Question about CyberPower OfficePower 825AVR UPS System
My computer won't boot and the CyberPower 825 AVR makes a continuous sound.
Please help, yesterday the unit was making a persistent sound and I pushed the red button on the left to stop it but then when I push it again the power button (green light) goes on and the desktop lights up but then everything turns off - this cycle repeats about four times then finally when it turns off after the fourth time the continuous sound of the cyberpower 825 avr unit starts up.
  • kstewari Jun 18, 2008
    Thank you for your help! I've had this unit for several years now - do you know how long they are supposed to last? I will try out your suggestions. Thanks again.
The batteries in these units are replaceable. Don't let someone talk you into buying a new system just because the batteries discharge or go bad. I have already replaced the battery in mine and it is a whole lot cheaper than buying a new back-up system,
Posted on Dec 17, 2009
  • 26 Answers
The batteries are DEFINITELY replaceable in this unit. Plus, this UPS has the AVR feature so don't throw it away. New batteries can be found at: http://www.batteryinternational.com/cyber-power-cps825avr-ups-battery-ups-batteries-f1.html
Posted on Oct 23, 2009
1. A 5 year minimum life for a UPS battery? I assure you that if you could build such an item, you'd quickly become very rich!
2. Of course the batteries in the CyberPower 825 are replaceable.
Posted on Jun 30, 2008
    Problem Solver:
  • 5 Answers
I have one just like it and there might be a problem that you are overloading the unit and that is why there is a constant beep. Try unplugging some or all of the plug and see what happens.
Posted on Jun 18, 2008
    Master:
  • 788 Answers
It sounds as though the UPS is not receiving power. Check that it's cable is properly plugged into the wall. Also verify that it's internal ground fault interrupter has not tripped, it's usually a little red button on the back of the unit, it should be pressed in and should stay that way, if it pops out then there is a problem with the ground of your electrical outlet. Also check that the breaker for that electrical has not tripped at your fuse box.
Since the UPS is not receiving power the batteries have discharged and that is why your computer cannot start, there is not enough juice from the UPS to boot it. That is also why it is making a noise as most UPS's sound an alarm to indicate that they are not connected to power.
There is a chance that the batteries in your UPS have gone bad or that something has become faulty in your UPS. Try plugging your computer and monitor directly to the wall bypassing the UPS to see if they work fine.
  • Dean Joly
    Dean Joly Jun 18, 2008
    I would say that batteries in a UPS should last at least 5 years, but that all depends on the charge/discharge cycles they go through and how much load is put on them. I don't think the batteries in a unit like yours are replaceable, probably time to buy a new one.
Cyber power 685 avr won't reset
Hi Marvin,
If the unit took a hit to it you should check to see if the battery is still good. It may not function properly because of a dead battery.
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
Nov 05, 2013 | CyberPower 575SL (CPS575SL) UPS System
Cyberpower 425 va When the device kicked in during
You can change that. It is designed to alart you during a power outtage. That way you will have time to shut down your servers. It will alway alarm during a power outage. But check to make sure your batteries are in good condition
Sep 09, 2011 | CyberPower Intelligent LCD CP825LCD 825 VA...
Where can I get a manual for my 825 AVR Cyberpower?
Here's the User Manual [click HERE] and here's the PowerPanel Personal Edition Manual [click HERE].
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Apr 19, 2011 | CyberPower (R) CP825AVRLCD Uninterruptible...
Failure to initialize after a microsoft update was installed
Go into the control panel and find the device manager. Then locate the UPS unit and right click and update driver. Then pick roll-back driver. This should install the prevous driver that was working properly. Then when you do windows update make sure to set it to hide that update so you don't re-install it again.
Sep 26, 2009 | Cybernet Systems CyberPower CP1200AVR...
CP685AVR/BF685 Power Contro.
It is likely the battery. These batteries are designed to last 3-6 years in a UPS. The good news is that if it is the battery, it is completely user replaceable and you'll have a Cyber Power unit that works just like new with a new battery. What may have happened is that the battery was weak, and you may have had a slight dip in the AC power. This caused the Cyberpower unit to switch over to the weak battery which couldn't handle the load. The unit then turned off. When you press the "ON" button, the unit will go through a self-test that checks all of the components and the unit will not turn on and be functional unless all of the components come back with a PASS, including the battery. If possible, test the battery with a voltmeter, it should read around 13.5, but not lower than 11.5v DC. However, with the unit over 3 years old, it almost certainly the battery. Here's a link to a replacement battery for the CP685AVR: http://www.batteryinternational.com/cyber-power-cp685avr-ups-battery-ups-batteries-f1.html
Hope this helps.
Jun 28, 2009 | CyberPower (CP685AVR) UPS System
The cyberpower 585 AVR suddenly is´nt working...
the ups hardware of the relay and driver might be spoil..ask of the service? you can try this asia systems technologies look for our sale person william +65 65478990 william@asiasystemstech.com i suspected that now that u UPS is have hardware issue.. to determine if the unit is really the problem it hav to be do a further diagnos..
Jan 23, 2009 | CyberPower Office Power 585AVR...
I need sound drivers
look for your computers home page and there you should find all the drivers for your specific make and model. make sure you know what kind of precessor and soundcard and video card you have though
Dec 06, 2008 | CyberPower OfficePower 825AVR UPS System
CyberPower 800 AVR
Hi. I've had one since 2003 no problems. Then suddenly I come home and the power had temp gone out, come back on and the tone is constant. I hit the button, on and off. powers, then off, a couple of beeps. Nothing improved it.
I read online...the back up battery eventually wears out and can be replaced! This will happen will all units, it's normal. No biggie and less expensive than a new unit. I haven't replaced mine yet as this all coincided with a new computer purchase and I was planning on getting at least one more unit anyway, so I've just grabbed a 825 off the shelf. I'll figure out ordering a replacement battery as I have time, and perhaps order a couple of smaller units for some other applications in the house.
One of these units is cheaper than the deductible on insurance, and I've had lighting just going overhead take out 2 tv's and such in different houses, 3 different events totalling thousands. My cyberpower protected the tower and computer I'm using now, but others in the house, router, etc were destroyed. You can't risk getting those hits on your insurance if you can help it. If only I'd had one hooked up to the garage door opener, lol. $61 would have saved me $500.
Jun 21, 2008 | CyberPower (CP800AVR) UPS System
Backup unable to communicate with computer
Plz check your computer without ups.If it is runing there.And wattage of ups .It seem over load or shortage of ups.Check power cable.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 06, 2008 | CyberPower 1350VA UPS w AVR & LCD...
CyberPower OfficePower 825AVR UPS System Logo
764 people viewed this question
Top CyberPower Computers & Internet Experts
Dale Jones
Dale Jones
Level 1 Expert
Paul Bade
Andrew Taylor
Andrew Taylor
Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
