Question about LaCie (300908) AIT Tape Drive
Tabe back up
I insert tabe it reads it then says bad media half way
  • 4 Answers
Try this shout "boo!" at the hardrive as it reads it should give you no problems after that;)
Posted on Jan 07, 2009
Dell studio 1555 doesn't read DVD or CD , when I insert CD / DVD it looks like it is reading the media but when I click on Drive icon, it ejects the media.
First reinstall the DVD driver to see if the DVD drive works.
If not then -
Try removing the DVD drive and inserting it back to make sure it properly connected then boot up the laptop and go into the BIOS and see it the DVD drive is detected, if the DVD drive is not detected then the DVD drive is faulty and needs to be replaced.
Jun 11, 2012 | Dell Studio 1555 (883685982850) PC...
My rio was playing and froze half way thru the song, now wont do a thing, including back up or turn off.
Read manual or online for reset button most mp3 players have one some where.
Reset the Riot by inserting a paperclip or pin into the hole on the back of the ... Rio
May 06, 2011 | Rio CE2100 MP3 Player
Does not read discs when inserted in drive ,keeps saying no disc inserted after a few minutes of trying to read media in all formats. very frustrating please help.
Unplug Everything!
Then Plug Everything Back In. Make Sure Everything Is In The Right Place. Clean Cd. And Make Sure That Your Tv Is Showin The Dvd Screen..
Hope It Helps!*
Feb 07, 2010 | Televison & Video
No power and auxiliary power led on in orange
Could be a bad power supply, bad motherboard, bed device such as a disk drive dragging your system down, or a bad card plugged into the motherboard. Easiest thing is to remove devices such as PCI cards and hard drives one at a time to see if the problem clears. If it doesn't, continue on at your own risk.
If your handy with a multimeter, you can make some checks to see if your power supply is good. Read below:
You have to determine if the power supply is good or the motherboard or some other device is bad.
You will need a voltmeter/multimeter and some experience in reading voltages. If you are unsure, quit now and take it to a professional so you don't shock yourself. Continue on at your own risk.
Using your meter set to DC, and computer on and opened, find your molex connector for any drive bay. Google Molex if your unsure what they look like.Then read Yellow to Ground -should be +12VDC. Read Red to Ground -should be +5VDC. If your not sure what ground is, you should NOT be doing this. Continue on at your own risk!
If these voltages are good, your PS is PROBABLYgood, and you can hook up the motherboard and hard drive. If your unit powers up fine reconnect every remaining device until the bad device is inserted and the problem returns. If your power supply did not read good then read below:
Your power switch on the front of the machine gets connected to the power supply via motherboard. The main power connector at the motherboard passes a momentary "short" signal to the power supply to turn it on. You need to recreate this event with a paperclip.
Another way to isolate whether your power supply is bad, you must disconnect the power supply from ALL other devices.
Then disconnect the AC input power from the back of the power supply.
Then you can use a paperclip to jumper ANY green wire to black wire on the largest plastic connector that you disconnected from the motherboard. Insert the paperclip with everything unplugged and stand back.
Once you are clear from the unit. Plug in AC power from wall to back of power supply and see if the fans start up on the power supply. If they start then half of your supply should be good. Re-read your DC voltages at molex to verify other half.
Hook up devices one at a time to see if they do their power up routine with motherboard UNHOOKED. You should hear drives spinning and see lights flashing. You do not need to whole computer reassembled for this part to work. If all devices are hooked up and seem ok, then your motherboard is bad.
Jan 19, 2010 | Dell OptiPlex GX620 PC Desktop
Compaq SR2041X does not read SDHC card
Possibly a band Reader.. one thing you can do is test to see if it reads other types of memory cards such as panasonic or kingston. If those do not work then it may be a bad card reader..
Apr 17, 2009 | HP Compaq Presario Media Center SR1750NX...
Phone cannot read or doesn't recognize media card
It need to be unlocked, enter blackberrymep.com to get MEP2 code (blackberry sim unlock code) .
Apr 02, 2009 | RIM BlackBerry Bold Smartphone
My player is half full but reads no file
if you downloaded some files that are corrupt delete that file from pc/laptop...and try again...you can also filter out the bad one block that sharer..(tool/option/filter) in limewire....
Apr 02, 2009 | Apple iPod nano
I've aproblem with sound
check the sound  settings, double click the speaker icon there in the bottom right panel window.. the volume control window will appear, check the balance controls etc. hope this will help.. [:0)
Oct 01, 2007 | ASUS P5S800-VM Motherboard
LaCie (300908) AIT Tape Drive Logo
110 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
