Question about Reddy R115DT Oil Filled Utility Heater
I put a new ignitor which it is the ceramic type and it will glow but will not light fuel and the fan will cut on for about 4 seconds and then go off.
  • 232 Answers
The ignitor only glows for 5 seconds, then quits. During this period the flame should have lit and will perpetuate itself. If there is no flame, then you have problems and you must start by setting the air pump pressure, which is easier than it sounds. Read these troubleshooting tips.
Posted on Nov 14, 2010
Gas does not ignite on furnace. Fan stays on even when shut off at thermostat. When trying to start, I hear a click and get a gas odor that stops quickly. Furnace had major overhaul 10 years ago.
You have a ignitor problem .Replace the ignitor .Is it a direct spark or a glow type .My guess it's a glow type .About the fan issue sometimes fan would stay running for maybe a minute even after you turn the fan mode ofg
May 27, 2017 | Heating & Cooling
Oven wontr come on, but broiler does//
you have a bad ignitor part number 74007498 and it's around 65 dollars.pull out the racks and remove the floor of the stove and you'll see the ignitor screwed to the burner tube,wet the screws with a wet paper towel,they will come out easier or if it makes it any easier remove the tube and then remove the ignitor.first start the stove if the ignitor glows but doesn't ignite the flame in 40 seconds or less it's bad,if it doesn't glow at all check it for continuity but it sounds like the ignitor is bad,if the new ignitor comes with wire nuts,cut the wires close to the body of the old ignitor,trim some of the wires back on the new ignitor and wire nut them together with the ceramic wire nuts,on some you can get the screws out of the ignitor,cut the wires close to the body,mount the new ignitor,trim back the wires on the new ignitor and wire nut them together and you're done,it doesn't matter how long the wires are just as long as the wire nuts are under the floor and away from the tube.it might help to remove the bottom draw to get at the wires,hope this helps and good luck.
Dec 11, 2011 | Maytag MGS5870 Gas Kitchen Range
The oven does not reach the temp setting
it seems to be very expensive shop arround there are alot of con men out there and he seems to be one a control pannel for that oven $105 and easy to fix no time at all $195 to fit 20 mins work at most 30mins
Nov 25, 2011 | Jenn-Air JGR8850 Gas Kitchen Range
When you turn the knob you dont smell gas, don't here the click of the igniter, but would like to light the oven manually. Can you help me please.
you can't manually light the oven with a match anymore,you have an electronic ignition in the oven or an ignitor part number 5303935066 and it's around 60 dollars.you have to remove the racks,remove the floor of the oven and then remove the cover and you'll see the ignitor in the back screwed to the tube usually with two 5/16 inch screws. set the oven to bake on 350,if the ignitor glows but doesn't light in 40 seconds it's bad,if it doesn't light at all you can unplug the ignitor and check it with a meter for continuity but most likely you have a bad ignitor.wet a paper towel and wet the two screws,they will come out easier,you can't use wd or anything like that because it will smell when you turn the oven on so use water, if you can see where the disconnect is to unplug the ignitor unplug it or when you get the screws out cut the two wires close to the ignitor,the new ignitor comes with ceramic wire nuts so you can connect the two wires you just cut to the new ignitor,the wires on the new ignitor will be long,you can screw the new ignitor on,leave around 6 inches of wire on the new ignitor so the wire connectors will be away from the tube and not up near the floor and if you have the ignitor screwed on you can see how long to make the wires,cut the wires and strip the ends on the old and new wires and wire nut them together.then turn it on to bake,when the ignitor starts to glow it sholud lite the flame in less than 40 seconds.hope this helps you out.one more thing don't touch the piece of the ignitor that's inside the metal bracket,they break very easy.good luck and have a great holiday.
Nov 20, 2011 | Tappan TGF320 Gas Kitchen Range
The heater fan runs for about 5 seconds , does not heat and than turns off.
This could be several problems. Check your fuel first. If it is old fuel from last year, get rid of it and fill with fresh. If it has water in the tank, your spraying water to your ignition source. If you have fresh fuel, it could be a fuel filter stopped up or your air pump is not set properly. Also check your ignitor to see if it is working properly. Some have a spark plug and some have a glow type ignitor.
Jan 03, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
Oven does not heat up
most likely you have a bad bake ignitor part number WB13K21 and it's around 80 dollars,unplug the machine or shut down the breaker,remove the racks,remove the bottom floor of the oven,remove the flame panel and you'll see the ignitor attached to the burner tube,unplug the wire harness going to the ignitor,remove the screws holding the ignitor in place,plug in the new ignitor and put the screws back in,turn the power on and put it on bake,the ignitor should start to glow and the flame should lite in around 40 seconds.there are other ignitors that you can use in the stove,the only difference is that you cut the wires going to the old ignitor and splice in the new ignitor and use ceramic wire nuts to connect the wires together,it just doesn't have the harness connector on it
Nov 27, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Magic chef self ignitor top,, how do u get the oven to work.. is it self ignite too. i turn on oven ger a glow in the oven,, dont know the model ,,older stove. good shape. bought house with gas stove...
If the glow bar is glowing and the oven doesn't come on in about 30 - 45 seconds.... it probably is the glow bar that needs to be replaced. BUT it could be the oven valve. Usually it is the glow bar.
The glow bar is wired in series with the oven valve and even if it is glowing it may not be sending the correct voltage through to the oven valve. To change the glowbar... unplug the appliance, unscrew 2 screws holding the metal bracket to the burner and remove the ignitor. You can cut the 2 white wires going to the ignitor and use ceramic wire nuts with the new ignitor.
Tom
Aug 10, 2010 | Magic Chef 31000 Gas Kitchen Range
York Diamond 80 furnace (propane conversion), about 1998 model. Solid Ignitor comes on, but no flame. Main fan works for about 90 seconds then cuts off. Fan only switch on thermostat does the same, fan...
Check for 24 volts across the two terminals on the gas valve when the ignitor glows. If yes, bad gas valve or blockage in the gas train. If no, bad ignitor or circuit board. Even if the ignitor glows, it still may be bad and not sending the proper signal to the board. If you jump the R and G terminals on the circuit board, does the fan still only run for 90 seconds? If so I would say replace the board.
Dec 28, 2009 | Heating & Cooling
Whirlpool LP dryer will not light. model LGR7646EQ2.
the ceramic ignitor probably is broke. turnoff power and gas, then remove burner assembly ther are two screws holding it in. also loosen gas connecter .pull burner out an visibly check igniter you most likely will see the ceramic coil broken remove it and bring it and model # to a part house then reassemble burner
Jan 26, 2009 | Dryers
ERSD36S09 Dual Fuel Dacor; broiler doesn't work
I had a similar problem. My broiler wouldn't light but the igniter was glowing. It turns out this igniter has to glow virtually white hot. If it's red or orange it probably needs replacing. I bought a new one from Appliance Parts Pro's. However, when I look at pictures of these things they all look exactly the same. My guess is all appliance manufacturers use the same unit.
To change it on the Dacor you need to pull off the back panel. Loosen the unit inside by removing the screws and shake the wires so someone else can see which ones. Disconnect the wires from the connectors and tape a piece of thickish string to it. This allows you to pull it out from inside the oven and have a way to get it back in past all the little turns and corners. My replacement had bare ends so I cut off the old connectors and soldered them to the new unit. However, I would guess you could use wire nuts instead.
Nov 18, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Reddy R115DT Oil Filled Utility Heater Logo
64 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
