Question about GE DCCD330EDWC Dryer
How to bypass coin-op mechanism (the coin-op mech is missing, can I save money by not purchasing it) ?
I just purchased a GE DCCD330EDWC 7.0 Cu. Ft. coin-op dryer without the coin-op mechanism. I am wondering what trouble I would need to bypass the coin-op mech. The salesperson thinks that the unit will only run for 20 minutes at a time and that even if I tore down the coin-op housing to find a mechanical switch in there that I would need to press it once every twenty minutes in order to dry clothing. He also stated that the switch is buried inside the unit and that it can not be accessed easily.
If it is possible to press the switch six times and have the unit run for 120 min, I think it would be worth tearing in to find the switch. If I somehow need to press the switch once every twenty minutes then things are starting to get a bit more complex...
5 Suggested Answers
  • 3 Answers
SOURCE: ge dryer
i built these machines... before doing anything ...check your fuse box or breaker .... 240 v .... it goes out often ... if its not that ... its probably your element ... ...open your door and on the top of the opening ... there 2 screw ... take the top off then the front ... 2 other screws ...take out drum ...and check element ... its about 60 for a new one
Posted on Nov 30, 2007
SOURCE: GE clothes dryer,model DPXR483EA1WW
Well this morning I got up and pressed the start button on my dryer and it's been working eversince. Thank-you I will contact you if I have any more problems. Jessica
Posted on Jul 18, 2008
docjohn174
  • 943 Answers
SOURCE: DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Posted on Sep 27, 2008
SOURCE: GE Dryer smells like its burning
the burning smell may be caused by a belt some have a look at the belt
Posted on Mar 07, 2009
  • 532 Answers
SOURCE: dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Posted on Apr 22, 2009
HOW CAN I FIND A UNIVERSAL COIN BOX FOR GE COMMERCIL DRYER?
Most Appliance part stores can get you a coin box. If you have none local, google one of these sites and they can help.
V & V appliance parts
Repair clinic
Marcone appliance parts.
Sears appliance parts
Feb 21, 2015 | GE Commercial DCCB330EJWC 27" Coin...
WHERE CAN i BUY A KNOB FOR GE 3-CYCLE EXTRA LARGE CAPACITY GAS DRYER?
You can try an appliance parts dealer or maybe one of the online sources
Jan 05, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Purchased a damaged GE dryer. Model and Serial number removed.
Model tag is inside door frame or at the bottom corner on the side. It may have been removed or not replaced if the front panel was replaced, Eric
Jul 07, 2009 | GE 5.8 Cu. Ft. 2-Cycle Extra-Large...
Timer for DDE7200RALWH
HI. the (WE4X795), will not work in this unit but, i have located a compatible timer module that will work. Simply click on the link provided below to be directed to the purchase page for your replacement timer. You can order on line on this site as well.
Click here.
Jun 17, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Coin-op dryer: changing the length of the cycle
that is correct, there a re multiple "cams"/discs that will increase/decrease times, they should be inside the lock box atop the machine, they come with the unit when delivered and that s the likely storage spot for them
Mar 25, 2009 | Whirlpool ET8CHEXSQ Dryer
I have a coin op dryer modle cem2760kq0 i put im a new timer in but it dose not stop runing?
mechanical coin op timers come without the shut off cam installed
there are slots around the edge corresponding to different times, that take a pin cam. the pin cam is in the box for the installer to insert to the owners specification, between 24 and 60 minutes in 6 minute intervals usually, hope you retained the packaging, or the old timer which should have its cam pin still in it
electronic coin op timers have to be programmed
Aug 28, 2008 | Whirlpool Dryers
Ge Commercial Coin-Op Dryer.
When you replaced the motor, did you replace the relay? It sounds like you have done everything reasonable. I would try bypassing the coin operation part and see if that changes anything. Go back to the motor relay. It may be incorrect application. the part guys only know what the computer tells them. it may need a different one. I am assuming that when the unit shuts off you checked for power from the timer to the next place, according to the diagram.
Mar 13, 2008 | Dryers
Dryers Logo
178 people viewed this question
Top GE Dryers Experts
Richard Roth
Richard Roth
Melissa Martin
Melissa Martin
ancel1961
Level 1 Expert
Are you a GE Dryer Expert? Answer questions, earn points and help others
