Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
There is no suction when using as an upright - Dyson DC07 Bagless Upright Cyclonic Vacuum
  • 694 Answers
Detach the hose from power nozzle and check PN for clog. This is the most likely problem if the accessory tools work with the vacuum.
Posted on Nov 13, 2010
Dyson hose does not produce alot of suction when extended.
Hi its Darran at Dyson.
It sounds as though the wand/hose is blocked. with the machine locked in the upright positino, remove the hose from the machine, switch on and test the suction. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If the suction is strong, you will need to check the wand for a blockage. If the suction is still poor, check the hose for a blockage.
You may find it useful to wash the filter as this can sometimes cause a drop in performance if its dirty and it wuold be more noticable from the hose.
I hope that this information is useful to you.
Kind regards
Darran
Dyson Customer Service
Feb 19, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Loss of suction when upright
Check the Rubber Air seals and bottom Hose for splits.
Feb 01, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No suction on wand of Dyson DC14 Animal
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
No suction when using the hose.
The beater bar is supposed to stop when the vac is upright. Sounds like you have a clog. There are several access points to check, fairly easy to clear obstructions.
Nov 14, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
After using my attachments I have a hard time getting suction when using upright again - how do I get the suction on my upright? It's a Hoover blue widepath Tempo~ thank you
It may be clogged underneath the vacuum where the roller is. Take the bottom plate off and look into the intake port. There may be some blocking the port.
Nov 09, 2009 | Hoover Tempo Widepath Upright Vacuum -...
My wind tunnelhas no suction when using the beater brush. Something is stuck. Can I fix it?
If the hose has suction in the upright position, and the floor has no suction in the normal use position, check for obstruction in the dirt path from the agitator cavity, thru the short hose, into the lower handle.
Oct 03, 2009 | Hoover U5753-900 WindTunnel Bagless...
Loss of suction when using upright. Suction remains for samll tools no suction when in upright position makes funny noise but ok when not used in that position kindest regards louis
u can remove the flexi pipe by pressing the inset button,it may be bit stiff if it had not being removed before.may be something is stuck at the bottom,also remove u bend where most of the stuff get stuck. i just posted how i fixed the suction and over heating problem. pl read it. good luck
Feb 08, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Connect or disconnect hose on upright vacuum
The hose has to be connected to engage the suction. To test this, is there suction in the hose when you turn the vacuum on? If so then the hose needs to be connected.
Jan 31, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
No upright suction
This means that you have something plugging the main camber where the dirt enters through beater bar head.check that out. biigg53566
Jun 24, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Eureka Boss - no suction in upright postion
when mine does that I find that the hose is not connected properly where it comes off to use the attachments.
If there is suction there, it is a straight shot to the floor unless it is loose where it fits together.
Jun 04, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
24 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
