Question about Health & Beauty
Ilet chair set for 4 month is the battery still good
  • 280 Answers
With power wheelchairs letting the batteries sit for 4 months without charging them leads to early battery death. The lead plates inside the battery sulfate over time and the battery discharges. If the batteries were fairly new (less than 1 year) before they sat for 4 months they can be resurrected and recharged but may not hold a charge very well. Distance traveled will be very reduced. You can try removing the dead batteries from the wheelchair and charge each individually with a 12 volt battery charger set to deep cycle. You will be able to see if the batteries come back up to full charge and do not burn. They cannot be recharged easily or safely inside the equipment and the charger that came with your equipment will not turn on. They should be removed from the wheelchair first. If the batteries take a charge and the PWC runs plan on using your power chair charger on them for at least 12 to 20 hours to bring the charge back up. Test the batteries over a short distance so you don't get stuck far from home. If you don't get very far before the batteries quit, invest in some new ones. Hope this helps.
Posted on Nov 13, 2010
My batteries in my jazzy select gt power chair are dead can I buy used ones?
Not a good idea to buy USED power chair batteries. Even new ones just have a 3-4 year life span. But yes, you can buy used batteries.
Feb 04, 2013 | Pride Mobility Products Health & Beauty
O have a Pronto M 41 and was bought in 07 but am having problams with turning on and shutting off.Could you tell me what it could be.
Have you replaced the batteries ever? I was told by my local Invacare vendor that the batteries are only good for 12-18 months. My mom's Pronto M41 was having battery problems and replacing both batteries solved the problem in her chair bought in 2007. Now she is looking to buy a slightly used chair (4 mos old) from the family of a deceased friend and there seem to be issues with the batteries in this almost-new chair.
Sep 11, 2011 | Electric Mobility Invacare Pronto M41...
My chair has been sitting for 4 months in garage. Chair MPV5 was rarely used. When charging, battery charger indicator shows green light. Chair still does not turn on. What should I be doing?
Replace the batteries and charge before use then charge nightly for 20 days Use the chair daily so you can get a good charge nightly to get the batteries operating at 100% After the 20 days If you don't use the chair daily always store fully charged and then charge once a week overnight. Should work fine once you get the new batteries in You will need to get 2 U1 batteries for your chair do not get Wally World or automotive batteries You must replace with sealed deep cycle batteries made for power chairs Hope this helps
May 07, 2011 | NRS Hoveround MPV 5 - Used Power...
My Hoveround MPV5 batteries will not charge, do you think it is a battery problem or a charger problem?
If you plug the charger into the wall, turn on the power switch and the light comes on, the charger should be working properly. Here is a way to test it-
Attach the charger that came with the power chair to the power chair controller firmly and turn the power chair on, while the charger is running. What should happen:the lights on the controller will scroll back and forth. If this does NOT happen and you can confirm the charger is turned on, the charger handle is fully seated inside the controller receptacle and the wall outlet has power, then the charger may have a problem and needs to be replaced.
If the charger is OK, then there may be a problem with the batteries. Here are some sypmtoms:
1-You connect the charger but the light on the charger never goes red, it just stays green.
2-You connect the charger but the light goes from red to green VERY fast.
3-The charger light goes from red to green but when you disconnect the charger and press the power button on the controller, you only have one flashing red light, or the batteries drain within just a few minutes of use.
4-The power chair has been stored or sitting idle for several months.
5- The power chair has been connected to the charger 24-7 for several months.
Any of the above examples indicates that the batteries are oxidized or damaged and will most likely need to be replaced. The MPV5 takes two, U1 12 volt 33 amp batteries which can be purchased at any battery warehouse store like Interstate Batteries or Batteries Plus.
Nov 30, 2010 | NRS Hoveround MPV 5 - Used Power...
I had not used the chair in 2 months, when i charged the battery in my electric wheelchair, the lights near the top of the joy stick shows its fully charge, but when i unplug the cord, it go's...
Yep It sure does Why didn't you charge the chair for 2 months? Charge at least once a week if you don't use it daily. Always break in the new batteries by using the chair daily for 10-15 days charging everynite then charge once a week if it sits for that long without use. Always put up fully charged. Do this and your batteries should last 3 -4 years Charge overnite if you use daily and never charge more than 24 hours Good Luck
Nov 15, 2010 | Electric Jazzy 1115 Power Wheelchair
What are the Best replacement batteries for the Jazzy Select 6 and Where is the best place (retail store or online) to buy them? I bought the U1 Gel Batteries at wholesalebatteriesonline.com and they...
ggirl why did you buy a pig in the poke they should refund your money because the batteries should have a six month warranty. Now always ask for the date code on batteries you are buying they shouldn't be any older than 4 months old. There are good batteries out there but if I offend anyone I'm sorry but MK batteries are very good also Interstate batteries and probably others that I'm not aware of. The best way to insure good batteries are buying fresh batteries, Charge them before you use the chair and always get into the habit of charging overnite if you use the chair daily. Never leave the charger plugged in more that 12 hours and if you don't use the chair daily charge at least once a week and always put up fully charged. Mk recommends charging the batteries daily for the first 20 days. Never run the batteries or let them fall below the red light on your battery level indicator. Your chair runs on about a 5 volt range (26-21 volts) after that the red light blinks like crazy. If it falls below 20 volts the charger will not charge the batteries. If you take care of them they should last you 3 years or more. Hope this helps
Oct 19, 2010 | Pride Jazzy Select 6 Indoor Power...
Will not hold charge for long - batteries good
NOTSOBRIGHT How old are the batteries? If they are good then your problem is with the charger. Remember you can have a good battery and a weak battery even if fairly new. The good battery will only go as high as the bad battery ie if after charge both batteries read 13.2 volts but once you put a load on the batteries (start driving) the bad battery will quickly drop to 11.8 volts and the good battery will also drop to that voltage. Your chair is a 24 volt system but the range where the chair operates correctly is only about 4 volts at 22 volts or so the lights will be almost in the red and the chairs performance will slow down. Hope this helps
Sep 21, 2010 | Jet 3 Ultra Power Chair
Why would my less than 2 months old batteries die after 15 minutes run time?
Has your power chair been stored or not used in a while? Have you been charging the batteries regularly? Is the charger plugged in to a working electrical outlet, turned on and plugged into the power chair properly?
If the batteries have not been maintained properly, they may have become damaged that will prevent them from getting a full charge. It can happen quickly, even in as little as 1 month of storage.
When you operate the power chair is there any noise or vibration that could indicate a mechanical problem?
If you continue to have a problem, contact your dealer or manufacturer. If your insurance paid for the power chair, they may pay for repairs. Warranty may not cover repairs caused by customer neglect.
Aug 06, 2010 | Ctm HS-2800 Power Wheelchair
Jazzy 1103 will not charge. Power cord and electrical outlet verified good. Plug in chair for charge, the ammeter indicator bar remains at 0, even after several minutes. If chair is powered on (while...
The battery charger is only made to last 1 year if you
re lucky. They are all made in China very cheaply and some only last a matter of months. If you are on Medicare they will replace the charger if necessary after a year. Good luck, hope this helps
May 15, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Battery will not fully charge but will run with partial charge
Two things can be wrong, first your batts may be old and need new ones. Have them load tested at an auto part store. Most powerchairs use two 12 volt batts. If you batts are good you should have between 12.5 and 13.5 volts on a surface charge and 11.5 to 12.5 on a load test charge. Second, if you had your chair stored away for a couple of months then your batts died and need to be replaced. If you are luck a "boost charge" might work. If you are planing to keep it stored for months at a time, you must charge the chair once every couple of weeks to keep batts fresh.
Mar 21, 2009 | Jet 3 Ultra Power Chair
Health & Beauty Logo
79 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
