Question about HP 9200c Flatbed Scanner
Black line scanning on digital sender
Hi There,
I have a problem with a black line being scanned down the center of all my documents I scan to myself. Where would I start to troubleshoot this problem?
thanks
Patrick
  • 4 more comments
  • patrickjp Jun 18, 2008
    thanks!
    I'm putting it through the feeder
    nope, it must be something in the feeder?
  • patrickjp Jun 19, 2008
    Ya know.. when you open the top (when the feeder is) there's no glass visible. Just 2 plastic strips the feed the paper and then the rollers.
    Is there another way to access this?
    that did it!!! thank you
    rtfm from now on!
  • brian c
    brian c May 11, 2010
    OK, that narrows things down a bit. Do the lines also appear when placing the original on the scan glass?
  • brian c
    Although I am not familiar with that particular model, they all use the same theory.
    Are you placing the document directly on the glass, or using an automatic document feeder (if this even has such an option)?
  • 589 Answers
Yes. There will be an access cover / lid where the document goes in.
Open the cover, and you will see a thin glass, called the 'scan glass'.
Look in the middle of the glass. You will most likely find a glob of white-out, or ink on it.
Use rubbing alcohol to clean off the culprit.
Welcome to scanner / fax / copier troubleshooting 101!
Posted on Jun 18, 2008
Line going thru scanned document left of center.
clean the slit glass the one which is next to the large glass
Jan 10, 2014 | Konica Minolta Bizhub 362 Copier
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
I have a line that runs down the center of all the documents I scan. What can I do?
On your scanner, there is something (dust?) that is blocking that part of the scanner from scanning that column on the scanned document. Clean the scanning-head.
Jun 08, 2011 | Canon DR-2050C Path-Through Scanner
We have a black line down the center of all copies...
If the problem only happens on copies or sent faxes then no it is not your drum. There is something on your scan glass. My guess is you are getting the line on your copies when you run the original through the document feeder. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on
May 20, 2010 | Office Equipment & Supplies
I can't find where the documents go after i scan them to the pc from my 9100c digital sender
Next time you scan, select the Save As feature, you should be able to see the default path using the Save As.
Oct 30, 2009 | HP AutoStore HP Digital Sender 9100C...
Black line on scanned document
Please clean the glass with Isopropyl alcohol. Dont use solvents.
S. Mohan
Mar 27, 2009 | Canon DR-1210C Scanner
Line on scanned documents
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 20, 2009 | Brother MFC 7420 All-In-One Laser Printer
Black lines
Not sure what you have tried but if there are no lines when printing but there when scanning there is something on the scanner. Could be something as small a single dot of dirt and it will put a line down the whole page. Try cleaning the glass.
Dec 13, 2007 | Office Equipment & Supplies
Scanning document leaves streak down right hand side
Even a single grain of dust or a single strand of hair on the scanning glass will cause the scan head to perceive ink/image where there is none. Deffinetly try cleaning the glass using a good window cleaner, and a cloth that is completely clean, or even a peice of newspaper. If the black line remains, I would suggest taking it into a service center to have the scan head itself cleaned.
Dec 05, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP 9200c Flatbed Scanner Logo
756 people viewed this question
Seeker5211
Seeker5211
Ben Johnson
