Question about Gateway FPD2275W LCD Monitor
Gnr ts700 Screen has gone to the Middle Of the monitor
Hi my monitor was working fine , Then today , everything has gone to the Middle of the Screen. And sort of gone bright. I have try another monitor on the computer and the computer is fine. When the gnr Monitor Is on everything in the middle of the screen, and half of the left side Is Black. When i first switch the pc On the screen is fine, when Loads, and if i go into the bios Is fine. Soon as windows xp Logo comes On , it all shifts across. Can any One Help with this . Thanks
    New Friend:
Vdv.Reparaciones.Madrid
The problem is nothing that you can solve just openning the monitor case.So i just want to let you know that is not just a driver gone missing or a bad cable.Unless you have a frind or someone that knows how to fix it i suggest you take it info store to repair it.I can tell you tho that the power is fine so as the display.The problem is very simple but you have to know what you are doing.If you take it to repair shop let them know that a piece on the board that they need to change and it cost more or less from 2-4 Euro.I dont know in dollars how much it can cost but not more then 5 dollars.So a fair repair shop will ask you about 15-20 dollars or so.If they say more i suggest you buy a new or used one.Any questions send mail to vdv.reparaciones@hotmail.com
Posted on Feb 24, 2013
    Scholar:
  • 152 Answers
Did the other monitor have the same problem or was it ok? If it's just the one monitor, it may be on it's way out. It is very dangerous to open a monitor and try to repair it. Don't do it yourself unless you know exactly what you are doing. Have you installed anything new in your pc? What about seeing if there is an updated driver for the monitor? The monitor's website - support page - should have a driver update. See if that works. If you recently installed a graphics program, it could be a setting there that is messing things up.
Posted on Jun 18, 2008
GNR TS902W monitor start up problems
GNR TS902 19 inch flat screen computer monitor with 3x4 aspect ratio
Difficult starting or completely dead:- (This is a 'Stock Fault' with these otherwise excellent monitors)
Check or replace the electrolytic capacitor C829 - type 1000MFD 16 Volt DC Wkg It sits on the PSU board next to an empty "C817" mounting point (which is for a device wired in parellel) so you can fit two smaller ones (of ~ 500MFD each) . . I suggest replacing it (C829) with a 1000MFD 25 VoltDC Wkg type.
Also (very much less frequently) capacitors C802 - 470MFD 50V VoltDC Wkg and C819 680 MFD 16 VoltDC Wkg are faulty.
Jul 08, 2014 | GNR 19M1 19" LCD Monitor
Tip
How to enter Factory settings on GNR TS700 (Black/Silver) 17" LCD monitor
- Press Power to turn screen off
- Press and hold Select/Auto
- Press Power to turn screen on. LED will be Orange instead of Green
- Release Select/Auto
- Press Menu
- You will see 2 additional options (Factory 1 & Factory 2)
- Exit as normal
- To return LED to Green, Power off then Power on
To reset colour:
- Choose Factory 2
- Choose Auto Color1
on Dec 31, 2009 | Computers & Internet
How can i watch tivo on my computer monitor
Sorry to say but no, your monitor only has VGA which is an analog signal and HDMI is a digital signal. A cable will not convert between the two. There are digital to analog converters available but they run more than a new monitor. You can use any monitor that has a DVI port with an adapter cable because the DVI port is digital just like the HDMI port so a cable can convert the plug between the two and the signal will then be the same.
Nov 16, 2012 | Computers & Internet
Hi i have a GNR TS902W monitor it doesnt turn on
Hold down the left and right arrow buttons for 1 minute. The monitor should switch inputs and start behaving again. Mine did that although I never discovered what changed it in the first place.
Jan 01, 2010 | GNR 19M1 19" LCD Monitor
OSD + GNR 19M1 LCD screen
Seems that you have set the resolution on your graphics card to a setting higher than the maximum resolution supported by your monitor.
Try to boot into Safe Mode & lower the resolution of your graphics card. If not possible, go to Device Manager & remove the graphics card from it, then reboot your computer. This will reset the resolution.
You can then re-install your graphics card drivers & get it to work properly.
Dec 22, 2009 | GNR 19M1 19" LCD Monitor
I cant find a video driver for my monitor
Its probably not the monitor thats the problem but the graphics card, try setting up the graphics card in the same way you did for the sound card.
Jul 11, 2009 | Computers & Internet
Monitor goes dead after after switch on after 3seconds
CCFL backlight may be busted.. also ccfl inverter may need repair or replacement too..
Mar 09, 2009 | GNR 19M1 19" LCD Monitor
Dell monitor problem
Try pressing Fn + F8 keys to toggle the screen image.
Nov 30, 2008 | Dell E176FP 17" LCD Monitor
Monitor gnr ts 700 driver
GNR Corp Ltd. (UK) Support Q, How do I install/reinstall my GNR monitor drivers? A, Check the link on the GNR website: wwwgnrintl.com. Q, Where can I find the latest drives for my GNR ...
www.amtiva.com/client/gnruk/support/faq.html
Oct 06, 2008 | Computers & Internet
No picture on the screen
I have this Panasonic PanaSync SL70 17'' monitor, I don't use it often. It is still in very great shape. However, I tried to turn it on yesterday, I got a black screen. The power LED is on and I can hear the relay is clicking when signal received. I tried to remove the signal cable, I can see it turns to power saving mode. It seems that everything works fine except no picture. I am if the transformer is gone, but not sure. I am wondering if you can help?
Feb 19, 2008 | Panasonic PanaSync SL70 (White) 17" CRT...
Gateway FPD2275W LCD Monitor Logo
232 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
