Question about Toro Garden
How to install transmission drive belt on c165 wheel horse
3 Suggested Answers
suzukiracing
  • 200 Answers
SOURCE: I HAVA A TORO WHEEL HORSE MODEL 71223, I PUT A NEW
The problem sounds like the tranny if the belt is correct.Thanks for asking and I hope it helps.
Posted on Jul 21, 2010
rohdd
  • 293 Answers
SOURCE: I want to purchase a drive belt for wheel horse
The belt part number is Toro 93-3884. Just search google for this part number.
They are around $50-60.Also you can purchase from sears . com
or here: http://www.m-and-d.com/TOR-93-3884.html?mv_pc=00015
J
Posted on Mar 07, 2011
Drive belt installation 2000 electreaglid classic
Remove the rear wheel and then remove the primary chain, the clutch, the engine compensating sprocket, and the chain adjuster as an assembly and then remove the primary chaincase housing. Support the bike under the rear fork and engine and then remove the pivot shaft and the spacer THEN slip the belt off the transmission sprocket and then install a new drive belt over the transmission sprocket and proceed to reinstall the pivot shaft and spacer after which you can remove the support holding the engine and rear fork and install the primary chaincase housing, the primary chain assembly and the primary chaincase cover and fill the primary chaincase with lubricant up to the bottom of the clutch diaphragm spring. Install the rear wheel and adjust the belt to the proper deflection dimension and confirm that the rear wheel is properly aligned side to side.
Jul 08, 2014 | 2005 Harley Davidson FLHTCUI Electra Glide...
How do you change the drive belt on a 2006 hd sporster
Remove the rear wheel and then remove the primary chain, the clutch, the engine compensating sprocket, and the chain adjuster as an assembly and then remove the primary chaincase housing. Support the bike under the rear fork and engine and then remove the pivot shaft and the spacer THEN slip the belt off the transmission sprocket and then install a new drive belt over the transmission sprocket and proceed to reinstall the pivot shaft and spacer after which you can remove the support holding the engine and rear fork and install the primary chaincase housing, the primary chain assembly and the primary chaincase cover and fill the primary chaincase with lubricant up to the bottom of the clutch diaphragm spring. Install the rear wheel and adjust the belt to the proper deflection dimension and confirm tat the rear wheel is properly aligned side to side.
May 21, 2014 | 2004 Harley Davidson XL 883 Sportster
How to replace drive belt on a 1993 harley davidson heritage softail classic?
To remove a Softail drive belt FIRST remove the rear wheel then remove the primary chain, the clutch, the engine compensating sprocket, and the chain adjuster as an assembly, then remove the primary chaincase housing, place a support under the rear fork and engine, remove the pivot shaft and spacer, slip the drive belt off from the transmission sprocket.
To replace a Softail drive belt FIRST not that all belts, used or new, must never be formed into a loop smaller than 5.0 in. (130 mm), and must never be bent backwards because this can severely weaken the belt and cause premature failure if it, then install the belt over the transmission sprocket, install the pivot shaft and spacer, remove the support holding the engine and rear fork, install the primary chaincase housing, the primary chain, the clutch, the engine compensating sprocket, and the chain adjuster and the primary chaincase cover, fill primary the primary chaincase with oil, install the rear wheel, align the rear wheel and properly adjust the belt tension to the specified deflection.
Apr 28, 2014 | 2000 Harley Davidson FLSTC Heritage...
How to replace drive belt on 1993 harley davidson?
Is it a softail????
Apr 28, 2014 | 2005 Harley Davidson FLSTC - FLSTCI...
How do I change the drive belet
To remove a 2007 Touring drive belt FIRST remove the rear wheel and the rear swingarm, remove the primary chaincase assembly,remove the old belt from the transmission sprocket.
To install a 2007 touring drive belt FIRST install the new belt on the transmission sprocket, then install the primary chaincase assembly, then install the rear swingarm and the rear wheel and adjust the belt deflection to specifications.
Belt Deflection
Vehicle Orientation Model Inches Millimeters
Motorcycle Upright
With Rear Wheel in Air
or On Jiffy Stand
Without Rider or Luggage
FLHR/C,
FLHT/C/U, 3/8-7/16 9.5-11.1
FLTR
FLHRS,
FLHX1/4-5/16 6.4-7.9
Apr 27, 2014 | 2007 Harley Davidson FLHRC Road King...
Jul 18, 2010 | Toro Garden
Disassemble Troy-Bilt Econo-Horse Transmission (1991 Manufacture)
If you do not have a manual you can get it free at troybilt.com.
Apr 24, 2010 | Troy-Bilt Pony Garden Tiller
My troy-bilt 8.5 horse 26 inch wide snowblower wont move anymore.
Take the belt cover off that covers the drive pulley on the engine. You should only have to loosen two bolts. Inspect the belt to see what it looks like. I am not sure if it drives a gear box or if it turns a friction wheel that drives the wheels. If the belt looks good check for shear bolts that might have sheared off and replace them.
Dec 19, 2009 | Garden
I have Toro Wheel Horse riding lawnmower model # 70040 - 790000
need the ser number of the unit. the pulley don't split its one part, i need the ser number . this is no easy job. good luck
Oct 13, 2009 | Toro Lawn Mower With Toro Power Tools
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
132 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
