Question about Dirt Devil Featherlite Bagless Vacuum M085845Vacuum
Not as strong when bought, weird noises too.
The main problem is a weird noise caused by the brush not spinning on the carpet like it used to do strongly leaving a sweep mark on the carpet, which helps pick up the dust through suction. Seems to have lost the power, so I raised it, but it still doesn't pick up that well. What should I do, I already checked the belt, ripped all linen spinned on the brush. It just doesn't leave that mark on the carpet after being swept, it just stops. What should I do?
  • 1 more comment
  • kathywRN Oct 04, 2008
    The brush sometimes spins maybe once or twice but mostly it does not spin at all. I cleaned all the hair and threads wrapped around the brush, inspected the belt which looks fine but it still will not spin.
  • Anonymous Dec 30, 2008
    my vacum is not strong enough to pick up dirt. I cleaned it out well but it did not work.
  • Anonymous Jan 19, 2009
    the brush at the bottom of my vacuum stopped spinning.
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=618616&thid=682390
Posted by Swork100 on Jun 18, 2008
The main problem is a weird noise caused by the brush not spinning on the carpet like it used to do strongly leaving a sweep mark on the carpet, which helps pick up the dust through suction. Seems to have lost the power, so I raised it, but it still doesn't pick up that well. What should I do, I already checked the belt, ripped all linen spinned on the brush. It just doesn't leave that mark on the carpet after being swept, it just stops. What should I do? Dirt Devil Featherlite Bagless Vacuum
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. A couple of the problems you seem to be having is that the belt is stretched out and not picking up well and the other is the brushroll is not spinning freely in order to pup the dust and dirt. The average flat belt change is every 4 to 6 months for the best cleaning and the check your brushroll to see if that spins freely if not it is probably bound up with thread and hair and needs to be cleaned off @ every belt change. If the belt is tight it cleans well and the brushroll does not get a chance to wrap around the brushroll and slow it down. All part of the maintenance of a vacuum cleaner. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 23, 2008
Bissell heavy duty 9x cyclonic vacuum cleaner has loud noise when brush roller is turned on
Inspect the area around the brush roll. There may be something stuck somewhere in there. Remove the brush roll to see if the brush roll end caps will spin freely. If there is hair or debris restricting the brush roll may be causing noise.
Feb 19, 2015 | Bissell Carpet Cleaner Powerbrush Deep...
I can't get my Dyson to switch from flat floor to carpet mode. I push the tiny red button on the brush part, but I get this horrible noise. I already followed the video and cleaned the brushes
The horrible noise may be something wrong in the brush bar assembly preventing the brush bar from spinning freely. Remove and inspect the brush bar and belt or belts if applicable to your model.
Dec 07, 2014 | Dyson Vacuums
My Shark vacuum is making a weird noise how to fix it
HI, it's Jim from Crucial Vacuum!
If your Shark Navigator Lift-Away Vacuum is making a loud noise while it's on then there's definitely a clog somewhere. Here' s a few places you should check prior to plugging in the vacuum and turning it on.
The first place to check would be the brush roll and belt. If you notice visible debris, like strands of hairs, or long carpet fibers this could be catching on the brush roll and causing it not to turn fully. Be sure to clear this debris from the brush roll and manually spin the brush roll a few times after you do so to help unearth and any other clogs. This may be the reason for the noise and its crucial that this part of your vacuum is clog free.
Another part of your vacuum to check would be your hose. Detach the hose and stretch it out as much as you can to see if any debris or clumps of dust are stuck inside. Using a broom handle can help if you see a clog, but it won't come out after you've stretched out the hose.
Another big factor would be a dirty filter in your vacuum. Most manufacturers recommend you change your filter on average every 3-6 months. However, it is recommended to change your filter even earlier depending on usage and allergy care. The cleaner your filters the less debris will get stuck in your vacuum, causing less clogs and overall less odd noises while vacuuming.
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=nv355
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Nov 23, 2014 | Shark Navigator Lift-Away Professional...
Makes heavy vibration noise when turned on for carpet and belt is good
Check the brush roll and the end caps to insure the brush roll is spinning freely. If there is wear or damage to the brush roll it can cause it to be out of balance and vibrate
Jan 12, 2014 | Electrolux EL5020 Vacuum
Roller does not turn
When a Dyson DC07 makes this horrible grinding noise, it can only mean one of three things.
The Dyson DC07 uprights use a clutch mechanism to control the brush spinning when you change the floor / carpet switch. When you hear this grinding noise, it's actually the clutch slipping because it can not spin the roller brush. Most other uprights use a belt to spin the roller brush, and if something is stuck in the roller brush it will cause the belt to break. Dyson's however will make that awful grinding noise rather then breaking the belt, and will only make that noise if the roller brush can not spin.
When you hear this noise on a Dyson, it can only be 1 of 3 things. Either your clutch mechanism itself has gone bad, or the roller brush itself was not properly put back into the vacuum, or the brush itself has gone bad.
I'll be happy to walk you through step by step on how to diagnosis this problem and find out which one of these two parts is bad on your vacuum2_bing.gif.
Step 1. Make sure the vacuum is unplugged. Then turn the vacuum upside down so that the brushes are facing up. It's easiest if you put the head of the vacuum on top of a bench, or counter top. This is how the vacuum should look:
Step 2. You see on the bottom of the vacuum 3 plastic screws that are usually the same color as the vacuum cleaner2_bing.gif. If you're vacuum is purple, the screws will also be purple. Use a flat head screwdriver, and turn each of the 3 screws a half of a turn, counter clockwise to loosen then. After each screw has been turned (you don't need to remove the completely, just a half of a turn is all), simply pull upwards on the bottom plate to remove it.
Step 3. You should now be able to see the roller brush exposed. You'll now need to remove the roller brush. This will take some patience, and some work in order to get this brush out of the vacuum. There is a special tool that has been designed to help you get the brush out easier. I would try getting the brush out first before buying this special tool. The easiest way is to use a flat head screw driver and pry the belt up while pulling up and out on the brush. With some patience and some maneuvering, you'll be able to get the brush out of the vacuum. Here's where you should put the flat head screw driver on the brush:
Step 4. Once you get the belt out of the vacuum cleaner, it's time to test it. Use your finger tips to hold just the end caps on the very end of the roller brush. While holding just the end caps, use your thumbs to try and spin the roller brush. Does the brush spin freely? It should rotate completely several times on each spin. If the brush doesn't spin, or you feel some kind of resistance to the brush spinning, then this indicates that your roller brush has gone bad. Here's a picture of how to test the brush:
If the roller brush went bad, then you'll need to purchase a new one. Here's a direct link to the roller brush your machine uses on our website GoVacuum:
http://www.govacuum.com/dysondc07.html
If the brush however was able to spin freely, and it spun multiple times, this indicates that most likely the brush was not put back in properly, or it could be a little more serious of problem in the clutch itself has gone bad. The clutch replacement repair is a much longer, more challenging repair to do. There is a very helpful video on how to replace the clutch below so that you may follow step by step instructions on how to change it. It was really helpful for me the first time I did this repair.
I think more likely however it's probably that the brush was not put back in properly, and this caused the brushes not to be able to spin, which would cause the clutch to make that horrible noise. Make sure that the roller brush is pictured like the brush above, you may also want to make sure that the bottom plate is put on correctly, this could also prevent the brush from spinning:
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
If you need to replace the clutch, here's a direct link to the clutch your Dyson DC07 uses on our website:
http://www.govacuum.com/dydcclasfore.html
Here's the video on how to replace the clutch:
When you hear that grinding noise, it can only be one of these three problems. This clutch mechanism was so problematic that Dyson removed it on the second series of the DC07 models. I hope that this repair was helpful in diagnosing your problem. If you have any questions about the diagnosing, or the clutch change, please feel free to use the Clarification Request form here on the Fixya repair page. If this was helpful you, please be sure to rate my repair as helpful by clicking the thumbs up icons.
Thank you,
Chris J.
GoVacuum
Apr 06, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a dyson dc07 with a malfuncitoning clutch diagnosed here on fixya. I've replaced the clutch and the grinding noise when the clutch is engaged for carpet and non rotating brush problem presists. This...
Greetings from GoVacuum,
If you have replaced the clutch already, then this can really only be one other problem, and that is the roller brush. If the roller brush's bearing have locked up, and the brush is no longer spinning, this is going to cause the clutch to make that horrible grinding noise, and a lot of people incorrectly think automatically that the clutch needs to be replaced.
Here's a very easy way that you can test the roller brush on your Dyson to see if it may have gone bad. In 10 years of fixing and selling vacuum cleaners, I have never seen such a cheap roller brush that's in the Dyson DC07 models with clutches, unfortunately this is notorious problem we see on this particular model.
Ok, so to test out the brush, make sure the vacuum is unplugged, and turn it upside down. Remove the 3 plastic screws on the bottom plate, and remove the bottom plate to expose the brush completely.
You may then simply pull upwards on the roller brush, and take the brush out of the belt that is wrapped around it. After the brush has been completely removed from the vacuum cleaner, hold the brush with only your pointer fingers in each hand, and only put your pointer fingers on the outside of the bearing caps on each side of the roller brush.
While holding only the bearing caps with your fingers, try to spin the brush with your thumbs. The brush should spin freely in your fingers, and you should get a good 5 or 6 rotations with each spin.
If the brush doesn't spin, then your roller brush has gone bad. Espcecially with home that have long haired pets, or females, the hair gets between the bearing cap and the bearing inside and causes the plastic caps that are covering the bearings to heat up, ultimately causing the bearing caps to melt, and finally the bearings sieze, and the brush will no longer spin freely which is why the clutch makes that awful noise.
Good news is that the roller brush is not as expensive or as difficult to replace as the clutch was. You may purchase the DC07 roller brush here;
Genuine Dyson DC-07 Roller Brush for Models That Use a Clutch Part # 904174-01
If your roller brush does spin, then I'm baffled as to what could be causing the clutch to make noise, but I'd like to try and help you figure this out.
Please send me an email to chris.jones@govacuum.com, or just request a clarification request here on Fixya, and I'd be more then happy to try and diagnosis this Dyson further for you.
If this Solution was helpful to you, please rate the repair as helpful by clicking on the 4 Thumbs Up Icons in the top right hand corner of this solution.
Thank you so much, I hope that this helps you.
Chris Jones
GoVacuum.com
Nov 22, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Loud noise when I start the vacuum in carpet position
Not exactly a solution, but more of an explanation. The noise is caused by a ratchet device that's designed to protect the belt if the brush roller becomes blocked. It's a bit like a clutch that slips when resistance on the brush gets too great. The noise will occur if there's a solid blockage, of course, but it will also occur whenever the machine senses excessive resistance. This may happen on carpets with really thick pile, but can also happen if the carpet is loosely fitted and can be sucked up tight to the roller by the force of the vacuum.
Small consolation, but the problem should lessen as the brush wears. Meanwhile, if all else fails, switch the brush off (hard floors mode) while vacuuming the problem carpet(s).
Feb 08, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Correct position of beater bar on a Dyson DC14?
I had the same problem. I removed the brush from the machine. The brush should move freely when removed. If it doesn't move freely, pull the ends from the brush, both ends come off(one will have a rod fixed to it). I would suggest you clean the ends and the inside of where the ends sit on the brush. I applied a little grease on both end housings(inside end housing) if no grease available try washing up liquid. Put the brush ends back on the brush. I then spun the brush to check that it moved freely. It should move freely, if it does fit it back on the machine and it should be silent. If you cant get it to move freely I suggest a replacement brush. Tip: I used a blunt knife and placed it through the belt to avoid removal of the belt. Good luck. Cheers Jason
Jan 19, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Just bought a hoover upright windtunnel cylonic weird noise
no, brush roller shouldn't be touching anything,its under warrenty so take it to a hoover repair shop with your proof of purchase and they will fix it at no cost to you.something like that they might be able to fix it while your there because it won't take long. please leave feedback
Jan 08, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Dyson DC14 all floors.
sept 30,08 bought dc14 all flloor. After 3 to 4 uses it started making lots of noise when on carpet setting. I examined the roller brush and it was cracked at one end. I returned it Oct 13 ,08 and got another dc 14 all floor. Now this one after 2 uses has the same problem only a larger crack in the brush and a small piece of the brush broke off. Very dissapointed.
Jan 08, 2008 | Dyson DC14 All floors Bagless Upright...
Dirt Devil Featherlite Bagless Vacuum M085845Vacuum Logo
398 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
