I have an Amana washing machine model LW6153WM that has a leak from under the machine. We changed both water hoses but that must not be the problem because it still leaks. Where do we start to look to try to find the source of the leak? Thanks.
    President:
  • 1,891 Answers
Most common leak would be the water pump located in the center front . remove the front panel 2 screws hold it . and i think you can see the motor and pump in the front . then fill the machine and during the fill look for where the water is comming from. . most common are the pump / the center seal / or the valve .. hope this will help feed back pls mm and thanks for using fix ya ..
Posted on Nov 14, 2010
My Amana front load washer leaks water from beneath the soap dispensing tray while the machine is in use. Any ideas as to how to fix it?
Remove the tray and clean it under hot running water. Pull out and then up and out is the normal way, but some have a catch which you should be able to see. If that doesn't fix it, you would need to look inside it for loose or split hoses. If the water is just dribbling out under the tray and down the front of the machine, cleaning the tray will fix it.
Dec 28, 2016 | Amana Washing Machines
How do i figure out where my washing machine is leaking?
The easiest way would be to lay the machine on a pad on a side( (water will leak out so take the machine outside) and look for signs of leakage( mineral deposits, discoloration). Many components are not serviceable so prepare to buy a part. Hope it's a hose or something inexpensive!
Jul 20, 2014 | Amana Washing Machines
Amana tandem 7300
What does it mean when a washer leaks from the bottom?
The pump will have an outlet or drain hose, an inlet from the tub and may have a circulating hose outlet as well. If you have water leaking from the washer during a wash or drain cycle, check the area of the drain pump. Look for signs of a loose hose clamp or a leaking hose connected to the pump first. Washer Repair Diagnostic Leaking Water Amana Whirlpool NFW7300WW
Jan 18, 2018 | Washing Machines
Leaking washing machine
It is so common that the drain leaks in many ways andis the most problematic fault in a washing machine. In all occasions it isimportant that your observation is most important and so is vital to theidentification /rectification and solution. If you have noticed that water hasleaked then as the drain hose pump/valve and fittings are located on theunderside of the machine it is important that you look for possible leaks here.In some cases the drain hose would be clogged at the drain end to outlet of thehouse and so there will be back flushing resulting in overflow to the outside.Also the drain pump/valve can be clogged or the drain hose clamps can be looseon the grip which can all cause the leak to occur. Removing and cleaning thedrain pump/valve, tightening of the hose is also very important. Also water canleak if there are gaps on the front door gaskets and must be checked but thiswill happen only during the cycle and not on the drain cycle end.Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html Check for tips on the link below to identify parts andremoval:http://www.espares.co.uk/advice/washing-machines/a/7
Jul 04, 2012 | Amana Washing Machines
A lot of water leaking out of bottom of washer
You got to open it up to see where the water is coming from. It could be the tub, pump, hoses, anything in there...
May 21, 2010 | Amana ALW895 Top Load Washer
Amana washer model# nav4800aww leaks water on the floor while washing large loads. Now it does it on all loads.
firstly remove rear cover and check during running if any hose is leak?
or-
water seal inside drum is leak for this drum has to be open. mostly bearing are damager due to water entering bearings. so bearing are needs replacement.
Nov 05, 2009 | Amana Washing Machines
Water leaking from under machine
Could be a loose hose connection..........
Mar 22, 2009 | Amana Washing Machines
Amana washer leaking.
Have your husband disconnect the power and water lines, pull the washer out and tip it back so he can check the hose connections to the water drain pump in the bottom of the washer. That pump should have two hose connections. In older machines, it is entirely possible that a hose has either come loose or cracked. If the hoses appear fine, check the pump itself for possible cracks. If all looks well, check the hose clamps for tightness.
Feb 23, 2008 | Amana ALW880WH Top Load Washer
Amana LWA50AW Washer Leaks!
you need to get the front off... grap a light and get down and look inside to find out whats leaking... with out looking its just guessing check all water hose connections, water pump, and main seal where transmission goes thu drum
Sep 05, 2007 | Amana LWA40A
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
