Question about Maytag PYE2300AY Electric Dryer
Have an upsidedown F5 error on my MDE6700AYW Neptune dryer. cleaned out all the lint trapped in blower and lint trap. still have error. is it the thermistor? If so where is it located and how do I clear it
    President:
  • 2,468 Answers
Your temperature moisture thermistors are on the blower wheel housing they are about an inch round and have small connectors on them and the sensor face it in the housing to detect temps/moisture,you can unscrew them with a 1/4" hex nut driver
Posted on Nov 29, 2010
Forgot lint trap, dryer making noise immediately after. Cleaned vent and blower wheel and housing- still making noise. What else could it be??
If its like a grateing metal on metal it sounds like the rear bearing has worn through which is quite common.
hope this helps a bit
Jun 24, 2016 | Dryers
Tip
How to Fix Dryer Lint Problems
<span>Instructions</span> Things You'll Need: <ul> <li> <span>Vacuum cleaner</span> </li> <li> <span>Screwdriver</span> </li> <li> <span>Electric leaf blower</span> </li></ul> <ol> <li> Remove the lint trap from the dryer and peel off the accumulated fuzz.<br /> </li> <li> Vacuum the top of the dryer, the floor nearby and underneath for lint at least once a week. When you remove the lint trap, tiny particles fly into the air and settle nearby. Behind and underneath the dryer are favorite hiding places for dryer lint.<br /> </li> <li> Disconnect the vent tube from the rear of the dryer and inspect it every month. Dryer lint accumulates more easily in flexible plastic tubes than rigid aluminum ones, because curves halt the lint's path.<br /> </li> <li> Clean the vent tube leading to the wall annually. As for the tube leading to the exterior, a trick that sometimes works is aiming an electric leaf blower down the tube. The leaf blower can expel the lint through the exhaust on the exterior. Before using the leaf blower, check that all duct work is fastened securely.<br /> </li> <li> Unscrew and remove the back panel on the dryer, if you're mechanically inclined. Particles that escaped the lint trap can accumulate inside the dryer cabinet, so vacuum this area.<br /> </li></ol>
on Jan 04, 2011 | Dryers
Csn you remove trap where lint filter goes
How To Clean Your Dryer's Lint Trap, Screen And Vent ...
greenlivingideas.com/2014/08/14/clean-dryers-lint-trap-duct-screen/
Aug 14, 2014 - Cleaning your dryer's lint trap, screen and vent is a great way to keep it using energy efficiently. ... (Of course, if you can hang your clothes to dry, you'll not have to go ... Now use the vacuum to remove any lint from the lint trap.
Stackable Dryer-Lint Screen-Where is it? - YouTube
? 3:09
https://www.youtube.com/watch?v=-qu0OF9V2vA
Dec 27, 2011 - Uploaded by OcRefrigeration & H.v.a.c.
This Video Shows Where a " Lint Screen " is in a Stackable Washer Dryer and How to Remove it. Clean it ...
How to Clean a Dryer Lint Screen ' Cleaning Guides
www.howtocleanstuff.net > Cleaning Guides
Jan 11, 2016 | LG DLE5001W Dryer
The lint trap on my GE dryer is moist.
Check the venting, if it is blocked or if the venting is bend it will not allow the moisture to leave the dryer and it will end up in the lint trap and on the door
Jul 26, 2012 | Maytag Neptune MDG5500AW Gas Dryer
Noisy dryer after cleaning lint
There is something caught up in the blower wheel. You will need to disassemble the dryer from the front to be able to get to the blower wheel housing to clear what ever you have jammed there and remove it. Everything is done through the front.
May 31, 2010 | Maytag Dryers
Dropped pen into lint trap. Now Dryer makes a screeching noise.
The pen has fallen into the blower housing and is hitting the fan blades.
Unplug the dryer!! Remove the two screws at the top of the lint trap. Remove the rear panel. Remove the four screws at the bottom that attach the lint filter housing to the blower housing. Then, remove the pen from the blower housing.
Apr 06, 2010 | Kenmore Dryers
Lint trap
http://www.pcappliancerepair.com/model-display.php This will show you how your dryer is put together. The lint has gone directly to the fan, where it could affect fan performance. You would have to remove the front off the dryer, and the cover off the fan area. It's not a bad idea to clean this area once in a while.
May 11, 2009 | Maytag Neptune MDE4000 Electric Dryer
How do I remove the lint trap holder to clean out the lint inside
The font panel must be removed. This may be done by removing the control console (open upper cabinet doors to find screws behind the console). The screws along the top of the lower front panel are easily accessible. Disconnect the two interlock switches, remove the grounding clip attached to the bulkhead & lift the panel off the two lower clips. Inside the panel is a housing that leads to the exhaust blower. It will be packed with lint that may be hardened like papier mache. Just clean out the mess & reverse the process to replace the parts.
the
Jan 21, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Maytag neptune dryer wont restart mde 3000 aya
Your dryer needs a new motor. It should cost about $200-250 including labor. Call a local repairman - not a national company. Give him the model number and ask him to bring the motor with him.
Mar 31, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
168 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
