Question about Lexmark X5250 All-In-One InkJet Printer
Hi I have installed the Lexmark 5200 all in one printer , every thing is there and it states printer ready but it still wont print. We have got windows 7 on the computer Thanks
  • 340 Answers
You will need to go to the Lexmark website and download the drivers for Windows 7, this should take care of the issue.
Posted on Nov 13, 2010
Will only print maybe one page of a 4 page document and sometimes wont print at all
Below are 3 possible solutions.
Unexpected page breaks occur
Cause Solution
Job has timed out.
Set the Print Timeout to a higher value:
Blank pages
Cause Solution
Toner is low.
Remove the toner cartridge from the printer. Shake the cartridge back and forth several times, and then reinstall it.
Install a new toner cartridge.
Toner cartridge is defective or empty.
Replace the toner cartridge.
Jobs do not print
Cause Solution
Printer is not ready to receive data.
Make sure Ready or Power Saver appears on the display before sending a job to print. Press to return the printer to the Ready state.
Specified output (exit) bin is full. Remove the stack of paper from the output (exit) bin, and then press .
Specified tray is empty. Load media in the tray.
Wrong printer software is installed.
Verify you are using the correct printer software with your printer.
If you are using a USB port, make sure you are running Windows 2000, Windows XP, Windows Server 2003, or Windows Vista and using Windows ME, Windows 2000, Windows XP, Windows Server 2003, or Windows Vista compatible printer
software.
Cause Solution
Internal print server is not set up properly or is not connected properly.
Verify that you have properly installed the print server and configured the printer for network printing. For more information about installing a network printer, click View User's Guide and Documentation on the Software and
Documentation CD. Copies of the printer software are also available on the Lexmark Web site at www.lexmark.com.
You are using the wrong USB or Ethernet cable, or the cable is not securely connected.
Make sure you are using a recommended cable.
Make sure the connection is secure.
For some reason Lexmark has not posted information for this model. If you need a manual you might try the C534 manual at: http://support.lexmark.com/index?locale=en&page=product&productCode=LEXMARK_C534&segment=SUPPORT&userlocale=EN_CA&frompage=null#2
Dec 10, 2010 | Lexmark C533DN InkJet Printer
Installed the 5200 series on my laptop software on computer but nothing printing out on printer. Have checked power is on an all cables connected. Have uninstalled and re- installed it but still the same....
Are you selecting the printer in the print screen? It's possible that the Lexmark wasn't set to default and your computer is trying to print to another unconnected printer or a virtual printer.
Oct 15, 2009 | Lexmark X5250 All-In-One InkJet Printer
Cannot install
I don't know what you mean that it is not available. I assume that you are simply trying to select an available printer on Windows?
You'll need to download and install the driver here. Just select your OS:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Please rate me :)
Apr 24, 2009 | Lexmark X5250 All-In-One InkJet Printer
Printer installed & ready but wont print
found solution: driver software had an error while installing & only installed half the proper software. i had to uninstall the lexmark 5200 serious software completely & download it again from the lexmark website.
i talked to the lexmark customer service live chat line on their website & found out what the problem was. they are very helpful, i highly recommend using it if you have a problem with your lexmark product!
pretty simple solution, its just a little time consuming.
Nov 22, 2008 | Lexmark X5250 All-In-One InkJet Printer
Printer driver for mac
There "may" be one possible solution, which people have had success at.
The Dell 922 printer is the same as a Lexmark X5270
Lexmark has Mac OS X drivers for their version of it.
If you have Mac OS X, the driver can be obtained here:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:440:0:0&searchLang=en&os_group=Mac%20OS%20X&target=
Mar 24, 2008 | Dell 922 All-In-One InkJet Printer
900 service error with lexmark printer
OK, a couple of things... Some earlier Lexmark units had code on both a RIP board (raster image
processor) and an engine board. In this case, the code would have to be reloaded into both
boards. Fortunately, this can be done even if the printer will not boot to a ready state. However, if
this has already been done sucessfuly, the problem may well not be the printer but rather something
in the data stream. To confirm this, remove any and all data cables and reboot the printer. If it comes ready and you can print all the internal pages including the network config pages, then it is likely the
problem is the data stream. One must be careful when the printer is controlled by a print server
because the end user may not have control over the print que. If a corrupt or printer incomprehensible
job is stuck in the que, the printer will go to a 900 condition as soon as the network interface
initializes. This will continue until the print que is cleared.
Hope this helps...
Sean.
Dec 13, 2007 | Lexmark Optra T620 Laser Printer
Printer X1180 lexmark wont install properly
LEXMARK X1180 WONT INSTALL 0N WINDOWS xp DOWNLOADING FROM SITE STILL LOOKING FOR DRIVER FOR PRINTER WHEN I PLUG IN USB FROM PRINTER IT SAYS INSTALLING DRIVERS GOES SO FAR AND NOTHING HAPPENS
Oct 17, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark E238 Laser Printer
Here are the steps to reset the page count on a Lexmark E234, as described here:
  1. Power the printer on and get it to the Ready state.
  2. With the printer on and in the Ready state, open the front cover.
  3. Press and hold the Cancel button until all of the lights begin flashing up and down.
  4. Release the Cancel button and close the door. The photoconductor count should now be reset.
Hope that helps!
-MetaB
Aug 12, 2007 | Lexmark E238 Laser Printer
Lexmark X5250 All-In-One InkJet Printer Logo
231 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
