Question about Goodman GMS90703BXA Heater
I HAVE A GMPO5O-3, WHERE CAN I FIND THE FLASH CODE
  • 308 Answers
If you look in the little round window on the blower door you should be able to count the flash code from there. If your model does not have the codes listed on the outside of the blower door, then remove the blower door and check on the inside of door. Hope this helps
Posted on Nov 17, 2010
Fi code flashs 3 times...won't start
The three flashes indicate a fault code,are they three long or short flashes? A long flash is a ten and short is a one,so for instance if you have one long flash and two short ones that is fault code 12 if it was three short flashes that would be 3 ect... You will have to Google the fault code numbers to see what they mean ,ie fault code 21 could be oxygen sensor fault.
Sep 17, 2017 | Motorcycles
Can anyone help me? I own a pride celebrity lx8 scooter. It is beeping 3 and 1 or 3 and 2. What could this mean please? Many thanks R
Yes I done a quick search on the beeps it took me to the same fault codes as the book TRY SENDING AN EMAIL TO www.pridemobility.com.au....good luck..Hi again yes I just picked up the fault book and they call them flash codes I WILL CHECK INTO THE PROBLEM cheers. Hi 3 flash code unplug charger turn key of then back on again , 1 flash code charge batteries 2 code same as 1 charge batteries good luck
Jul 06, 2016 | Pride Health & Beauty
Meaning of fault codes vt commodore
no the code is not 1013
it should flash this same sequence 3 times (one flash small pause then 3 flashes large pause) and then repeat it if there is no other code. if another code is present then it will flash a different number 3 times and then start again with your original code.
DTC 13 - Right Hand (RH) Oxygen Sensor No Signal
Apr 28, 2014 | 1998 Holden VT Commodore
How to do a self diagnostics code test on a Chrysler Concorde LXI 2001
put key in ignition turn key to start position then off then to start then off then start and leave on. count the check engine light flashes. the first number will be a long flash then the numbers after will be short flashes, then a pause and then the next code will flash with the first number a long flash then followed by short flashes. count the flashes. if the first flash is a single flash and the next flash is say 3 quick flashes then this is code 13. these are a 4 number code system like 1013 is the same as a code 13. I hope you understand as its difficult until you get the hang of it. Chrysler has a code at the beginning to indicate codes starting and one at the end to indicated codes ending. and will repeat the cycle 3 times. it maybe easier to get them pulled using a code reader.
Mar 10, 2013 | 2001 Chrysler Concorde
It does not move but battery is not dead
Here is the manual for your chair.
http://www.pridemobility.com/pdf/Owners_Manuals/INTL_Jazzy/Australia/AU_Jet_3_Ultra_om.pdf
On page 33 are the table of fault codes your chair uses it displays these codes by flashing the battery condition meter lamp. Flash-flash-flash----flash-flash-flash----flash-flash-flash, which is a code three service failure. Normally when you get a service code failure its a good bet your controller going to cut off your motors. Get me the code and i will tell what i know about that code.
Aug 17, 2012 | Pride Mobility Jet 3 Ultra Power Chair -...
94 sunbird le with a flash code of 12
A code 12 on gm cars just tells you that the ecm diagnostic mode is working ok.It should flash code 12 3 times then if there are any codes stored it will flash the code 3 times and when it is done it will flash code 12 again.
Apr 20, 2012 | 1994 Pontiac Sunbird
1991 CHEVY S-10 4.3 2X2 AUTO TRANS, TRUCK RUNS GOOD BUT WHEN IT REACHES NORMAL OPERAING TEMP THE SERVICE ENGINE SOON LIGHT COMES ON
There is no way to tell what the light is for without scanning for trouble codes.There is a way to access the computer trouble codes without having a code reader. If you look under the driver side dash near the steering column, you will find the diagnostic port where you would plug in a scanner. If you look closely you will see that the terminals are identified as a,b,c, and d. Take a metal paper clip and straighten it out, then bend it into a u-shape. Put one end of the paper clip in terminal A, and the other end in terminal B. Now turn the ignition key to the on position, but do not start the engine. The check engine light will start flashing. This is how you will get the codes, by counting the flashes. The check engine light will flash the number 12 three times, to let you know that it's getting ready to flash a code. Let's say the computer has stored a code 32, and a code24. First, the number 12 will flash 3 times(flash-pause-flash flash). Then there will be a long pause. Then the computer will flash the first code, which, in this example, is 32(flash flash flash-pause-flash flash). It will flash the same code three times, then it will flash the number 12 again. After the third number 12 has flashed, the next code will flash, which is 24(flash flash-pause-flash flash flash flash). That code will flash 3 times. Then there will be a long pause, and the pattern will be repeated. After all the codes have been flashed, the whole sequence will be repeated, starting with the first code, and will continue as long as the paper clip is in the diagnostic plug. Write the codes down as they are flashed. If you get mixed up, just wait for the next sequence of the number 12 to flash, then start counting the flashes again. Believe me, it takes a lot longer to type all this out than it does to get the codes off teh computer. If you have any questions, let me know. When you have the codes, I can look them up for you and see what they represent.
Feb 23, 2011 | 1991 Chevrolet S-10
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Ford 2001 F150 pickup truck beeps approx 5-6 times every 5 minutes. Think i has to do with the airbag.
    Yes you are correct, it is an airbag problem./
    The Airbag indicator lamp is burnt out, and a flash code is waiting.
    Radio shack ( or similar ) should still have the replacement bulb for it.
    Once you put it back in, the airbag lamp will flash a code that is a number, t ( ie flash 3 times ) then another number ( ie flash 5 times ). You will need that code for the next step in the diagnoses. Don't be alarmed if you get 10 sets of 3 flashes, that is actually a LFC ( Light Flash Code ) 33
    Oct 11, 2009 | 2001 Ford F150 Styleside SuperCrew
    Code flash nokia n70
    Hi...
    Please let me know the Code to flash Nokia N70
    Thanks!,.
    Jul 19, 2008 | Nokia N70 Cellular Phone
    Goodman GMS90703BXA Heater Logo
    41 people viewed this question
    Top Goodman Heating & Cooling Experts
    Dan Webster
    Dan Webster
    paulcarew
    Brandon Berry
    Brandon Berry
    Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
