Need help with a problem on an Allen Digital Organ model 301B. Capture system is not working fight. Manual pistons can be set but the general pistons can not, all the stops go down when you push a piston. Also where can i purchase or download a service manual for this organ series.
  • 8,197 Answers
Sorry we can not help you here. You will need to call in a paino/organ repair person
Posted on Dec 07, 2010
Why does my organ not retain its memory settings any longer?
What make and model organ are you specifically talking about? I assume you're referring to a capture combination action that no longer retains the settings you try and program?
Aug 11, 2014 | Music
How do I remove the front calipers?
1st jack up your car & remove the tire. The calipers are generally held on by 2 large allen head bolts. Personally I prefer to use an allen wrench that fits on a ratchet, but just an all steel allen wrench will work. You should be able to remove the calipers at this point. When re-installing the calipers you'll need to push in the caliper pistons (usually 2 per side of car) I've had good luck using about a 6" c-clamp to push the caliper pistons back in . I hope this helps.
Apr 27, 2014 | 2004 Mitsubishi Endeavor
I am lookin for the manual of an Allen digital organ ADC 2140
Please visit the page below and check under "MORE MODELS" section. You will find a section for MDC there. If you do not find the exact model you are looking for, you can put a request to their support team for the Manual. Hope this Helps.
http://www.allenorgan.com/www/support/ownersmanuals.html
Click on "MORE MODELS" then in the drop down menu click on "MDC". If you do not find the correct model there, request a manual here: https://www.allenorgan.com/www/support/frmmanualrequest.html
May 24, 2013 | Audio Players & Recorders
I have an older model lowrey spinet organ - very similar to the Jamboree model M325 but with a few significant differences. Only 6 rhythms instead of 18. No metronome. Has AOC,Genie plus organ,Genie bass,...
Try this link:http://www.organservice.com/ Here's another one:http://www.combo-organ.com/Schematics/index.htm Join this one for free and post:http://organforum.com/forums/thread/73735.aspx This site is good too:http://www.combo-organ.com/spares_and_repairs.htm#Electrolytics Hope these help.
Jan 09, 2010 | Boss Micro BR Digital Recorder
Need an operator's manual for Yamaha Elecone organ model MFX-7420
Have you tried joining at the Electone Zone at www.electone.com? It looks like a fun site and its free to join. Maybe one of the members there can kindly help you.
May 24, 2009 | Music
Is my tv digital compatible or not
https://www.dtv2009.gov/FAQ.aspx What you need to know is whether your TV set has something called a “digital tuner” already built in. If it does, your TV set will work after February 17, 2009. The best way to determine whether your TV set has a digital tuner built in is to consult your owner’s manual. If that’s not possible, you may be able to look up information about your TV set on the manufacturer’s website. Or, you can take an up-close look at your TV set. In any case, you’re trying to find out if your set has an input connection labeled “digital input” or “ATSC” (for Advanced Television Systems Committee, which is the DTV format).
Here are some general guidelines that may help:
TV set made before 1998 was a traditional “analog” set. If you bought a big-screen, projection TV between 1998 and 2004, it may have a built-in digital tuner inside. But chances aren’t great. Only a limited percentage of projection TV sets (and generally only those 42 inches in diameter or larger) included digital tuners before 2004.
If you purchased a new TV set since 2004, your chances of having a built-in digital tuner improve dramatically. Starting in 2004, many of the TV sets sold at popular electronics stores feature digital tuners that will work after February 17, 2009. But it’s not a sure thing. Even some of the newer TV sets are purely display monitors that lack the internal circuitry needed to pick up digital broadcasts. Usually these sets have been advertised as “HD-ready” or “HDTV monitor” sets. That means they can display digital and high-definition signals, but they need help getting those signals in the first place. You’ll still need a special converter or a cable TV connection. Hope this info above helps. Also, check your manual, and if you don't have it some manufacturers, (Philips does for some models) offer the manual on their websites.
Apr 07, 2008 | Philips TV Tuner Video Capture PCI Card -...
On my Technics EX-70 organ, have lost my presets that were originally set up by a professional teacher who is no longer available. I need some detailed help in programming the Voice Setting Computer and...
To Big Gord. To program voice setting computer, set up a sound you want press & hold white button then button 1 while still holding
white button. repeat for other setups. before turning organ off always press cancel on VSC should hold settings for next time you use it.
To set upper organ presets, the sequence is shown on page 17 of the manual.
To RishiMalla. To reset organ turn on Fullband Setting Computer switch then press black Inital key on bottom key board.
Feb 28, 2008 | Audio Players & Recorders
Wurlitzer organ --need manual
I can make a copy of my owner's manual and send it to you. It's for a Wurlitzer Model 4430, also from the 1940s, 50s and 60s like the one you have. Would that maybe help? All I'd ask for is a couple of bucks for printing and shipping costs. If you want it, just reply to this post with an address or some way to contact you in order for me to obtain an address; I may be able to be talked into making a digital copy and emailing it to you if that's even legal. I'm not sure. You can look into that for me and let me know what you want/need :-)
Sincerely,
The Organ Donor
Jan 11, 2008 | Audio Players & Recorders
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
