I have a nutone wall heater model 9356 .is there a replacement for it . the thermostat went out and I can not find any parts .
3 Suggested Answers
  • 306 Answers
SOURCE: I have a Cozy one-sided
Can you remove the front cover to the wall unit? Look for the wiring and follow it till you see a round about the size of a fifty cent piece. Should have 3 of them. One of them is not closing and allowing the signal to go through. So turn up the t-stat to call for heat take each one of the limit switches and by pass them one by one till you find the one that is bad. Depending on where you hit the cover is where I would look first. The limit's are rated by temperature so replace with correct size. You should be able to see the temp. on the limit something like 180 is what you are looking for. Also make sure the wires are in good shape where they connect to the switches. Might have a loose connection. ken
Posted on Jan 03, 2009
SOURCE: Replacing a non-programable thermostat for
If you take thermostrat back off and connect the wires together will baseboard heater get hot. If not you may have bad heater. If it gets hot your new tstat may be bad. The way you have it wired is correct. Most line voltage tstats have a ground screw. Your 's may not but will work without one .
Posted on Jan 24, 2009
What is the thermal fuse temp in a Nutone 665rp heater?
Our thermal fuse blew as well, and my son was able to read the small print. Mine is a MicroTemp SRCAXK G4A01 TF 100, which according to the ThermoDisc website appears to have an open temperature of 100C (212F).
Dec 11, 2010 | Broan-NuTone 665RP Electric Compact Heater
I need a heating elament for my Braun model qtx100HL-A ceiling fan heater. I took it out and it is a 6260 eichen 120 v / 1425 watt
My Nutone Model 765HL uses the same heater; I tried the Broan-Nutone website but they were out of stock. Finally found it at Central Vacuum Stores for $35. Here's the direct link: http://www.centralvacuumstores.com/nutone/Broan-Nutone-Heater-Elements/QTXN-Series.php
Hope this helps!
Sep 06, 2010 | Broan-NuTone Heating & Cooling
Nutone, Model QTXN 100HL-A 1500 Watt Does not heat. Electrician said it was the heater part that has "6260 Eichen 04" on it. He said it was the diode. I would like to order the small part.This is a...
The "diode" that your electrician mentioned is actually a one shot thermal fuse.
You can either go to the Nutone website for parts, or remove the thermal fuse, extract the info written on it and buy a replacement. Mine was a 100C 10A thermal fuse. I got mine from DigiKey.
Mar 29, 2010 | Broan-NuTone Heating & Cooling
NUTONE HEATER PROBLEM
contact nutone. the problem is that the sensor that shuts off the unit to prevent overheating is too sensitive or faulty. nutone website seems geared towards selling their product so you may have to call them direct at 1-888-336-6157. this is customer support. good luck.6-6157
Mar 03, 2010 | Broan-NuTone N-668RP Combination Light Fan...
Nutone 665RP fan/light/heater all not working
Hunt for a tripped GFCI and push reset. The ground fault protected receptacle may be in a nearby bedroom, hall, or basement.
Dec 06, 2009 | Broan-NuTone N-668RP Combination Light Fan...
Can 2- 220 wall heaters be run off the same breaker
all depends on the wattage of the heaters. add up the wattage of the heaters divide that answer by 220 and that will give you your amperage draw, then you must size your wire, breaker and outlet accordingly. you can only load a braker to 80 percent of its amperage by the CEC.
Oct 14, 2009 | Broan-NuTone Nutone White Fan-Forced Wall...
Older Nutone bath- fan/light/heater Model #9111. Light works, fan and heater do not. Must I replace the entire unit.
Most of the time is is cheeper and less time consuming to replace the unit than to find what happen to it and then order parts to repair it.
Aug 28, 2009 | Broan-NuTone (8663RP) Ceiling Fan
Noisy, smelly fan in nutone heater
You should probably replace the heater motor. All the parts should still be available for you fan and it should only take a few minutes to change out.
Dec 07, 2008 | Broan-NuTone Wall Heater
Heating & Cooling Logo
420 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
