How to reformat the protected CD / DVD ?
Hello Sir,
pls teach and advice me use what mathod / sofware to format CD / DVD dis ?
Many nthanks
Sidney
  • eyelash0619 Jun 18, 2008
    Hello Sir,
    pls teach and advice me use what mathod / sofware to format USED / PROTECTED'S CD / DVD dis ?
    Many nthanks
    Sidney
  • eyelash0619 Jun 19, 2008
    Hi lafalot, When I start using recycle CD disck to burn or format. ( inside contian some unknow programe ) the dilogbox open and indicate this disck was protected unable to burn, please insert blank disc in CD drive (D:)
    pls teach and advice me use what mathod / sofware to format or to burn the USED / PROTECTED'S CD / DVD disck ?
    Pls advice
    Many thanks
    Sidney
    Scholar:
  • 152 Answers
You should be able to format a CD/DVD directly through Windows without additional software. Try one and let me know how it goes.
Posted on Jun 18, 2008
HELLO I WANT TO REFORMAT MY SAMSUNG N110 TO FACTORY SETTINGS
pls insert the samsung operating system cd and restart the pc then repeatedly press F12. Then select boot device menu and then select CD/DVD ROM. Select Format the Partition and then select Windows. It would take 1 hour to finish installation in factory settings
Feb 19, 2011 | Samsung N110-12P Notebook
How to reformat my thomson 6675 because i lost all the files and i cant reformat using windows 7
hello, you need to check your BIOS setting.Before you format,you must make sure that your CD OR DVD DRIVE is above your hard disk.Then get a window 7 formatting disk and format.This should work
Nov 18, 2010 | Computers & Internet
I am format my hard disk{verbatim 250gb model #47562)now he not support with my dvd player. there showing file not available. so i need softwear
it is not a sofware problem... if the disk was recognized before.
try reformatting the disk and select fat32 as file system. do not chose quick format.
try again to connect to dvd player.
regards,
paolo.
May 21, 2010 | Verbatim SmartDisk Firelite Portable USB...
Problem with bio protection in acer aspire 4736 with win 7.
You may have not removed all files....I assume you used the"Uninstaller"? If so there may be files left in registry causing the prob. If you are not expert with registry editing then find someone that is and delete all files for this sofware and try a clean installation.
Mar 05, 2010 | Acer Aspire 5735 Notebook
Write a DVD movie files from HaraDisk
hello, try to use another brand of dvd disc, and see to it that your copy is not protected because some studios probably who took your video have protected it so that you cannot reproduce. its part of a business bro.
Aug 10, 2009 | LG GMA-4020B Super-Multi...
How to transfer hi-8 tape to cd or dvd pls teach me
You can set the date and time by following the steps in the instructions manual which can be found by following the link below.
http://www.retrevo.com/support/Sony-CCD-TRV68-Camcorders-manual/id/763dj989/t/2/
Hope it helps,
~regards,
Jegan
Jun 03, 2009 | Sony Handycam CCD-TRV68 Camcorder
Remove Write Protection
Try this,
1.
Check out if the USB drive has a small swich for write protection. If its there try toggling the switch.
2.
Windows can all write protect flash drives. Check out this registry path,
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
You may find a key here on the right side by the name 'WriteProtect'. If it's not there this would not be the cause of problem. If it's there, make sure that the value is 0.
Please let me know if this does'nt work.
Nov 06, 2008 | Transcend (589307) Media
Burning cd,dvd wid password..
The cd\dvd or any other removable media is designed for transporting data from one place to another to work on diff machines.
So the normal data can be accessed every where.
U cannot password protect the cd, not so far.
If u dont want to compress using winzip/winrar & set passwords
There are some encryption tools that allow u to make a keydisk that u can use so that only with the keydisk the files can be read
Jun 27, 2008 | Ahead Software Nero Express 6.0 (NERO6OEM)...
CD key
this is either because of corrupt software or invalid key or expiry of serial key...
U need to download sofware or serial key respectively from the free website(search in google)
Mar 01, 2008 | Computers & Internet
Reformats
1. make sure you backup ALL data you want, after a format it is un-retrievable without the right tools
2. put your windows XP disk in the cd drive, and turn on PC
3. when it asks "Press any key to boot form CD" hit a key
4. a blue screen will appear with writing flashing down the bottom for a few minutes until you come to a menu
5. press "enter" to start a install
6.press "esc" when it asks if you want to repair old installation
7. highlight the relevant partition and press "d" to delete old partition, then "enter" then "L"
8. it will not go back to partition menu, in which case you select "C" to create a new partition and then "enter" and "enter" again
9. select "format the partition with the NTFS file system" it will now format the hard drive, then copy files, restart by itself then begin the second part of the instiallation which im sure you could manage
Dec 30, 2007 | Computers & Internet
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
