Question about Canon PIXMA iP3000 InkJet Photo Printer
Just refilled my inkjet tanks (black, blue, red, yellow) all are working fine except the yellow - I've done 2 deep cleanings after a few regular cleans, checked the print head. Nothing is working.
  • 37 Answers
AH YEAH MATE SOMETIMES THE REFILLED CARTRIGES DONT WORK PROPERLY,GOT 2 BUY GENUINE ONES
Posted on Nov 14, 2010
Will only print yellow, black and photo black-- red cartridge shows ink in window and I just refilled blue-- cartridge was only out of printer a few hours. I've cleaned the print head a number of...
There are a few things here that will do this. One is the cartridge is a smart cartridge and unless you reset the chip it either won't print or shows low. If you filled it before then this shouldn't be it. If you have refilled the cart more than a few times they sometimes just stop. This is either the ink has jelled inside or the little feeder sponge is dried out. If you changed ink brands sometimes the ink reacts with the old stuff and jells.The other is the jet or any feeder tubes are plugged with dried ink. Usually happens if you haven't printed for a while. You can try running the cleaning cycle and it will take quite a few of these sometimes before it starts working.
There are a few more tricks for cleaning such as using white vinegar to dissolve dried ink but that's a bit of the messy side sometimes. Usually we have just had to buy a replacement cartridge after spending the time on this. We eventually just got rig of our ink jets and got some of the cheaper color laser printers. Wish we had done that sooner.
Sep 01, 2011 | HP Photosmart D7560 InkJet Printer
Brother 490cw no red and no yellow print after a few time cleanning still not working blue and black work fine
You need to have the print head replaced. Brother is covering the cost to repair this problem if you call 1-877-276-8437 and tell them you are missing 2 colors on print outs.
Jun 09, 2011 | Brother MFC 490cw Color Inkjet...
All nozzles are fine except the yellow which does not print out at all in the test. I've cleaned and deep cleaned to no avail
Try flushing the yellow channel with cleaner with syringe. The cleaning function will not dislodge a blockage if it is severe. You will have to recharge the channel with yellow afterwards. You can probably do this with a refill kit.
Apr 09, 2010 | Canon Pixma iP4500 InkJet Printer
Refilled pixma MP210 color cartridge. Now my printer will not print any color at all, only black
Maybe your printer cartridge that has been refilled got ink clogged. You can bring it to the store where you can let them clean it for you. It must be free for cleaning since it was refilled from them. Hope this help.
You can also clean your cartridge by following my instructions below:
BEFORE DOING BELOW INSTRUCTIONS,TRY TO CLEAN YOU CARTRIDGE FIRST USING THE DEEP CLEAN FEATURE OF YOUR PRINTER, THEN USE PRINT NOOZLE CHECK PATTERN.
1. Uninstall your cartridge.
2. Get a tissue paper.
3. Try to put the printer head over a small piece of tissue paper.
If you will see the three colors in the tissue(Cyan-close to blue, Magenta-close to red, and Yellow). It means it was not clogged, the problem is the chip of your color cartridge and needs to be replaced. But if the colors are blur and or nothing appears, it means the printhead of your cartridge is clog. You can proceed to step 4.
4. Try to put a little amount of water in a small piece of tissue paper and soak the printer head for a 2 min. Then remove it after.
5. Wipe the printer head with a dry tissue paper.
6. Reinstall the cartridge back to the printer.
7. Print a 4 basic colors, RED, BLUE, YELLOW and BLACK.
8. Clean the printer using the cleaning feature of your printer.
9. You can use deep cleaning twice. And Print a noozle print.
10. Hope it could help.
Dec 17, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Will not print blue
clean head cardrige and calibrate color cardriges.
Jun 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon MF960 will not print yellow
The yellow may be clogged. Try cleaning the printhead by removing it from the printer and soaking the bottom (half inch deep) of printhead in warm window cleaining solution for a few hours.
303Electronics eBay Stores
Jun 05, 2017 | Canon PIXMA MP960 Printer
Black or Blue not printing - just red and yellow
Are you using geninue Microboards new cartidges or refills? If you are using the new Microboards ink carts, then you have a bad cartridge, or possibly a bad batch. Simply call Microboards tech support at 952.556.1639.
http://www.techwaredist.com
Oct 16, 2008 | MicroBoards PF-2 InkJet Printer
Dissapearing yellow
I run about 100+ canon printers from s800 up to the new ip4500.
I have met and solved almost every problem I find described on the web. Your problem with the disappearing yellow ink can be only one thing. The ink cartridge has not been sealed after you injected the ink. If there is even the smallest avenue for air to get into the cartridge it will allow the ink to flow very rapidly back out of the cartridge and into the waste ink pads in the bottom of the printer. You won't be able to see a puddle of ink under the printer until much later when you have done many cleanings or installed many leaky cartridges.
Dec 23, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Magenta printing as yellow
Well, first off, are the alignment, and nozzle check sheets looking good? If not, then work on that. If so, then we have a problem. Try creating a test sheet in Word. Make red, yellow blue & black text and see if anything else prints wrong. Get back to me!
Jun 19, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
All colors print blue
You did the right thing. Sometimes a bad printhead or a bad cartridge will cause a leak and will damage both. Good job!
Jun 05, 2007 | Canon i850 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
77 people viewed this question
old marine
old marine
