Question about KitchenAid Architect® KUDT03FT 24 in Builtin Dishwasher
Kitchen Aid Model KUDT03FTSS2 -- no water getting into dishwasher. I have no idea what to check to see if there is a clog somewhere.
    Brigadier General:
  • 4,088 Answers
Make sure the water tap into the sink hot water plumbing has not been turned off. Check the routing of the water line which feeds the washer to look for kinks somewhere. The inlet water solenoid in the washer base may have failed--if no click when water should go in, suspect the solenoid. It is a fairly simple thing to replace. The last suspect would be a failure of part of the control system that signals the inlet solenoid. Hope this helps!
Posted on Nov 13, 2010
Kitchen Aid Model # KUDP01ILWH2 Dishwasher dishes
Hi.
Using too much rinse aid will not work. Stick to user manual factory prescriptions. If you use correct amount of rinse aid, and the right product for your dishwasher, that is not the cause of the stains.
Ensure that you are using the right detergent along with rinse aid. Check specifications on manual.
Ensure that the drain well is clean.
Ensure that spray arms have enough pressure, check water level and impeller pump.
If you still get stains on dishes, and you are sure that they had been caused by limescale, that means that the water in your house is too hard. This will also damage your appliances in the long term, causing faults due to accumulation of limescale and rust.
The best thing to do is installing a water filtration system on the appliance inlet.Call your local appliance shop or technician to discuss about the problem and purchase a filtration system for your appliance.
Apr 08, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
Not getting any water into the kitchen aid dishwasher
it could be the water inlet valve. that is definitely a DIY job. but first i would check out the float inside the machine. if it is stuck in the up position, no water will enter the machine. it will assume that it is already full of water. look for a small hat or cone on the bottom. make sure that it slides freely up and down. if it was stuck up, you will have just freed it and solved your problem. good luck
Nov 04, 2009 | KitchenAid Dishwashers
My Kitchen Aid KUDI01FLBL3 is not cleaning my
Most likely there is debris at the pump impeller. This model has a problem with debris and grease accumulation at the pump inlet. I have no idea how it gets past the screen but it does. Remove the transfer tube on the back wall, the lower sprayer, and screen assembly. Clean out the debris and reverse installation.
Sep 16, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
My 6 yr old Kitchen Aid dishwasher is leaving food residue
After checking all sprayer arms for clearance, and checking heating element and discharge pump, the problem was solved by replacing the small sprayer arm at the top of the washer. This small arm had popped off some time ago - obviously the water pressure was excessive for the small and unimpressive fastener. Luckily we had saved this piece, which I refastened with a strong aluminum non-corroding small bolt. Presto - now the water distribution is back to design specs, with sufficient water coming out under pressure from the mid level arm. Lesson: always look for the simplest cause first with the simplest solution. TCA
Jun 20, 2009 | KitchenAid Dishwashers
Kitchen Aid dishwasher model KDC-18 is not filling with water
Under the machine is the water inlet valve. if you take off the front end of that you find a filter which fills up with rust, and you can clean it out. If that doesnt work, repairclinic.com will sell you a new valve for 32
Jun 13, 2009 | KitchenAid Dishwashers
Kitchen aid dishwasher
Either:
  1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
  3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Sep 01, 2008 | KitchenAid KUDMO1FK - Multiple Color...
Kitchen Aid Dishwasher Model KUDJ230Y3
You can try a few things to identify the problem.. first off... when you reinstall the cleaning arm..can you manually spin it freely? No binding or anything obstructing its path? If that's OK.. then you may not be getting water into the arm from it's feed. Many dishwasher arms rotate when water pressure is present.. You can verify you have water pressure by cheating the door interlock and cycling the system .. ( be careful.. since water will jet out pretty quickly) . If you don't have water pressure to the arm, chances are you have a bad or clogged pump, pinched or clogged hose from or too the pump.. Hope that helps...
Aug 08, 2008 | Dishwashers
Kitchen Aid Superba Dishwasher
check the holes in the spray arms to see if they are plugged also brand and model number will help
Mar 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Dish machine
you need a plumber sounds like your sink piping has a blockage
Mar 08, 2008 | Dishwashers
KitchenAid Architect® KUDT03FT 24 in Builtin Dishwasher Logo
329 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
