Question about Eureka Vacuums
Is there a way to remove the bottom rotating brush from the vacuum itself? (Eureka amps 12)
    Novelist:
  • 147 Answers
Yes. but without more information about your vacuum I cannot tell you how exactly to remove it.
if you could get the model number off the back of the unit or the bottom of the unit it would help more.
Thanks.
Posted on Nov 13, 2010
Spinbrush not working on eureka as1104
If the belt is intact, the brush roller ends may be so jammed (usually with hair) that it cannot rotate. Also, if the brush roller cannot rotate, the motor shaft may be rotating in one spot on the belt and eventually will burn it out. The solution in the case of the brush roller is to remove it and check for free rotation. If the ends are binding, the brush roller will have to be disassembled to remove debris.
Aug 10, 2014 | Eureka Vacuums
The brush doesn't rotate.
replace belt for the brush to work!! it may be broken or the wrong size belt. if you remove bottom part, then you can replace belt. have a good day!!
Oct 21, 2010 | Eureka 5849A Boss Bagless Upright Cyclonic...
I have a Ultima 12 amp e10071, The brush is not turning, there is tension on the brush as if the belt is connected but still there is no rotation. The motor does run. How cani open the vac to take a...
You get to the belt & brush roll area from the top. On the hood of the vacuum, right behind the word Altima, to the right & left sides, you will see a screw. Remove them, lift off plastic hood. Check belt if broken or just stretched too big to catch brush to turn it. Check ends of brushroll for any hair, thread buildup & clean it. See if end caps turn easily. If one or both ends do not turn easily, the brush roll would need to be replaced.
Eureka Brush roll part # 62365-3
Eureka U belt part # 61120D
Sep 01, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Change the belt
Hi There,
Here's how you can replace the belt on your Eureka SmartVac 4870. I have taken pictures of the repair to help you better with this.
Here's what you'll need in order to complete this repair:
- Eureka Style R Extended Life Replacement Belt, Part 61110
- Eureka SmartVac Model 4870 Roller Brush Assembly, Part 61520 (Only if the brush no longer spins, or the brushes are worn out)
- Phillips head screw driver
Step 1. Turn the vacuum upside down so that the brush roller is facing upwards. Unscrew the three screws that I've highlighted in red.
Step 2. Remove the bottom plate after unscrew the three red highlighted screws. Once you remove the bottom plate, you'll have full access to the roller brush and belt area. Remove the roller brush by pulling straight up on the roller brush itself. Discard old belt, and test roller brush to ensure that it spins freely by holding the very end of each side, also called the bearing caps with just your finger tips. Try spinning the brush with your thumbs. The brush should spin several times around with each spin. If you notice the brush doesn't spin at all, or if you feel some resistance when you spin the brush, this means that your bearings are either gone, or will be soon. It may be time to consider a new roller brush at this time.
Step 3. Remove the new Eureka Style R belt from the packaging, and wrap one end around the the metal pin, on the opposite side of the roller brush. This pin is actually the motor shaft that spins the belt, which spins the brush.
Step 4. Wrap the other end of the belt through the side of the roller brush that has the pulley, and use the roller brush to stretch the brush roll back into the agitator housing. Make sure the end caps fit in the housing correctly by making sure there are no gaps between the roller brush housing and the end caps of the roller brush.
Step 5. After reinstalling the roller brush back into the housing with the belt attached, pull the belt forwards towards the brush. The brush should spin when you do this. Make sure that the belt is not pinched underneath of the roller brush or this will cause the belt to break immediately when you turn the vacuum back on.
Step 6. Reinstall the bottom plate, making sure that the little notches on the front end of the bottom plate tucked underneath of the reverse notches on the bottom housing of the vacuum cleaner. Tighten all 3 screws back into the bottom plate. Make sure the vacuum is set to carpet mode, and turn the vacuum on.
If you have any questions about this repair, or if you notice that the roller brush stops when the brushes hit the carpeting, please just use the clarification request form here on the Fixya repair page. I will then be happy to walk you through a little more advanced repair of replacing the clutch in the Eureka SmartVac that controls the rug/floor switch. Most of the time though the belt will be all the vacuum needs.
I hope that this was helpful information to you. If this helped you, please be so kind and rate the repair as helpful by clicking on the thumbs up icons in the top corner of this repair.
Thank you very much,
Chris J.
GoVacuum
Apr 04, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
Not picking up. suction okay on tools. I think belt is broken but how to get to it and change it?
Turn it over, with a phillips screw driver, remove the 5 or 6 screws that hold the bottom on. (Yours MIGHT be held on with clamps) Point is, remove the shoe that covers the brush. When you get it off, you will see whaat to do.
Nov 01, 2009 | Eureka 12 Amp Capture Vacuum Upright...
I have a Eureka Altima and not sure how to change the belt?
1) Use handle release to lower handle
flat onto floor
2) Remove 2 screws from the front side of
brush roll cover
3) Lift and remove brush roll cover .
4) Remove brush roll and belt. Thread
new belt around motor shaft and
brush roll
5) Insert left end of brush roll first. Make
sure square on brush roll cap is in
place. Pull right side of brush roll to
stretch belt. Secure right end cap into
base.
6) Rotate brush roll 2 turns to center belt.
7) Replace brush roll cover
8) Replace 2 screws
And you can get the maual here.
http://www.eureka.com/service/manuals/80244.pdf
Good luck
Sep 27, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Roller brush will not turn on Eureka "The Boss Power Plus" 12 amp
Depending on the model there will be a couple of screws on the top plastic cover. The cover lifts off and the belt is then serviceable. On some models you will need to remove some parts on the bottom too to get the roller out.
In any case just look for screws that hold the covers on and explore a bit. You can't break anything.
Jul 30, 2009 | Eureka Boss SuperLite Bagless Upright...
How do I to change the belt on an eureka altima 12?
the belt is on the bottom right (looking at it from the front). the Eureka website does have the manual for download, http://www.eureka.com/service/manuals/80244.pdf
With the vacuum flattened (straightened) out, turn it over and remove the back roller cover, (2 screws) once off, the roller should just pop out on the opposite side (opposite from the belt). Don't forget to turn the roller to center the belt once you have it on.
Jun 14, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Have eureka 9734 replaced belt, put back together,brush rotates well but vacuum is not picking up anything, no suction.
It sounds like the machine is clogged. Check the port behind the belt and any and all hoses for obstructions and remove.
Apr 13, 2009 | Vacuums
BOSS 5851 Wide Track, 12 Amp
The top comes off to get to the belt and brush roll. Did you check the brush roll to make sure that the ends turn freely, or is one not turning, the belt is a lon life "U" part #61120A. The brush roll is what drives the vacuum, but if brush roll or belt is bad, then it won't drive it.
Feb 03, 2008 | Eureka 5849A Boss Bagless Upright Cyclonic...
Vacuums Logo
26 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
