Question about Canon FAX-B160 Plain Paper Bubblejet
Language change How can i change display language to English for Fax B160
  • msuwinda Jun 26, 2008
    Thi is not an answer of the qes it is another question like that
  • fconde Jul 21, 2008
    HOW DO I CHANGE THE LANGUAGE FROM FRENCH TO ENGLISH NO STEP TAKEN YET
How do i change the languange on my phone from spanish to english?
Posted on Jun 23, 2008
I have a Canon MX360 printer, copier, fax, scanner. I set the wrong language, and want English. It also will not go online. How do I change that?
see the following Canon article.
Change the MX360 LCD display to English or desired language
An Unintended Language Is Displayed on the LCD
Select the language you want to be displayed according to the following procedure.
  1. Press the <COPY> button, wait approximately 5 seconds.
  2. Press the <Menu> button three times.
  3. Press the r_mark_s.jpg button one time, then press the <OK> button.
  4. Press the r_mark_s.jpg button repeatedly to select the rightmost menu.
  5. Press the l_mark_s.jpg button twice, then press the <OK> button.
  6. Press the l_mark_s.jpg r_mark_s.jpg button to select the desired language for the LCD, then press the OK button.
    The desired language is displayed on the LCD.
  7. Press the <Stop> button.
Nov 03, 2014 | Office Equipment & Supplies
How to change language on Brother FAX-930 . I have on Fax Germany language , buth I need english . Can I do it ?
  1. Turn off the P-touch.
  2. While holding down the Shift key and the "R" keys, press the On/Off key once and then release the "Shift" and the "R" keys.
  3. "English" should be on the display and then press faq_ans_70_return.jpg.
    If "English" did not display, repeat steps 1 thru 2.
  4. "inch" will be on the display, press the "Enter" key.
  5. Set the Date (MM/DD/YY) and Time (hh:mm)
Still having Problem Then follow Us For Brother Printer Support
Feb 19, 2014 | Brother FAX 930 All-In-One Thermal Printer
Change langage
Display Language
You can select either “English” or “Spanish” as the display language. The factory
preset is “English”.
• If you select a language you cannot read, change the display language again
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [up]
or [down], then press Select.
3 Scroll to “Change language” by pressing [up]
4 To change from English to Spanish, press
Español.
To change from Spanish to English, press
English.
• The display changes to the selected language.
• You can also select a language by pressing [up] or
[down].
5 When Spanish is selected, press Salvar, then press [OFF].
When English is selected, press Save, then press [OFF].
Jan 05, 2010 | Panasonic KX-TG2356 Cordless Phone
Change language to english and my fax machine
You have to go into fax Setup, there, you should find menu's to alter lanuage and anyother small alterations
Nov 14, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon JX200 language reset
Press the dataregistration button to display -usersettings-Press the # button 1sssw will display scroll down with the arrow buttons untill clear is display press ok and do printer clear.It will do a start up and ask for language reload all your default settings.Make sure your tone and pulse dail is set correctly.
Aug 17, 2009 | Canon FAX-JX200
How to change language display
there will be problem with machanism............... there is no any option for change language
Sep 12, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
Canon Fax B160 sending fax troubles
The fax transmission speed was set to 14400, we have solved the problem by putting down transmission speed to 4800 and now emission works without troubles.
Mar 03, 2008 | Canon FAX-B160 Plain Paper Bubblejet
Canon FAX-B160 Plain Paper Bubblejet Logo
202 people viewed this question
old marine
old marine
