Relisys 17'' TL766 black monitor,sometime they disappears when I turn monitor off and on again,sometime not,what is causing them
try to open back cover and remove / insert all connector that you can found including ribbon wire check also soldered side for possible lost contact.
Apr 10, 2010 | Relisys TL 766 Monitor
Fp5315
Hi I have similar, I'm an electronics engineer and took mine apart only to find the power supply is very sick to the pint the pcb that converts all the signals probably has been damaged too, ie BIN FODDER.
Not very constructive but at least I know what is wrong - if I can get any constructive info i willl post it....
Aug 23, 2008 | HP Compaq FP5315 15" LCD Monitor
Relisys Sound
CJ,
1. Check make sure the audio cable are plugged in from the monitor to the PC output audio jack (light green).
2. Open your on screen display and go to Volume settings. See if it set on mute or set to 0.
3. Turn of your monitor & PC and unplugged all the cables from your monitor and PC wait for 10 seconds and then replugged it all the cables and audio cable back. Then turned on you PC...
4. If it still doesn't work.. open the back cover see if the speaker cable are plugged in.
5. If that doesn't work...then your monitor AD board built-in speakers are defective.
6. Why not just used a external speakers, it give better sound quality.
Have a nice weekend!
Aug 17, 2008 | Relisys RLT1720 17" LCD Monitor
RELISYS 17inch LCD TV
Hi...there,
2yrs it long enough...some only got 1yr. Hehehe... You'll need to replaced a new backlight inverter.
Good lucks!
Aug 01, 2008 | Relisys RLT1720 17" LCD Monitor
LCD Benq FP937s+
This is an Inverter related issue on the Inverter board.
Feb 23, 2008 | Relisys RLT1720 17" LCD Monitor
Screen goes black after a few minutes, switching off and on and picture returns then goes black again
I have problem with my monitor, it is automatically switching off and switching on for 2 to 3 minutes for every 15 minutes why ?
Please mail me the solution to craju1@yahoo.com
Oct 21, 2007 | Relisys RLT1720 17" LCD Monitor
Monitor goes black
If you can see the backlight ,white 2pin connectors connect to invertor pCB.Look around these two connectors you should see 2 brown/yellow/red transformers with a ferrite core.These are the inverter transformers , resolder all pins and power transistors around it.
That should solve your proble.
Please provide feedback and rate this solution.
Samir.
Aug 30, 2007 | HP Pavilion F1503 15" LCD Flat Panel...
Relisys TL 540 (Blue, Graphite) 15" LCD Monitor Logo
131 people viewed this question
Top Relisys Computers & Internet Experts
Samuel Konger
Samuel Konger
giarcnameloc
Level 1 Expert
Are you a Relisys Computer and Internet Expert? Answer questions, earn points and help others
