Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Its saying it has no water when it does and it wont make espresso or steam
  • 1,089 Answers
Check to see if you have the gray float-magnet in the water tank. It should be in the bottom of the tank and float ing in a confined area. There is a sensor in the machine that detects the magnet when its up and clears the fill water tank message. If its down the magnet is bad and you will have to get a new tank.
Posted on Nov 13, 2010
I need to descale my machine, now the screen says descale and "purge" and nothing happens when I press hot water on OR want to let steam out
There is a blockage in the steam/hot water circuit . Try poking the end of the steam tip on wand with a paper clip. Make sure turn the hot water on by pressing the hot water button and turning the steam wand.
Apr 08, 2015 | Saeco Magic Comfort Plus Espresso Machine
I want use distilled water in my new Rowenta DG8030 steam station but instructions say to use 1/2 tap water and 1/2 distilled water or 100% spring water. Why can't I use 100% distilled water? Why can't I...
Believe it or not, distilled water is quite corrosive, more so when hot. Distilled water doesn't contain any dissolved ions but the water is ionic in nature, the ions of every water molecule tend to dissolve away other elements. Steam generating plants and steam ships as well as steam heating systems treat the water with chemicals to keep the water from eating away the metals of the system and test the chemical makeup several times a day while operating. [I spent 4 years in the Navy on a steam powered ship.]
The same holds true for smaller steam appliances like espresso machines and steamers. A very thin coating of calcium carbonate [limestone] is a good protector but too much makes for inefficiencies and burned up elements.
Somewhere I read that Chrystal Geyser spring water is approximately the correct ion balance for espresso machines and I have been using it for years in my espresso machine. In any case you still need to occasionally de-scale your steamer per the manufacturers recommendations.
Feb 03, 2015 | Rowenta Irons
Water smell
You may have some residue inside the steam pipe from previous uses (e.g. milk). If you know how to remove the steam pipe, this will be easy to clean. Otherwise, you could try a pipe cleaner (depending on the type of steam wand).
You can also try running the steam pipe into some water, but be careful not to overheat the boiler (consult your manual... it may say you can't steam continuously for more than a minute, or even less).
Sep 24, 2013 | Nuova Simonelli Microbar Espresso Machine
Hi, I have a delonghi 3400 espresso machine. When I turn it on, it says "turn the steam knob". I turned the steam knob to "on" and nothing happens. I pushed all the buttons and...
you must purge the machine first, by waiting till the light turns on then slowly turn steam knob until a steady stream of water appears.Make sure unit is full of water.
Feb 17, 2011 | DeLonghi EAM3400 Espresso Machine
Machine wont make coffeee, m,essage says ventilate...
You need to push the hot water button on the machines panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
May 20, 2010 | Saeco Stratos Coffee Maker, Espresso...
Steam not working properly = keeps saying close knob then ventilate have waited and pressed 26 + does coffee but then steam not strong enough again
Probably a broken "Steam Valve Cam". They are plastic & prone to failing with consequence that the steam/hot water needle valve does not properly open.
May 05, 2010 | Gaggia Titanium Espresso Machine
Changed Claris Filter-now says
Fill your water tank with Warm Water and then try a few times. Keep Patient and Keep trying for some times and it will work.
May 31, 2009 | Jura Capresso Impressa S9 Coffee...
Water wont stop dispensing Nuova Simonelli JAZZ Espresso
Hello. We had the same problem, after about 20 cups, the hot water would not stop running out the steam nozzle. The problem is either a faulty Solenoid or a blockage stopping the solenoid from closing. We ran the steam for 5 seconds, then stopped, then steam, then stopped, then water, then stop, and it seemed to clear the blockage. Alternatively, you may need to get the solenoid replaced.
Apr 11, 2009 | Nuova Simonelli JAZZ Espresso Machine
Stema Knob wont fully stop flow of steam/water
Here is the link to the part that you need to change. http://cerinicoffee.com/Saeco_steam_valve_plastic_italia.asp
For Saeco Parts and Cleaning supplies visit www.cerinicoffee.com
Jun 18, 2008 | Gaggia Titanium Espresso Machine
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
108 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
eyecam
ray gallant
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
