Question about Life Fitness 9100 Next Generation Remanufactured Treadmill
My lifefitness treadmill gives a static shocks...
  • 42 Answers
Hi you have a wire touching the body of the treadmill somewhere, but an easy fix is to go to any car parts shop and buy an antistatic strip. just attach that to the body of the treadmill making sure it is touching the ground, this will def fix your problem. i had the same with mine i spent ages looking for the wire etc but just waisted alot of time. the strip has worked very well.and cheap to buy under £5.00.
Posted on Nov 14, 2010
I get a small electric shock each time i put my hand on the heart rate monitor on the left of the treadmill. Also happens when i h the inclune buttons on the left. Any suggestions?
Hi Pjd
Shocking problem!
Suspect that the treadmill is generating static electricity.
It is building up as you run... via the rubber mat.
Like the comb through the hair picking up tissue paper bits.
This is basically a Van De Graaff Generator.
Try attaching a wire from the machine chassis (metal) to a metal tap at your sink.
Do you still get a shock?
Not sure where you are and what your electric supply is.
I'm in Australia and our AC plugs have a third pin which is connected to our meter box which is then connected to an outside GROUND ROD.
Perhaps the AC power you are using has no ground or only a 2 pin connection. I which case I would add a three wire plug to the treadmill and the ground pin would connect to the treadmill's metal chassis by a screw or bolt.
Anti static spray may also help
Cheers
Van de Graaff generator
https://www.target.com.au/p/anti-static-spray/50563715
anti static wrist strap
Mar 01, 2016 | Exercise & Fitness
Lifefitness treadmill belt sticks even though wax bag is full
It may not be sticking, but instead slipping on the front roller. You can resolve this by simply tightening the running belt. This adjustment will be done by using the rear roller.
Apr 01, 2014 | Life Fitness 91Ti Treadmill
Control panel shocks
This is a common occurrence as we enter the dry season. Static electricity will build up as you walk/run on your machine. There are many factors which make the problem more or less evident - the type of walking belt and deck, design of the treadmill, type of walking shoes, etc.
Some treadmills have a grounding wire from the console to the frame of the treadmill as well as a grounding wire from the rear roller to the frame of the treadmill. Check to see if these are in place, or have a qualified technician check this.
One common solution is simply to add a humidifier to the room where the treadmill is located. Raising the humidity will greatly reduce the static shock problem
Nov 30, 2013 | Endurance Exercise & Fitness
Treadmiill keeps saying waxer needs filled after filling it
please see the cause and remedy and fix it. Please read carefully your section of troubleshooting instr. manual or download
Inspect spray pattern between 8" (200mm) and
16" (400mm).
If not, verify wax nozzle is clean, hoses are not
kinked, wax bag is not empty, or wax is
contaminated.
http://www.sportsmith.net/images/product_support/lifefitness/Treadmills/TR9100/9100 Treadmill Manuals/Service/m05100k
God bless you
Nov 29, 2012 | Treadmill Doctor LifeFitness 9100...
I have a bodyguard t260 treadmill and when I run on it there is a great deal of static electricity that shocks me when I touch the treadmill handles
The shock is a build up of static electricity on your body called Electrostatic Discharge (ESD). Friction between the walking board and belt can generate static electricity.
If experienced, the shock is not harmful or dangerous.
Nov 11, 2011 | Exercise & Fitness
Treadmill won't turn on, I get a slight shock when I click the on/off switch.
Dear Sir:
Thank you by you request, I will help you inmediately.
Please do this with very Carefully!!
The shock is a build upof static electricity on your body called Electrostatic Discharge (ESD).Friction between the walking board and belt can generate static electricity.
If experienced, the shock is not harmful ordangerous.
Thank you in advance, sincerely. God bless you.
IF YOU NEED FURTHER ASSISTANCE, PLEASE CONTACT ME
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 27, 2011 | Precor 9.21 Treadmill
Why does my lifefitness series t screen read immobilized?
I believe the tread has been locked out (safety feature important for clubs) - you can call lifefitness and they will give you the key sequence to unlock it
Sep 21, 2010 | Life Fitness 95Ti Treadmill 95 Ti
How do i reset the waxer on a 9100 lifefitness treadmill?
Press these buttons:
101–ENTER–
HILL–RANDOM–
FIT TEST.
Program lights come on. Display will scroll toWAX DELAY OFF.
Press speed "UP" or "DOWN"
to toggle to
WAX DELAY ON or OFF.
May 13, 2010 | Treadmill Doctor LifeFitness 9100...
Cant get the lifefitness treadmill T7-0 to work
you may need open up the head board and check the switch.
Mar 29, 2009 | Life Fitness LifeFitness 97Te Treadmill
Heart rate monitor chest band not working with Life Fitness 9500H
This mean that you unit is not equiped with a receiver inside the treadmill. Some models that was an option. Polar is the only brand that works with Lifefitness. You may have a bad upper display board. You can buy a replacement for a small amount of money.
Mar 12, 2009 | Life Fitness 9500HR Next Generation...
Life Fitness 9100 Next Generation Remanufactured Treadmill Logo
191 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
